Question about MicroBoards Orbit (ORB-4201-01) Burner
Need manual for model # 58308 Orbit telescoping tripod sprinkler base with brass impact head
2 Suggested Answers
  • 3247 Answers
SOURCE: how to program an orbit sprinkler system for model
In case you are looking for the actual programming instructions these are available from the Orbit website.
http://www.orbitonline.com/lib/media/57880-31rA_005316.pdf
User Instructions
http://www.orbitonline.com/lib/media/57880-24rB_005637.pdf
Tutorial
http://www.orbitonline.com/tutorials/6station.cfm
If you already have the instructions but are not clear how to start, then please post a comment if you need specific help.
Posted on May 20, 2010
How to adjust spray and spray pattern
check the directions on the box. sometimes sprinkler head has two screws. one screw is for pattern adjustment and the other is for spray adjustment
Apr 07, 2016 | Orbit Irrigation 58308 Tripod with Brass...
Have a system 7 heads 5 feeding off trunk line two off of two tee lines. the system is feed by 3/4 pipe,it worked fine for 1 year know it won't always pop the heads.
Either the pressure has gone down due to a leak or the heads have gotten dirty inside and need to be cleaned out so they again pop out fully.
Mar 06, 2015 | Orbit Satellite Impact Sprinkler Head
Orbit sprinkler manuals
Check for obstructions in the mechanism. Follow the instructions on the adjustments.
Aug 09, 2014 | Orbit Irrigation 58308 Tripod with Brass...
Is there a manual for the orbit h2o-6 gear drive sprinkler on tripod?
Contact the manufacturer. They usually will have the manual online for downloading.
Jul 24, 2014 | Orbit 58565N H2O-6 Gear Drive Sprinkler
Can this valve be repaired?
Check to see if the company has a rebuild kit for the unit.
Jun 06, 2014 | Orbit 51016 3/4" Brass Anti-Siphon Valve
My sprinkler head is stuck spaying in one spot and I can't figure out how to adjust the range and distance of it.
Sounds like you have a bucket impact sprinkler. These are problematic as they tend to beat themselves into non-operation from the moving parts involved and the impacts. They stop turning for a number of reasons, low water pressure, dirt and debris filling the bucket impeding rotation, plants covering the sprinkler etc. If no debris is found and others continue to work on same zone the water pressure is probably unchanged it may just be tired. I suggest replacing it using a pop-up rotor preferably a Hunter PGP-ADJ or PGJ-ADJ Rotor as rotors have only 1 moving part a gear which is sealed inside the sprinkler making them very dependable.
May 14, 2014 | Orbit Sprinkler System Super-jet 3-inch...
How do I adjust sprinkler head properly
Check to see if the small slotted screw is flush with the top of the spray nozzle. If so, it has been manually lowered. Turn the screw counter clockwise until it stops, be sure to hold the nozzle to keep it from turning. If no, unscrew the nozzle and remove debris from around filter. Tell the gardener to just mow the grass and not to touch the sprinkler system he is usually why it was turned down 9 times out of 10. If he says "No touch, No touch. He is lying fire him.
Apr 13, 2013 | Orbit Sprinkler System 2-inch Soft Top...
Need instruction manual for orbit sprinkler timer model 57196
Copy following link for Orbit Sprinkler timer manuals
http://www.orbitonline.com/support/guides/Manualsearch3.cfm?Brand=01&Type=Timers
Copy following link for various brand name sprinkler timer manuals, including Nelson, Melnor etc if you need new timer
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
Sep 10, 2012 | Hardware & Accessories
Model 57882 9 station timer I did set up station 1 where do I begin in order to set up station 3
Question is not clear.
Do you have programming problem with the timer?
Or problem locating sprinkler heads?
Or a sprinkler valve problem?
Add a comment with detailed information.
Sprinkler timer turns ON-and-OFF.
Timer does not advance the sprinkler to next station. The sprinkler valve advances to next station when timer turns OFF.
For example, when timer turns ON, then station 1 starts watering.
Timer turns off, and then sprinkler valve automatically advances to station 2.
Timer turns on again, and station 2 starts watering.
Orbit resources:
http://www.orbitonline.com/lib/media/InstallationGuide.pdf
http://www.irrigationdirect.com/media/manuals/owners-manuals/orbit/Orbit-WaterMaster-57880-Controller-Owners-Manual.pdf
Aug 02, 2011 | Orbit 57882 9 Station Super Dial...
MicroBoards Orbit (ORB-4201-01) Burner Logo
756 people viewed this question
Top MicroBoards Computers & Internet Experts
Rick Moore
Rick Moore
 Grubhead
Grubhead
Are you a MicroBoards Computer and Internet Expert? Answer questions, earn points and help others
