SOURCE: lost the instructions
Here is a link to the manual. http://www.intermatic.com/products/timers/consumer%20indoor%20timers/digital%20timers/dt620ch.aspx
SOURCE: My intermatic timer won't trip back on
I don't think the timer runs on 240 volts does it? You can switch 240, but the timer uses 120 volts to run. You might check the connections and timer clock rating more closely. Also, the 'off' & 'on' trippers are different, make sure you use the right one.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: I do not have operating
Instructions for DT300
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/dt300.ashx
Testimonial: "Thanks, The user instructions for my Intermatic 7-day Digital Timer ( Model DT300 Series) is just what I needed"
SOURCE: lost my instructions for intermatic
EI600 is a heavy duty 20Amp in-wall timer that is battery operated, and can replace single-pole or 3-way switches.
Intermatic page
http://www.intermatic.com/products/timers/in-wall%20timers/electronic%207-day%20astro%20time%20switches.aspx
EI600 manual
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ei600c%20-%20english.ashx
SOURCE: i can only find the
Intermatic posts manuals in Spanish and English, but not every manual is available.
Here are some choices.
1) Add a comment with timer model number and I'll find manual and post link if manual is available.
2) Go to Intermatic manual page below. Use 'Find' feature on browser (click Edit > Find) to locate model number quickly on page. Manual search takes you to individual manuals or to a product page. When page comes up model numbers show in a vertical row > click model number to view drop-down menu for links to manuals.
Not every manual is available.
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
3) All else fails, use google translate. I re-wrote and posted GE yard stake manual today using translator. Enter whole sentences into translator > no need to translate word by word anymore.
http://translate.google.com/#auto'en'
Here's outdoor GE timer translated from Spanish using google translate:
http://waterheatertimer.org/pdf/GE-15107-outdoor-timer-manual.pdf
5) Add a comment and post link where you found Spanish version of manual (as long as it's not a free-manual-with-spyware website) and I'll locate English manual if possible -or- translate manual for you, and post result next day or so.
