Question about Deco Lav DECOLAV Decobronze Push Button Closing Umbrella Drain Without Overflow
Drain won't close
The button to close and open the drain will only close the drain if I keep holding it down. It pops back up as soon as I release it.
  • 25 Answers
Hi, the button can come out of the drain hole either by unscrewing it or some simply pull out, once it is out there is a threaded bolt attatched to it this can be adjusted by screwing it in or out
Posted on Jul 12, 2010
Kenmore smart reach
What is the model number on the model tag?
Feb 13, 2014 | Refrigerators
Popped the lid open to change vacuum cleaner bag...now lid won't close. It's stuck at 90 degree angle. Is a button to release it?
Hi bndennis,
Please check the spring on your lid, it may be keeping the door open. Miele vacuum cleaners mainly use a spring concept for keeping lids open - merely pushing it down will lock it at the bottom.
Kind Regards :-)
JEDEMEYER1
* If this solution helped you, please rate it
Jul 23, 2011 | Miele S4210 Antares Bagged Canister Vacuum
My iphone won't search without the screen getting dark and un readable then freezes
iPhone into DFU mode so you can do an iTunes firmware restore follow these steps:
Open iTunes and connect the iPhone to your Mac.
Press and hold the Home button and the Sleep/Wake button at the same time.
After exactly 10 seconds release the Sleep/Wake button. Continue holding the home button until you iTunes pops up a message telling you that it has detected an iPhone in recovery mode.
The iPhone screen will remain black
: It may take a few attempts to get your iPhone into DFU mode. Generally, I hold down both buttons then release the Home button just before I think the Apple logo would appear. If you are still holding both buttons down and you see the Apple logo you are holding them down for too long!
May 08, 2011 | Apple iPhone Smartphone
How do you get in your ipod if you forgot the unlock code?
Do the following:
  1. Connect your device to your computer and open iTunes.
  2. Hold down "Home" button on the device.
  3. While holding down the "Home" button, hold down "Sleep/Wake" button.
  4. Hold down the two buttons until the Apple logo appears on screen.
  5. As soon as the Apple logo appears on screen, release the "Sleep/Wake" button.
  6. Keep holding the "Home" button until the iTunes logo and the USB lead picture is shown on screen
  7. Release the "Home" button then follow instructions within iTunes.
Nov 21, 2009 | Apple Audio Players & Recorders
What to know if sunroof only slides open or if it will pop up to open like preludes
On EX and EX-V6 models:
The moonroof has two positions: it can be tilted up in the back for ventilation, or it can be slid back into the roof. Use the switch under the left dashboard vent to operate the moonroof. The ignition switch must be ON (II).
To tilt up the back of the moonroof, press and hold the center button. To close the moonroof, press and hold the top of the switch To open (slide back) the moonroof, press and hold the bottom of the switch. Release the switch when the moonroof gets to the desired position. Make sure everyone's hands are away from the moonroof before opening or closing it.
The moonroof has a key-off delay. You can still open and close the moonroof for up to ten minutes after you turn off the ignition. The key-off delay cancels as soon as you open either door. You must then turn the ignition ON (II) for the moonroof to operate.
Hope this helps.
Nov 02, 2009 | Honda Accord Cars & Trucks
I forgot my password on my ipod and can't get it unlocked
Do the following:
  3. While holding down the "home" button, hold down "Sleep/Wake" button.
Oct 25, 2009 | Apple iPod classic MP3 Player
Forgot my itouch password
Do the following:
Sep 26, 2009 | Apple iPod touch
Fuel filler door cable
spray the catch with wd 40
Mar 23, 2009 | 1998 Cadillac Seville
BMW X 3 Panoramic sun roof initialization.
title says X5, but description says X3. i'll explain for an X5, but X3 with the pano should be the same. and i'll explain function of the roof, not reprogramming.
button is located on the panel at the top near the front & center windshield. its the switch on the far left on this panel. its a switch that not only toggles, but also slides forward & back.
with your finger in front of the button, slide it back & release. this will make the cover slide back and store revealing the sun roof. you know have 2 options (tilt the sunroof up or open the roof completely).
to tilt it up, press up on the rear of the button and release. the rear of both roofs will pop up. to close, push up and release the front of the button or slide the switch forward.
to slide it open completely, repeat what you did to open the protective cover (slide the switch from front to back). the roof will open completely and stow out of the way. to close, slide the switch forward and release. pano roof will now close.
to close the cover, slide the switch forward again.
neat trick: if you want to tilt the sunroof open without opening the protective cover, press up on the rear of the button (when the cover is closed) and release. the cover will separate in the middle exposing about a 2-3 inch mesh, then tilts the sunroof open. to close, push the button forward again.
also, if you are above a certain speed (can't remember what it is off hand) with the sunroof open or tilted, it will close automatically, then perform the neat trick on its own to keep air coming in.
one last trick: if you want to open the windows and sunroof from outside, press & hold the unlock button (forward button on the key) and you will see the windows go down, then the roof will open to vent. releasing the button will stop the motion of the windows & roof.
hope this answered what you were asking.
Jan 27, 2009 | 2005 BMW X5
Deco Lav DECOLAV Decobronze Push Button Closing Umbrella Drain Without Overflow Logo
190 people viewed this question
Top Deco Lav Plumbing Experts
Donni Steen
Tom Chichester
Are you a Deco Lav Plumbing Expert? Answer questions, earn points and help others
