Question about Dryers
Dryer is heating, but clothes are taking too long drying -- you gave one solution already.
Your Solution helped a bit, but this is apparently not the problem... I checked the duct in the back of the dryer. There was some blockage of the duct, from being too close to the wall. We cleaned it out and moved the dryer forward to prevent it from happening again. So, this did correct the worst of the recent trouble I have been having. However, it is not fixed. Loads are taking a full cycle (hour) plus another 30 or so minutes; which is back to what it used to be -- still too long. We are in Phoenix, AZ and have low humidity. Clothes would dry only a little slower if I hung them out. (...and I do with a few things, so I know how long it takes to air dry!)
The lint trap is now filling up pretty evenly, and a little thicker covered. See, a month ago we did a bunch of cleaning in the laundry room to add a chest freezer. We scooted the dryer back a bit to get the freezer in. OOOOPPS.
I've been doing some reading on the internet and am wondering if we need to replace the door seal? This is the only part that I can find that mentions trouble with the drying time... I looked at it, I cannot see an obvious tear, but given the symptoms ?????? Only other thought is to go get a dryer lint cleanout brush kit from Linens+Things.
please help.
    Novelist:
  • 184 Answers
IF THE DRYER DRIES O.K. WITH THE EXHAUST UNHOOKED FROM THE BACK OF THE DRYER, THERE IS STILL A RESTRICTION IN THE DUCT WORK. LINT WILL BUILD UP, ESPECIALLY IF THE DUCT IS FLEX DUCT WITH THE SPIRAL LOOK. REPLACE FLEX DUCT WITH RIGID METAL DUCT WHERE POSSIBLE.
Posted on Apr 22, 2008
LG Dryer takes too long to dry clothes
Sure the outside vent is not clogged up? If so it will overheat and turn it self off and do a poor job of drying the clothes.
Also check and make sure that all of the heating elements are working properly.
Jul 09, 2017 | Dryers
Tip
How to receive the best dryer repair help on FixYa
There are a couple of things that you should include in your dryer repair question so you receive the quickest and most accurate answers.
1. Model Number
The model number can be located on the model/serial number tag that is located on the dryer.
Make sure you get the full model number from this tag and not the model number from the owners manual.
The model number from the owners manual only includes the first few digits of the full model number because they include that owners manual with many similar models of dryers.
With the full model number I'm able to look up factory service manuals, tech sheets, wiring diagrams, factory service pointers and so much more.
2. Detailed description of the problem
At the very least give a brief description of the problem you are having with your dryer.
Descriptions like 'My dryer don't work' is not very helpful.
Describe what is not working. For example is the not heating? Maybe the dryer is heating, but takes a long time to dry?
The more details you can give the better. Instead of saying 'The dryer is heating, but takes a long time to dry' you could go into more detail and say something like...
"I put a load of cloths in my dryer and set it on the auto dry cycle. When I went to take them out two hours later the dryer was still running. The cloths were still a bit damp too. Most of the time I can dry a load of cloths this size in one hour. Why is my dryer taking so long to dry?"
Following these couple tips can help you get a faster and more accurate reply to your dryer repair question.
on Aug 03, 2011 | Dryers
My LG Tromm DLE5955W dryer has great airflow and heating but about 2 months after I bought it, it now takes 2 hours to dry a load of clothes. I have vaccumed it out and replaced the vent house already with...
You have a problem with the exhaust vent in the house walls. Try this. Disconnect the dryer vent hose from the back of the dryer and see how well it dries a load of laundry. If it comes out alright, then you know that the vent in the house is clogged and will need to be professionally cleaned out. Good luck
Jun 19, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
It takes hours to dry a load moderate to heavy load of wash. There is definitely heat, so the heater element is doing something--but apparently not enough to dry the clothes in a reasonable amount of...
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Nov 21, 2010 | Dryers
Dryer heats up but doesn't dry clothes take 3 hours after restarting 3 times to dry 3 articles of clothing.
It's not your heating element. Your venting system is clogged. Like mine was. You'll need to take care of this ASAP and from then on at least once a year. It is a fire hazard. Not only that if left this way It can kill your heating element.
Oct 15, 2009 | Whirlpool LER4634J Electric Dryer
Takes a long time to dry clothes
You might want to clean out the exhaust hose where it goes thru the house. Also vacuum inside the unit to if you havent done so already. Let me know if this helped
Apr 27, 2009 | Dryers
Dryer
Today my whirlpool dryer started making a loud noise. it is drying the clothes but the noise is loud.
Jul 06, 2008 | Kenmore Dryers
Dryer heats up but does not dry clothes
first take the venting off the back of the dryer and dry a load if dryes normal replace venting if takes a long time to dry have a repair man clean the dryer
Jun 12, 2008 | Kenmore 74602 Gas Dryer
Maytag dryer doesn't dry properly
heating element is fine. it either works or it doesnt, cant work halfway, your problem sounds like you hav a clogged vent a kinked exhaust leaving the home. try looking at the exit point form the home can you see any lint around the housing, VENT VENT VENT
Mar 11, 2008 | Dryers
Takes too long to dry clothes
Check the dryer venting from the dryer to where it exits the house. It is most likely coated with lint and needs to be cleaned out.
Jan 08, 2008 | Dryers
Dryers Logo
145 people viewed this question
Top Dryers Experts
