Question about Apple MacBook Air
Error What does hardware error code 4HDD/11/40000004: internal mean?
    Problem Solver:
  • 8 Answers
That error code means your HDD is dead..
It may be corrupt; it's unusable.
You will need a new SATA HDD.
Source: Google and my experience with that error in my Macbook Pro. var fctb_tool=null; function FCTB_Init_c051884345bf42a4a9c154223e7d2f63(t) { fctb_tool=t; start(fctb_tool); } FCTB_Init_c051884345bf42a4a9c154223e7d2f63(document['FCTB_Init_6e224391880b406abfb85fe687432776']); delete document['FCTB_Init_6e224391880b406abfb85fe687432776']
Posted on Nov 27, 2010
I have the same error but, mac os x wont boot but windows and linux working good very good
Posted on Dec 09, 2011
  • Robotik Dec 09, 2011
    Try to install other os it will work, i know it's **** that os x wont boot but hey it's better than nothing.
    P.s
    By the way you can install os x but after few
    Start ups it drop death as before.
Ny macbook air is fully chrged, but it doesnt want to boot..HELP
Posted on Aug 07, 2010
    Problem Solver:
  • 19 Answers
Did you disconnect all your external devices before running the AHT?
Note: Please be sure to disconnect any external devices, printers, hard drives, scanners, and so on (other than the Apple keyboard and mouse) from your Apple Computer before starting up to Apple Hardware test and running the Diagnostic.
http://support.apple.com/kb/HT1509
Posted on Jul 09, 2010
2 Suggested Answers
Macs R We
  • 481 Answers
SOURCE: my macbook air hardware test shows error code
The meaning of Apple Hardware Test results is Apple proprietary.
That having been said, it appears that AHT is reporting a problem with a hardware component associated with your hard drive (the drive itself, a drive temperature sensor, or something else). An Apple Authorized Service Facility will be able to give you more information.
Posted on Jul 14, 2010
54.2 code what does that mean?
Description
The device has experienced an internal hardware error.
Recommended Action
Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.
Mar 16, 2014 | HP LaserJet 2840 All-In-One Printer
Tip
XBox360 error codes (Three Red Lights of Death, Red Ring of Death, X-Clamp)
Hi.
XBox 360 error codes are displayed with flashing lights in the ring of bi-color LEDs located around the start button, like in the picture below:
They are often called lights of death. The technical name from Microsoft is Light codes.
LEDs located around the start button can be green or red. When they get red it means that there is a problem.
When the XBox is operating normally The leds will be green. The number of green segments indicates the number of controllers connected to the Xbox.
Here a working Xbox with one and four controllers connected to the console:
If the lights are red instead of green, then there is a problem. Here the four common error codes:
A: The code in picture A, with only one red segment on and flashing on the fourth quadrant, means that there had been an hardware failure. The internal component failing is often not specified.
The light code is accompained by an error message on display, telling a numeric code that can better address the cause of the fault. The best thing to do is contacting Microsoft to find out the reason for the code. Depending on the code you may also be asked to perform a secondary error code retrieval procedure.
In the Example above E74 means that there is an hardware fault on video connections or GPU.
B: If the first and fourth quadrant LEDs are on, that means that there had been overheating. Internal fans, CPU and board must be tested.
C: General hardware failure. This means that the console detected an internal failure, but no error code is displayed on screen. Call Microsoft to get instructions on detecting secondary code or sending the console for repair.This error code is commonly called Three Lights of Death.
D: The last error means that there is a problem with the AV connection to the monitor or TV. The code is not displayed if you use HDMI connection, in that case you get an on-screen error code. Test using different cables. If that does not fix the problem, this error means that the XBox Gpu is fried. This error code is commonly called Red Ring of Death or RROD.
In the near future I plan to publish a new article explaining how to troubleshoot secondary error codes. In the meanwhile, if you need more support, you can ask a question to our experts or contact Microsoft.
Regards.
on Apr 08, 2010 | Microsoft Xbox 360 Console
Error code 5030
What that means is that there is an internal hardware failure in this printer and it's actually gonna require a service. It's actually an internal hardware failure that's going on within the printer. You would have to contact the Canon tech support USA and they will be able to give you further guidance on what to do.
Jan 04, 2014 | Canon PIXMA MG8220 - Multifunction ...
Engine scanner error (internal hardware laser scanner error) error message laser scanner
This means that the laser unit inside your printer has failed. It costs around 100 dollars for the part and it needs to be installed by a trained technician. Best idea is to buy another printer. Sorry.
Sep 29, 2013 | HP Laserjet P1505 Printer, Remanufactured,...
Webcam does not launch , lexmark x422 driver exclamatry mark show , means driver fail , how to solve this problem , i want to get picture , and use skype video calling
HI
A Code 10 error is generated when Device Manager can't start the hardwaredevice, a situation usually caused by outdated or corrupted driver A device mayalso receive a Code 10error if a driver generates an error that Device Managerdoesn't understand. In other words, a Code 10 error can sometimes be a verygeneric message indicating some kind of unspecified driver or hardware problem.Uninstalling and then reinstalling the drivers for the device is a likelysolution to a Code 10 error. If reinstalling driver is not working than try torollback the driver or restore the system on previous date..
regards
sandy fixya
Jul 21, 2011 | Lexmark International Lexmark X422
I have an error code 80028F08
that error indicating to you that there is an issue with the internal I/O hardware of the system. Meaning its either a stuck game, frozen switch. Fillout a form and wait for a newsystem to arrive from sony while your is examine or thrown away
Mar 12, 2011 | Sony Playstation 3 (PS3) Console
My macbook air hardware test shows error code 4HDD/11/40000004: internal. What does that mean and how do i resolve the problem?
Jul 06, 2010 | Apple MacBook Air Mac Notebook
Our Konica 8031 Printer has given us a code of C 1265, and will not print. Could you please let me what this error means, and also what needs to be done to fix it... Thank You.
This seems to be related to an internal hardware problem. Try reseating the memory DIMMS and other visible internal connectors and try again.
This most likely requires service from a qualified technician.
Good Luck!
Feb 05, 2010 | Konica Minolta Office Equipment & Supplies
C5180 All-in-One
HP doesn't list that specific error code, however www. dumpanalysis.org had a crash dump analysis listing that or a similar code. That means your printer has an internal error state. Check with the HP articles for error codes. You should try shutting it off for two minutes then rebooting to see if you can get it back online. 0xC2FF, & 0x0000C2FF are UTF 16 & 32 bit Hex codes indicating a memory overflow error (from what I could judge). If you are fortunate it will not be a permenant condition from hardware failure, otherwise your printer may need servicing.
Mar 26, 2008 | HP Photosmart C5180 All-In-One InkJet...
Apple MacBook Air Logo
1,563 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
