Question about RIM BlackBerry Bold 9000 Smartphone
The trackball fell out and I dont know what to do I have a new phone coming tommorrow but i need things in my notes.
    Novelist:
  • 144 Answers
You can 'try' this.
plug your blackberry into the USB port, and when it prompts to start Mass Storage Mode, press the Y key. if that works, you should be able to navigate the phone with windows explorer.
there should be two memory stick / removable drives available.
one will be the built-in device memory of the phone, the other drive is the MicroSD chip that sits in behind the battery.
Navigate through those folders and i expect you will find a folder called Notes.
you can read these with your normal text editor like notepad i think.
Posted on Jul 16, 2010
I got my 8350i wet and the phone works but the keypad goes crazy if i press the trackball it says jkkk should i replace keypad?
honestly i would replace the whole device because you dont know if the keypad is the only thing wrong with it something else may go wrong after replacing the keypad
Jan 15, 2010 | RIM 8350i Cell Phone
My phone fell into a pool then only the trackball
im so sorry for this inconvienience, f you didnt automatically remove the battery after dropping it in the pool then you are almost surely out of luck. leaving the battery out is key, after that take it to an electronics repair store and have them to dry it out and spray electrical parts cleaner on it! this helps it evaporate water and prevent oxidation (which is conductive) after they have finished your phone could work for the next two years!
Jul 08, 2009 | Sharp Sidekick LX Smartphone
My blackberry world edition's trackball suddenly started selecting things as if I pressed the trackball even though I haven't. If I open email it clicks the links in it as I scroll past and reply pops up...
You might have one of three things wrong with your blackberry 1. something is stuck down there like a peice of plastic causing the button to seem like its being pressed all the time or 2. there could be water damage in there thats if you bring your phone into the bathroom with you while taking showers humidity is like cancer to phones it might not show up right away but it can happen 3. someone might of pushed the trackball so hard that it dented the button in this case i would take it in to get repaired. If it is one of the other two it should be an easy fix you can check for either one of these problems underneath the trackball by removing the ring that is around the trackball you can do this by carefully prying around it off then you should be able to drop the trackball itself right out of the phone aswell as any thing stuck in there or if there is water damage or any water down there I suggest you turn the phone off as soon as possible to prevent any further damage then I would just leave the phone in a nice dry place to get rid of the water then the trackball should work again same thing goes for removing anything that might be stuck down there after that is all done with you should be able to reassemble it remember the ring around the trackball only goes in one way so do force it or you risk breaking it.
Cheers,
Kyle
Jul 05, 2009 | RIM BlackBerry ® 8830 Cellular Phone
Trackball fell out of my blackberry curve. I need to scroll down. Is there an alternative method?
You have to have the trackball, there is no other way to scroll. You can probably get one from your local phone store.
May 13, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Tracball works as keyboard
i just threw away the phone cuz i hate it now and i went and bought a new one
when i called support they said its a hardware issue and they couldnt do anything about it and said the only thing is to buy new phone
Feb 09, 2009 | RIM BlackBerry Pearl 8100
I can scroll throught folders only
you may need a new trackball or the trackball socket repaired. either way its less than buying a new phone. contact www.fixphonenow.com they can provide you with a free estimate.
Jan 10, 2009 | AT&T Blackberry Curve 8300 Smartphone
Sidekick 3 trackball helppppp /
I have never taken one apart but here is the link to a website where someone gives the steps to cleaning your trackball. The pictures are quite clear so you should be able to figure out where the magnets go by looking at them.
http://www.fixmysidekick.com/how-to-remove-and-clean-sidekick-3-trackball/106/
Sep 02, 2008 | T-Mobile Sidekick II
Sidekick 3 problems
Antonio-
You may be able to fix many of those things yourself. The trackball proabaly just needs to be clean. Does the LCD have a white screen when it is on? The Camera, well that may take some work.
For the white screen check out here: http://www.repairmysidekick.org/Fix-Sidekick-White-LCD-Screen
If it is not white, a new lcd can be had for 45 dollars on ebay.
they are easy to replace.
replacement of the Sidekick 3 LCD flip screen.
To clean your track ball, follow these instructions:
1: Take a deep breath and blow on the trackball area, rotate and do it again. This may blow any particles block the sensors.
2: This requires a Q-tip and some alcohol. Turn off your sidekick, wet the end of the q-tip, and gently clean the trackball while rotating. Be careful not to get the alcohol on anything but the trackball. Let dry for a minute and try it out. If this doesn’t work then try again.
Apr 14, 2008 | T-Mobile Sidekick® 3 Cellular Phone
RIM BlackBerry Bold 9000 Smartphone Logo
Top RIM Cell Phones Experts
Longtime User
ismael castillo
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
