Question about Sony Cyber-shot DSC-W80 Digital Camera
My sony NP-BK1,fallen down.This sis company's property i am poor i can't spend money to repai.it's lens strucks.pleas help me..............it's lens strucks not mooving,
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jul 06, 2010
The lens has got stuck and will not move in or out
The lens error is due to failure of the lens control system. You can remove battery and card replace battery and while switching on tap the lens hood on your hands so as to disengage any dirt or mechanism being struck.
Use some air to blow between the lens to dislodge any sand particles struck inside. If none of these works then you can think of taking consensus with the service centre.
get estimate before you decide. It will be good to have it checked at the Sony service as you do not have to run around for spares.
Jan 22, 2011 | Sony Cyber-shot DSC-W170 Digital Camera
Dropped my sony digital DSC-W370 14.1 and the lens would not close. Have taken it to camera repair shops but they want to charge more than I payed for camera. Would like to know if I can try to close lens...
Use some air to blow between the lens to dislodge any sand particles struck inside. If none of these works then you can think of taking consensus with the service center on a reasonable estimate as some of the costs are high and hence they charge more.If the get estimate is high then you decide to scrap and go for a new model.Since some of the spares are available only with Sony service, this must be thought of, as you do not have to run around for spares.
However if the camera works without the lens shutting try and use it without any repair as Sony would have estimated for lens mechanism assembly
Jan 20, 2011 | Sony Cyber-shot Dsc-w370 Camera
What can you tell me about the Bushnell 420 x 60 Refractor Telescope?
No matter what the box says, 110x is the maximum power for a 60mm objective lens. The tripod is weak so stability is a problem. Fair for lunar observation and fair to poor for planetary viewing.
Go spend some money on a decent telescope A Celestron 114mm reflector is only about $150
Oct 06, 2010 | Bushnell Deep Space 78-9512 (120 x 60mm)...
Hi... Can you help me in the software of my pc the Video Controller (VGA Compatible) It was gone when I was reformat the PC. Motherboard Manufacturer: Company Name Micro-Star International Motherboard...
Field Value North Bridge Properties North Bridge SiS 661FX Revision 11 Memory Timings CAS Latency (CL) 2.5T RAS To CAS Delay (tRCD) 3T RAS Precharge (tRP) 3T RAS Active Time (tRAS) 5T Memory Slots DRAM Slot #1 256 MB (DDR SDRAM) DRAM Slot #2 512 MB (DDR SDRAM) Integrated Graphics Controller Graphics Controller Type SiS 330 Mirage Graphics Controller Status Enabled Graphics Frame Buffer Size 32 MB AGP Controller AGP Version 3.05 AGP Status Enabled AGP Device SiS 330 Mirage Integrated AGP Aperture Size 64 MB Supported AGP Speeds 1x, 2x, 4x, 8x Current AGP Speed 8x Fast-Write Not Supported Side Band Addressing Supported, Enabled Chipset Manufacturer Company Name Silicon Integrated Systems Corporation
Jul 16, 2010 | Microsoft Windows XP Professional SP2
The camera comes on when the powere button is
Usually this is a sign that the battery is weak or not charged enough.
Make sure you have either a new battery or the battery is fully charged, then test the camera again.
This camera takes a Sony NP-BK1 Li-ion rechargeable battery (or compatible).
If the battery is good and is fully charged, then there is a problem in the camera, and needs repair or sell it as parts or as is (if repair cost is too much) on a site such as Ebay.
Apr 15, 2010 | Sony Cyber-shot DSC-S750 Digital Camera
Not reading discs
I bet your blu-ray lens is going bad. If your PS3 is backwards compatible, try putting in a PS2 game or Standard-Def movie. If it loads/plays just fine...that narrows it down to the blu-ray lens/drive. This happened to me a few weeks ago.
*NOTE* WHATEVER you do, DO NOT send your PS3 to PSR1. They stole $109 from me. They DO NOT fix your PS3. They lie. I am spending my free time right now trying to help people save their money. THEY STEAL FROM GAMERS! SO WRONG!
Nov 05, 2009 | Sony Playstation 3 (PS3) Console
Sony battery np-bk1 won't charge.
I have cybershot sony dsc w-370 i found an information massage ever apear ( for use with compatebel battery only ) while i use NP - KB1 SONY battary so how couled i solve it ? thnkes
Oct 04, 2009 | Cameras
Canon np 6030
Replace the exp lamp and try again after an error clear.
Jun 25, 2008 | Office Equipment & Supplies
Sony Cyber-shot  DSC-W80 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
