Question about Craftsman 8.50 Torque Rating Dual Rotating Tine Tiller
I have an older Sears 3 hp tiller I'm guessing my dad bought it in the 1970's. I got it running again and was going to put some 90 weight old in the chain assembly that drives the till's but I can't find a fill hole! I hate to run it if it is low on oil. Any ideas?
gisvc
  • 40 Answers
SOURCE: tiller wont run
hi,
if it has set up for longer than a few moths it is most likely a fuel issue. many times the diaphram on the carb will dry out and shrink or crack allowing air to seep through leaning the motor to the point to where it will stall after a couple seconds. spray some wd40 aorunfd the ouside body of the carb and tank were the carb attaches if applicable and restart if it runs a little longer you will need to replace the diaphram which is inexpensive to fix usually under $10.00 refer to a manual or somtimes you can go online to youtube and there are many videos on the subject. hope this helps... good uck!
Posted on Mar 30, 2009
MNfisherman
  • 11896 Answers
SOURCE: my 6 HP Craftsman tiller will not run without starting fluid
Carberator is gummed up and will need to be removed and dismantled and soaked in solvent for an hour or two.
Posted on Aug 16, 2009
SOURCE: CRAFTSMAN TILLER
I have the same problem. In my case it is the belt that is screeching. It doesn't move (sometimes) when in gear and the pully spins against it and casues it to screech. eventually it will begin to smoke. I thought maybe the belt was streatched and needed replacing but I can't get it off. There is a bolt with a sleeve that holds the guard on. I can loosen it but can't get it out. I inherited this thing from my dad. I remember him having the same problems from the beginning. As a good rule of thumb - don't by anything with the Craftsman name on it - it usually a piece of junk (my experience)
Posted on May 15, 2010
  • 6468 Answers
SOURCE: Craftsman model 917.299011 carburator problems
you might want to check for spark when it stops running
Posted on Apr 05, 2012
SOURCE: sears rear tine rototiller 32-29978 manual
Here is a link to a JC Penneys tiller that uses the same Briggs&Stratton engine 190402-1835-02 as my Sears 32-29978 8HP tiller.
http://dl.owneriq.net/a/af17c4af-5fe8-2b94-0155-02ad54e688e6.pdf
Posted on Mar 09, 2013
How much grease to put in gear box on a honed fg100
If it is heavy grease and not a 90 weight or better gear oil, you can pack it full. Use solvent and pressure to get all the old stuff out.
Oct 06, 2013 | Honda 25cc 4-cycle Mini Tiller
I have a 40+ year year old TB Horse tiller I need to know how to tighten up the slack in th belts and adjust the reverse disk. I was only 8-9 when my mom bought it for my dad. the main number I saw was a...
Do you know what Horse Power your tiller is? I have a manual for a 7 HP Briggs Troy-bilt that I bought in 89. I presume that you replaced the original belts with new ones?
May 14, 2011 | Troy bilt Horse Roto Tiller Parts Manual...
How to check gear oil on a mtd mimi tiller how much and what kind
I would say 90 weight gear lube go to a boat supply get a tube of 90 weight I dont have your model # so check on your owners manual
Mar 20, 2011 | Mtd Garden
I have a horse tiller. How do you ck. the oil in the gear box. Whate wt. of gear oil do you use.
Hole in the top side casting ... remove the plug. 90 or 110 weight gear oil available at yor auto parts store or other fine retailer who sells lubricants.
Jun 23, 2010 | Troy-Bilt 21AE682L766 Big Red 10 HP...
Old (1981)Troy Prof. 8hp tiller runs 30 sec. and stops.
Clean the carb and if this machine was kept outside all winter make sure no water in tank. I realize you stated that you removed old gas but how it was removed is the key. Try the carb thing first though.
Apr 28, 2010 | Troy-Bilt Pony Garden Tiller
What kind of oil do you put in the gearbox of a 15 year old pony tiller
Hello. The older models use SAE 90 or SAE 140 weight gear oil. joe
please rate my answer as very helpful. Thanks. Joe
Apr 25, 2010 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
PTO making noise when engaged in forward drive
It's 90 weight gear oil but most likely the output shaft seal has been gone for a consdierable amount of time and has leaked out and is just now making noise, they don't normally make noise right away after the oil runs out. put oil up to the plug fill hole and watch if it runs out the shaft seal if it does then it will have ti be repaiered.
Nov 13, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Need manual for craftsman 6 hp tiller model 917293310
you can get a manual from sears. if you go to the sears parts web site,put your model number in and go to the decal section the manual is there for a wopping $3.92 part number is 166007. i hope that helps you out.
Mar 10, 2009 | Craftsman Garden
Craftsman 8.50 Torque Rating  Dual Rotating Tine Tiller Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
