Question about LG WM-2277HW Front Load Washer
Stuck lg wm2277h detergent door
How can i open a stuck detergent door
  • LG Master
  • 8,220 Answers
You may need to remove the top so you can get whatever is hung up out of the dispencer. Use this Service Manual
Posted on Jul 06, 2010
  • 171 Answers
Sometimes you got to use little bit of force when you have any other solutions. when pulling out, shake it up and down.
Posted on Jul 07, 2010
My lg front load washer door wont open
Set the machine to END of cycle and leave it for 5 mins. Do this several times. Then try the door. It may be magnetically being held in or it could be mechanically stuck.
If no go.....Pay for that service call.........it will be worth it !
Poppa
http://www.cdbaby.com/cd/poppamadison
Aug 12, 2012 | LG WM2277H Front Load Washer
How do I reverse the door on a LG washer?
If there is no obvious provision for changing over from left to right or vice-versa then you are stuck with the one direction. You have to remember that the door operates the overall control master switch and therefore there would also have to be facility to relocate the switch and tab if you were to achieve what you are thinking about.
Next time, buy a machine the door of which opens and closes in your most preferred direction.....that's all there is as an alternative.
Poppa
Oct 09, 2011 | LG WM2277H Front Load Washer
Our LG dishwasher is not dispensing detergent like it's supposed to. we checked the bottom and the sprayers for any debri/food particles, but it was all clean. Could there be an issue with the dispenser...
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem
Detergent Cup does not Open
heatman101
Apr 25, 2011 | LG LDS4821 24 in. Built-in Dishwasher
WASHING MACHINE NOT WORKING, SHOWING ON SCREEN MESSAGE "LE"
The LG website explains it:
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6250
"Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor."
Apr 21, 2011 | LG WM2277H Front Load Washer
Detergent drawer will not open
Here's a possible solution: Remove the two screws on the bottom side of the plastic clips on the back of the washer (leaving the clips attached to the washer's top), then use the palms of your hands to sharply push the top back about an inch and a half and lift the top off the machine. Now, if you can see enough through the translucent plastic to tell where the hang up is, you can drill a small hole in the top of it to allow you to push that part down so the drawer will open. Then, use foil duct tape to seal the hole.
Jan 12, 2009 | LG WM-2277HW Front Load Washer
Water leaking out the bottom of door
You are using too much detergent. Make certain you use HE (high efficiency) detergent, and one of the service technicians suggests only using about one tablespoon of detergent per load.
Oct 18, 2008 | LG WM2277H Front Load Washer
LG WM2277H* Detergent dispenser will not open.
The soap you use need to be liquid not powder . Also you may need to run some vinegar threw it. It will help dissolve and break up the deposits. Thus allowing the flap to free up. good luck.
Oct 04, 2008 | Washing Machines
Lg wm2277h has low water level
The water level is very low on front load machines. (Below the bottom of the door) While the washer is running, push and hold the "spin speed" and "soil level" buttons at the time. Display should be between 230 and 255.(normal) If you do this while the machine is filling, you will see the numbers change. This machine only uses about 12 gallons of water for an entire cycle, vs. about 45 for some top loading machines. THIS IS NORMAL ! The machine will adjust the amount of water based on the type and volume of clothes in your washer. On a large load, you will see wet clothes, but no water sloshing around. PS. Because the machine uses so little water, make sure you use only one tablespoon of HE detergent (and only one teaspoon of fabric softner if you use it). This is very important.
If this info was helpful, please rate it as a "FixYa". Thanks.
Oct 01, 2008 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer Logo
138 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
