Question about Hotpoint 23 in. BFI62 Built-in Dishwasher
Glasses not clean and shiny
Glasses are not very clean and shiny. I use finish 5 in 1 tablets. Do I need to add extra salt ?
Thanks
Mrs. Desai
  • 4,059 Answers
Dishwashers have a part usually called a separator or accumulator which traps the dirt from the water during the wash cycles while the water is continuously recycled to clean the dishes. At the end of the cycle the separator is flushed out and the trapped dirt goes down the drain. If it doesn't get flushed out the dirt builds up till it starts showing up on the dishes. Some separators have a hole on top and one on bottom with a valve which stops up one hole or the other depending which cycle it's running. The valve can be stuck or broken causing the problem.
Posted on Jul 06, 2010
AEG 50879
This option can be selected by pressing the corresponding button, and remains in memory until the same
button is pressed again. This option modifies the phases of the programme in order to optimize performance
when "3 in 1, 5 in 1, 7 in 1, ......." detergent tablets are used:
- variation of the duration of the programme and the temperatures required to dissolve the detergent tablets.
- reduction of water exchange
- exclusion of introduction of rinse-aid
- exclusion of regeneration
If you use a dishwasher in the traditional manner (detergent, rinse aid, salt) then the Multitab function is disabled. If you use tabs that are already on the market with rinse aid and salt there is a possibility during washing cycle to add a double dose of rinse aid. From rinse aid dispenser and rinse aid from tabs. This will lead to poor cleaning results, glasses will look like they have been washed in milk..To avoid that you must turn on "Multitab" function and thus exclusion of introduction of rinse-aid from rinse aid dispenser. This function also stops the regeneration and will not spend salt because salt is already in a tabs. Also extends the washing time because tablets need more time to dissolve in relation to the traditional powder detergent.
Dado
Jul 15, 2014 | AEG Dishwashers
Where is salt compartment on a Hotpoint HDA3600 dishwasher
use the all in one tablets which have the salt already included. no more messing around.
Dec 12, 2013 | Dishwashers
I have just purchased a new Miele dishwasher. I filled the salt reserve as required but whenever the cleaning cycle finishes it reads Add salt! The salt reserve is already full! Please could you...
Hi Carol
You MUST add water into the softener reserve chamber, normally water first then salt.
Dont worry its a common mistake.
Please dont forget to vote this answer was helpful
Many thanks
Feb 13, 2011 | Miele Dishwashers
Hi, I have let my intex above ground pool go green over winter and with summer approaching don't know if I need to add extra salt or something else to get the pool ready for swimming. It is a 14 foot,...
You need to get liquid chlorine and add about 2 liters and let your pool filter run for a couple of days and in the mean time clean your filter twice daily. If the pool at this stage is still a little green add more chlorine and broom the bottom to stir it up. After this as once your pool is back to almost normal, clean the the filter again and add clarifya. To keep your pool in good condion over summer buy 2 pool floaters, put 2 chlorine tablets in one and blue block pool sparkle in the other and each week add 1 liter of chlorine. Hope this helps you as i have the same pool and i do this and don't have any problems. You can also add salt to your pool if you like but dissolve it in water before you add it to the pool.
Oct 25, 2010 | Intex Automatic Salt Water System for ...
My Dishwasher leaves a white film on dishes.
check inlet water quality. If more calcium deposits in the water this could happen. Try using water water softeners.
If provision for dish washer salt check and add salt. ( not kitchen salt )
Finally check whether rinse aid compartment is filled with the liquid. If you are tablet, extra rinse aid not needed. Try all the above.
Aug 17, 2010 | Whirlpool Dishwashers
White film on glasses. Cannot find solution,
Check water quality. clean the drain filter in the machine. Check spray arm spray jet holes. Clean if clogged.
If you suspect salt chamber try removing all the salt by flushing with water externally. Refill with fresh salt.
Jul 08, 2010 | Servis 23 in. M4306 Free-standing...
Hi - i just moved in and have this new bauchnet. I have the 5 in 1 tablets. But do i need to add salt as well in the hole/below apart from the 5-in-1 tablet to set the program?
That all depends on local water supply hardness.
If you have a water supply which leaves a lot of limescale, then you'll need to add supplementary salt, but will be able to dial down the dosage control to a lower setting than you would if you used plain dishwasher tablets.
The appliance handbook will give you a guide as to which settings of the salt control are appropriate for various water hardness levels. You can get the figures for the level of hardness by either using test strips which change colour (available from plumbing supply shops) or by contacting your water supply company.
If you want the really simple "**** it and see" method, then if you use no salt and the dishes are clean then you're good to go. If there are regular dried on food residues then you need additional salt: Fill the salt reservoir, tun the dispensing lever to a high setting, and with every second wash turn it down one click. Once you get to a point where there are stuck on residues you'll know that you've gone a bit too far and will need to turn it back up a click or two.
If it helps, my local supply is one of the hardest water supplies on the planet (literally!) and with plain tablets I have to set the salt dispenser to maximum and reload it frequently, with "x-in1" brands I use about a half less salt.
I hope that my reply has been of use and in return ask only that you rate my answer.
Feb 20, 2010 | Dishwashers
Hello. My dishwasher has been pretty perfect for four years. When my house water softener ran out of salt, I added rinse aid and salt to the dishwasher for the first time. I subsequently added salt to the...
Try cleaning the machine by adding white vinegar to the wash water (before the water-fill procedure finishes). Put your stained dishes and cutlery in with the wash to remove the hard water deposits. The combination of salt and rinse aid may have helped cause this problem. Hope this helps!
Feb 11, 2010 | Dishwashers
Glasses are blasted with grime. We no longer have the manual (apartment came with dishwasher) so don't know how to clean parts, or what parts to clean. Also, not sure what the second trap door is for. ...
Sounds like the glasses have been "crazed" by the detergent used. The detergent is so harsh that it removes the smooth finish on the glass. Unfortunately, there is no way to fix this. The new detergents on the market now days is better and does not do this.
Also, some older machines did not have a "rinse" dispenser so there won't be a separate "trapdoor." You can try some of the new detergents that have the rinse in the detergent, ie Finish.
As you said, it's a very old machine.
Jul 27, 2017 | Dishwashers
Too much salt
Don't know about this model, but if the salt pickup is inline with the water the water may not be flowing in fast enough and the reduced pressure may be letting the salt in. Anyway, final rinse should remove the salt. Try putting two clean glasses (no salt taste) in the unit, one upright and the other down. Run the unit with no soap and stop it after each cycle and check the glasses for salt. If you still have it after each cycle, try filling the unit from the sink manually before the final rinse. If salt's still present, something's leaking
Dec 15, 2006 | Zanussi 24 in. ZSF6120 Free-standing...
Hotpoint 23 in. BFI62 Built-in Dishwasher Logo
111 people viewed this question
Top Hotpoint Dishwashers Experts
AcmeUK
Level 1 Expert
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
