Akai video vsj217 dead apart from red standby light
  • Anonymous Apr 14, 2009
    yeah same problem. peice of junk.
Our tv has no picture
Posted on Apr 18, 2008
Akai pt5492 shut off by itself this morning, wouldn't turn back on. This afternoon I turned tv on and the red timer light came on, no picture, no sound. Checked batteries, unplugged and plugged in a...
First is the Akai name is owned by Samsung--and here is a general answer:
Red light is shutdown or means only standby light is on.
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.
Mar 28, 2012 | Akai Televison & Video
Only on light red standby
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Good luck and take care.....
Oct 07, 2010 | Akai LCT3201AD 32 in. LCD Television
TV just turned off while watching. standby light flickering red 7
Ur power board have dead capacitors.U Know how to solders?Take the tv aparts,check these capacitors in the power board for dead capcitors like puff up or burst open.Replaced these capacitors to get power back.Or buy and replaced the whole reburbish power board at Shopjimmy.com,Ebay.com.
Jan 21, 2010 | Televison & Video
Standby red light just continuesly blinks, no picture -
TV TURNS ON 1-2 SEC SCREEN SHOWS COMPONENTNT1 AND TURNS OFF WITH A POP SOUND FRO9M SPKRS
May 17, 2009 | Akai LCT2701TD Television
Unit will not come on - popping with only red ready light
Have you fixed this yet?Please let me know.Thank You very much!
Tyler
Apr 08, 2009 | Akai LCT2660 26 in. HD-Ready LCD...
AKAI LCT3201AD
Find and replace the following caps, Ec18, 19, 20 / 1000uf/16v,
Ec9, 10 / 1000uf/35v, Ec14, 25 / 470uf/35v should resolve the problem. You can get the caps at almost any electronics supply.
This is a common problem in this unit.
Good Luck!
Happy Thanksgiving!
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
premtech@willapabay.org
Nov 27, 2008 | Akai LCT2715 27 in. LCD Television
AKAI 32" LCD HDTV WILL NOT TURN ON
The only solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to jah2mil@hotmail.com
Nov 27, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Akai Lcd TV
If Z3 was shorted, there are 2 surface mount resistors that were damaged when Z3 became shorted and they have to be replace as well. The reference designator for the resistors is R65A and R65B, their value is 10 ohms and 1206 is the body size of the resistors.
If you need further assistance or to get the power supply repair, write to jah2mil@hotmail.com
Nov 07, 2008 | Akai LCT2701TD Television
Akai LCD TV wont turn on
Hello davidshu,
The issue seems to be a power supply problem. The television has a switching power supply. This might be the problem. I would suggest getting it repaired at a television repair shop due to the possible complexity of the work that needs to be done.
Apr 16, 2008 | Akai LCT3201AD 32 in. LCD Television
Akai LCT3201TD
Most failures of this nature are with dying or defective power supplies.
I service these power supplies. If you need more info, my email is jah2mil@hotmail.com
Oct 14, 2007 | Akai LCT3201TD 32 in. LCD Television
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
