Question about Amptron POLYVIEW 19" Monitor
I need a power cord for a Polyview V293 computer monitor.
    Problem Solver:
  • 15 Answers
Hi, I have a Polyview V293 LCD Monitor with a power supply output of 19v 3.42A. The power supply has failed. Most i have found being offered as direct replacement for this monitor have an output of 19v...
If the power adapter is a separate from the monitor then check the monitor's label on the back of the screen for the power rating.If the rating on the label is greater than 3.16A then I would not purchase this adapter.
I suggest you purchase an adapter with a current rating greater than what is stated on the monitor's label.
Check out this WEB site for power adapters - a 19Volt 90 watt = 4.7A power supply is suitable.
http://www.cheaperoz.com/z/result.jsp?ga=sc1&q=19v+power+adapter
Apr 01, 2011 | Amptron POLYVIEW 19" Monitor
A Polyview V293 monitor suddenly stopped working and fails to show any activity at all. There was no trauma at the time. Is this likely to be able to be repaired? Bruce Jones, Australia
Well, common failure in the LCD monitor after a couple years are due to failed DC filter caps in the power supply as you can see in my albums.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Oct 20, 2010 | Amptron POLYVIEW 19" Monitor
Trying to find a video device driver for an Amptron Polyview V293
try this link below to download the driver
http://www.driverstart.com/start592730.html
Aug 10, 2010 | Amptron POLYVIEW 19" Monitor
Polyview V17E monitor looses power at irregular times
Check your power saver settings
Start - Control Panel - Power
May 08, 2010 | Polyview V17E 17" LCD Flat Panel Monitor
Wont turn on, nothing.... Power supply is good
Replace the power-cord.
Wait until midnight, and turn out all the lights in the room, so that's dark in your computer room.
Turn on the monitor, and see if you get any light and/or any lamps (green? yellow? red?)
Try a different monitor attached to your computer.
Try your monitor on a different computer.
Sep 10, 2009 | Polyview PT-525A Monitor
Need a power cord for a Polyview PT-725A
I found this power cord thru Ebay:
http://cgi.ebay.com/AC-Power-Supply-Cord-PolyView-PT-725A-17%22-LCD-Monitor_W0QQitemZ350234908070QQcmdZViewItemQQimsxZ20090802?IMSfp=TL090802135003r13298
Runs about $30.00. You might be able to find a cheaper one thru searching but at least you know that they are out there.
Aug 29, 2009 | Polyview PT-525A Monitor
Monitor Display Problem.
The first Polyview has a power supply problem (a short) and locks out the power until it is unplugged. You need to check the voltages inside the Monitor to determine which component/s are faulty. I hope you know electronics if not leave it to the repair shop because you have neither the skills or equipment to repair it. By the way I am not a monitor repair man but I do have 30 plus years in the electronics field.
The second monitor may have a broken wire in the cord that goes to your computer. Other internal components can cause the same simptoms your seeing. Good luck!
Mar 28, 2008 | Polyview V17E 17" LCD Flat Panel Monitor
No sound
if your monitor has speakers, and it should  built in; then you will see a separate lead with  green plug on the end of it which is to be located in the rear of your pc with the green marked socket.
If theres no lead, then there must be a connector on the rear of the monitor
Oct 22, 2007 | Polyview V17E 17" LCD Flat Panel Monitor
Amptron POLYVIEW 19" Monitor Logo
109 people viewed this question
Top Amptron Computers & Internet Experts
David Payne
David Payne
Are you an Amptron Computer and Internet Expert? Answer questions, earn points and help others
