Question about Danby DPAC8020 Air Conditioner
What is the P2 code on an everstar mpk 10cr1 - Danby DPAC8020 Air Conditioner
  • 37 Answers
<b>Unit Displays P1</b><br /> P1 error indicates that:<br /> <ol type="A"> <li>The water tank on the side of the unit is full. <li>The water tank in not properly seated in the housing. <li>The switch at the back of the water tank housing is not engaged or is loose </li></ol> <br /> <i>Solution</i>:<br /> <ol type="A"> <li>Empty the water tank. <li>Make sure the water tank is properly secured in the housing <li>Remove the water tank for the housing and gently tilt the switch at the upper left hand corner of the housing towards you. This should allow the tab on the water tank cover to engage the switch. </li></ol> <br /> <b>Unit Displays P2</b><br /> P2 error indicates that the spill reservoir in the base of the unit is full.<br /> <i>Solution</i>:<br />Move the unit to a location that is suitable for draining water from the unit.<br />Remove the plug in the lower center of the back of the unit and allow the water to completely drain <br />(Remember to replace plug.)<br /> <hr color="#cccccc" size="1" /> <b>Unit Does Not Cool/The Green Light is not on. </b><br /> Is the unit in the Cooling mode?<br /> <i>Solution</i>:<br />Press the mode button until cooling mode is selected. <br />Lower the temperature setting on the unit to the minimum setting. <br />(The temperature setting of the unit has to be lower that that of the room)<br />Wait 3 to five minutes for the compressor to start running.
Posted on Aug 21, 2010
Everstar MPK-10CR compressor keeps running after power off, on remote. Display blanks. Only shuts off when O/L @ wall plug tripped.
call in an electrician as there is a problem in the circuit allowing power from a neutral line and bypassing the switch
Jun 30, 2016 | Everstar Portable Air Conditioner MPK-10CR
Everstar mpk 10 cr 1 manual, have an error code of P-1
It means that the little drawer for the water on the side is full of water or that it is not closed completly. In the water drawer there is a switch that makes it turn off the AC if it is running ,then it will give you a P1 code.
Make sure the water drawer is empty of water then. put the drawer back in carefully and gently, the switch that is built into the drawer will make contacts and your problem should go away. you might have to unplug the unit from the wall for it to clear the problem after doing the above steps.
Also here is a link to their site, Midea the company that makes these MPK-10CR units. For the owners manuel http://www.supportuscenter.com/documents/MPK_Manual.pdf
http://www.supportuscenter.com/pilot.asp
Sep 11, 2009 | Everstar Portable Heater/Fan
My unit displays P2 mode flashes red wont turn.....
Solution:
Move the unit to a location that is suitable for draining water from the unit. Remove the plug in the lower center of the back of the unit and allow the water to completely drain (Remember to replace plug.)
Remember...this is not the water tank on the side. This is the water than can collect in the bottom of the unit. Take it outside and drain it
Aug 20, 2009 | Heating & Cooling
Everstar Model MPK-10CR, What does flashing P2 mean?
p2 means the bottom pan is full, you need to drain the bottom, small valve on the back bottom in the middle
Aug 13, 2009 | Danby DPAC8020 Air Conditioner
Danby DPAC8020 Air Conditioner Logo
1,753 people viewed this question
Top Danby Heating & Cooling Experts
Dan Webster
Dan Webster
Dennis Boxerman
mintvl
Level 1 Expert
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
