Question about Cycling
2001 ford windstar van makes loud hum from left front while driving
Sounds like the wheel bearing is getting ready to lock up. They tend to hum when they are running without grease
Posted on Jul 06, 2010
2001 ford windstar door ajar light on even with all doors shut
In Windstar models the problem can be caused by the side sliding door contacts, but either of the two other switches in the right and left doors can also cause the light to blink on at times or just stay lighted. The issue is most noticed when the van is turned hard right or left when driving or on a rough road. A Ford dealer can run a test with a special scanner and ID exactly which switch is at fault.
Aug 12, 2016 | Ford Cars & Trucks
Had ticking sound started up this am loud pop then rough running like there was no muffler
Ford Windstar Starting/Stalling Problems - Car Forums at Edmunds.com
forums.edmunds.com > Ford > Ford Windstar
Oct 16, 2007 - 31 posts - ‎26 authors
Learn more about Ford Windstar at the Edmunds.com Car Forums! ... I tried to startmy van on a 15 degree morning - heard a loud bang and now it won't start. Battery ....The engine will crank, start run about 5 seconds then stop. ... I have a 2003 Ford Windstar, same problem,Ford is covering up the problem.
Why My Car Won't Start? - Reasons and Solutions
www.myautorepairadvice.com/car-wont-start.html
As a rough guideline, problems with the battery, alternator and starter are the most ...Before I even put the key into the ignition I hear a clicking noise on the right side ...started it and then it started making a loud clicking noise while I was driving it ..... i have a 2003 windstar ford it was clicking and wouldn't start had to get a ...
Rough Idle Engine Dies Loud Ticking!?! Please Help! - Ford Focus ...
www.focusfanatics.com/.../103146-rough-idle-engine-dies-loud-ticking-...
Nov 6, 2006 - Rough Idle Engine Dies Loud Ticking! ... down then dies and then i restart and it has no problems but the ticking continues PLEASE HELP ME ... Level Up0% Completed ... 2. my injectors are bad and the ticking sound is one of the injectors.... Another method is to turn the AM radio on to a place where there ...Missing: windstar
Jan 08, 2016 | 2003 Ford Windstar
When driving our 2001 montana, the noise gets really loud. Like a loud humming. What could be causing this noise? We had one wheel bearing replaced on the front left wheel which was a little loose, but...
"Loud humming" could describe many of the noises that your minivan may make. Let's start with the basics: do you hear the noise only when the van is in motion or also when the van is stopped? If you can hear the noise even when the van isn't moving, you're most likely looking at something in the engine compartment. Your serpentine belt and the alternator bearings (and, to a lesser likelihood, your power steering pump) are all sources of noise "in there." An A/C compressor on its last legs may also vibrate and cause a humming sound, though that's usually described as more of a "growl."
If you can only hear the noise when the car is in motion, the next question is whether it changes pitch/volume due to engine speed or due to road speed? For example, does the noise get quieter (momentarily, perhaps) when the transmission shifts gears? Or, does the noise simply get louder/change characteristics in a linear way as the van gets faster and/or slower?
Depending on the mileage on your van, the transmissions have been known to get quite noisy after a while, especially if you are doing sustained high-speed driving. The solution for that particular problem isn't cheap, as it involves replacing or rebuilding the transmission (the shift bands may be fine; the noise is caused by bearing wear, seal failure, and other sundry issues that still require pulling the transmission). A less expensive problem is that you might have a problem with one of your tires--a tire with separating belts may make a noise like this as it slowly tears itself apart. If you hit something hard with the undercarriage of the van, you might have a drive shaft that's slightly bent and hence is causing some sympathetic vibrations in the car because it's out of balance.
Depending on the cause, your humming sound may be one of those things that comes with driving an older car--or it may be a sign of the imminent failure of something serious. It's worth getting things checked out again to try to find the cause of the problem. You'll feel a lot better knowing what it is, even if it's something you choose not to fix.
Sep 11, 2011 | 2001 Pontiac Montana
A LOUD hum from the right front while driving a 2001 Windstar. I assume it to b the wheel bearing. Is their another possible reason for this noise?
Could be road noise from a shifted belt in the tire. could be a drive axle going out. those wheel bearings dont hum 99% of the time when they go bad,generally they have a low grinding sound,espesially when you turn,and your teering gets a bit loose and sloppy.
also check to make sure that you dont have a broken strut that may be touching the tire..try putting on your spare and see if that fixex it,if so its a shifted belt in that tire.
May 01, 2010 | 2001 Ford Windstar
Describe where the transmission pump is on a 2001 ford windstar van
it is inside the transmission case in the front of the trans
Mar 11, 2010 | 2000 Ford Windstar
2001 ford windstar van: possible starter problem?
Making sure that you have the right component will help, but should be a relatively easy repair. There are only a few bolts on the starter and you should be able to remove it with a basic wrench and socket set. When you pull the part off check the gear on it to see if it is worn. This may be the problem. Usually, if it is the starter, though it will make a loud grinding noise. Kinda sounds like a high pitched impact gun. Replace the component making sure that you wire it exactly like the one you remove. Take a picture if necessary.
Dec 01, 2009 | 2001 Ford Windstar
2001 ford windstar van: possible starter repair?
No special tools needed , so you should be ok .
Need IMS Conversion vans wiring diagram for 2001
i have a ford windstar 1995 model,also i have a transmission problem,when is cold it drive nomal like 1000 meter,but when it hot stop driving,what do u think is the problem?
Oct 10, 2009 | 2001 Ford Windstar
Cycling Logo
60 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
