Question about Lenovo 3000 C200 Notebook
Battery power not working
Works ok when pluged in. Battery level shows 94% charged but battery power not working.
    Problem Solver:
  • 8 Answers
Try Removing your battery first then unplug the Power adaptor from the system, then press and hold down the power button to do a power drain on your systems motherboard.
return your battery then try powering the system using battery only.
if the system still wont power up using battery, plug in your adaptor go in windows, go to add remove programs or programs and features depending on what windows your system has, once in either one of the two look for energy management uninstall it from your system then restart the computer one last time try powering using your battery only.
If still this does not work powering the system using battery try updating drivers for your motherboard go to the lenovo website consumersupport.lenovo.com for the chipset drivers download
if still nothing has changed call lenovo probably something is wrong with your motherboard or battery you may need to send the system back to lenovo for further checking.
Posted on Jul 08, 2010
I have to keep battery charger pluged in or nothing works
Probably one of the cell might not be working properly ie not holding the charge hence battery getting flat. Or check liquid level in the battery, might be low. or time to change.
Feb 09, 2014 | Jayco 2010 Jay Flight 28 BHS
I have a dell 1737 that will not recognise any power adapters I plug into it. It runs fine on the mains through the adapters but will not charge the battery. The battery works fine on the laptop if I...
ok becare with pluging in any power adapters, coz the machine has to run with the correct voltage. otherwise it will cause alot of damage to your laptop
Oct 22, 2012 | Dell Studio 1737 Laptop
My acer extensa 5620z does not charge nor works connected
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
May 25, 2012 | Acer Extensa 5620 Notebook PC
My philips gogear 4g is pluged in and works but when i unplug it it says low battery and shuts off immediatly it has been left on for 4 hours now trying to fully charge it will not charge is the battery...
If the media player battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Aug 26, 2011 | Philips GoGear ViBE Digital Media Player
HI, i Have lenovo 0769-A63 laptop i have problem in my battery, when i put AC then my laptop is start,battery shows 83%(pluged in,Not charging). when i remove the AC System is cloosed is just like Cpu, its...
Aug 12, 2011 | Lenovo 3000 N200 Notebook
Dell inspiron 8100 no ac power-power only with battery
You may have to run the battery/charger utility test.Look under control panel classic view.
Jul 14, 2009 | Computers & Internet
Power
your battery is all the way dead and needs charging, or your battery is not holding any charge and you need a new battery, or, worst case scenario, the phone battery contacts are not working and your phone is now incapable of using a battery.
Jun 23, 2009 | Palm Treo 500 Centro
Problem with getting inverter to work...
Inverters works from 12v carr battery or backup battery, you can not charge the inverter you msay killed your inverter if you connected to 120v wall mount...you use the inverter to give you AC (electric) from 12v battery. if your tv is 12v you need to know how much needed to get the correct connrection as output and input.
Nov 07, 2008 | Vector Maxx SST Power Inverter
Not charging
I found out how to solve this problem...first power down your computer. Then take out the battery, remove the power supply, and then hold down the power button for 30 secs. Put the power supply in only (not the battery). Start your computer after everything is done loading up put the battery back in. Give it a min. and then you should be able to roll your cursor over the battery life indicator in the lower right corner of you computer and is should say charging. I have found that other people have had this problem and it has worked for myself and for them.
Aug 26, 2008 | Computers & Internet
EVO n600C NOTEBOOK battery not charging.
1. Check the socket u pluged it in
2. have the charger tested for continuity.
Mar 14, 2008 | HP Compaq Evo Notebook N600c
Lenovo 3000 C200 Notebook Logo
205 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
