Question about Echo Garden
CS-670 . Cleaned fuel tank , lines , carb. New
CS-670 . Cleaned fuel tank , lines , carb. New plug . Good compression , pulled plug and could smell the fuel . Still won't start .
    Brigadier General:
  • 4,088 Answers
Check for blue, snappy spark at the plug (gapped at 0.020"). If weak or nothing, remove the flywheel cover to expose the ignition module. Check the module gap with a thin business card--turn the flywheel magnets under the module poles, insert the card into the gap, loosen the module screws, and allow the module to contact the magnets, then tighten the screws. Turn the flywheel somewhat to remove the card. Recheck for spark--if ok, try for engine start. If still no spark, remove the ignition switch wire from the module and retry for spark. If still nothing, replace the module. Install per the above instructions. Hope this helps!
Posted on Jul 16, 2010
I have a psa 225 echo weed eater. The engine readily starts but will only rev up using the choke lever back and forth. No power. What's my problem?
Carb or filter
. replace fuel filter in tank while checking both pickup and return fuel lines.
remove carb and disassemble cleaning all parts with carb cleaner and some soft air blow . look for small screen its round and about 1/4 round in carb these are so small that the gas that's available gells and plugs the openings . try to use non-ethonal high octane gas and use echo 2cycle oil .
Jan 26, 2017 | Echo Garden
Echo PB 251 won't run. replaced plug, gas, fuel filter, air filter. took carb a part, and cleaned with carb cleaner, used the compressed cleaner to clean out venturis/ports.
Wow! with all you have done it should run. Be sure the switch is on but if you are getting spark, it should be on. I would take it to the echo place for service.
May 14, 2015 | Echo Garden
I just bought a 1988 yamaha virago 750 and it was stored outside covered for over 4 yrs.Cleaned carbs and gas tank,put new plugs in,new fuel lines and checked fuel filter is ok. I have spark,compression...
good start on cleaning things BUT, you should replace pump. the pump will have the same gum **** the tank did. you can unhook lines and turn over to see how much fuel you get
Jun 14, 2011 | 1988 Yamaha FZX 750
Model 345 won't start. New fresh gas/oil mix. Cleaned carb with liberal applications of gumout. Removed diaphragm and inspected carb, cleaned what passages I could identify. Cleaned fuel line. The fuel...
There is a vent in the tank, it is situated on the right hand side of the tank, close to where the fuel hose exits the tank, the early vent looks like a round white pellet, the later vent is a white plug with a nipple on the top, the later vent will just pull out with long nose pliers, the early vent has to be extracted useing a self tapping screw, this of course will destroy the vent.
Jun 07, 2011 | Husqvarna Garden
Cub 1550 with kohler courage. Runs fine and then loses power, runs erratic and starts to backfire. Cleaned carb and fuel pump and ran fine for 30 minutes and then problem started again. When this occurs,...
Replace fuel filter after cleaning tank thouroughly, to clean tank remove fuel line at carb. Drain all fuel then leave line loose until you flush tank with carb. Cleaner then blow out tank with compressed air. Now install new fuel filter and check your fuel can for trash and water better yet just add fresh fuel.
Aug 12, 2017 | Garden
2004 Honda sportrak 400ex quad, Carburator diagram & adjustments. Will start run for a few sec. & then die. Sat 4 almost a year, took old fuel (as much as i can)out & put in new 91oct...
your carb needs to be cleaned/rebuilt,the jets are clogged from the old fuel,if the fuel that was in the tank had a really bad smell,then the fuel is bad,and what was in the tank is also inside of carb.(carb kit).
Mar 06, 2011 | 2005 Honda XR 400 Motard
Bike not starting at all. sometimes it starts after continous kicks but no use .agian the same problem.
I would suggest that you cleanyour carburetors.
To tell if they need cleaned, spray carb clean in the back of the carb and the kick it over, if it starts right up, then you need to clean your carbs., Drain your gas tank and install a new fuel filter, and put new gas in the tank too.
If it doesn't start right up on the carb cleaner, then check to see if you are getting spark.
If you have spark, then test your compression.
Compression should be at least 125-145 psi but not less than 100 psi to run.
If you don't have spark, pull power wire off coil and see if you have power to the coil.
If you do have power then your coil is bad.
if you don't have power, make sure your on/off switch is working. check wires
As long as you have good compression, good fuel and good spark, that motor will start.
Pull out the plugs and see if they are dry, or wet or , black and sooty.
If dry - no fuel
if wet - no fire or misfire
if black and sooty - clean & check gap or replace with new ones.
Nov 30, 2010 | 2006 Hero Honda Passion Plus
Honda GC160/ 5hp will not start
Two things here, Pull the line on the fuel tank off replace the in line fuel filter and replace the gas pump bulb if it is bad it will not allow the gas to stay in the carburetor. Also pull plug and see if it has good compression by putting you finger on top of it and move the flywheel till you get compression. Also the governor may be sticking it's connected to the carburetor and the arm that goes inside the engine. But the filter first.
Jul 10, 2009 | Karcher 2500 PSI Pressure Washer
I have a 98 honda foutrax 300 4 wheeler it started acting up and now it wont start took the carb. off and cleaned the jets and everything up and pulled the spark plug out and put my fire over the hole and...
remove all of the old fuel using a siphon bulb and hose. Put in brand new fuel and make sure the line from the tank to the carb. is flowing gas. if not clean or replace the fuel line
Jun 17, 2009 | Honda NS 250 R Motorcycles
Open Questions:
Garden Logo
188 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
Jim London
Jim London
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
