Question about GE J Series 18.2 cu. ft. Top Freezer No-Frost Refrigerator TBX18AABWW
Freezer works refrigerator does not get cold not sure of the model not home right now am at work
  • 4,070 Answers
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Posted on Jul 06, 2010
I have a model MTB1956GE Maytag Fridge, Frezzer
Can you feel air moving or hear the fan running in the freezer section? You said the freezer section is freezing well, but is it freezing really hard?
Regards,Richard
Dec 12, 2011 | Maytag MTB2156GES Top Freezer Refrigerator
I have an Amana refrigerator with bottom freezer. We just moved in to the home and landlord is out of town. The freezer is cold and I can see frost blowing but nothing is freezing. The food we put in there...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 10, 2011 | Microwave Ovens
Hi, Have model E522B fridge, freezer cold but fridge even on lowest setting is only just getting cold. Can I fix it myself? Thanks for your help
The only thing a home owner can do to fix this is to make sure ALL the coils under and behind you fridge are clean. If that dose not work I would very strongly suggest calling a repairmen before you attempt to fix.
May 02, 2011 | Fisher and Paykel Active Smart E522B...
I have an Amana side by side refrigerator. Last night I noticed water running from underneath and the ice cream in the freezer melting. I found dog hair clogging a vent and cleaned it. This morning the...
usually when the bottomof the freezer is cold and the top isn't it's the evap fan motor isn't working and all the cold air sits at the bottom.when you open the freezer door you should hear the fan running inside the freezer,also tried to look up your model but it didn't come up.open the fridge door,look up on the right and hear the cieling and you'll see a tag with the model and serial numbers,i just need the model number and i can help you better
Jan 30, 2011 | Amana ARSE66MB Side by Side Refrigerator
I just got a G E refrigerator from home depot model # gbscohcxarww. And the freeZer on the bottom works but the ref rig on top doesn't get cold
set dials to middle setting, max cold makes cold freezer, not reefer box!! if freezer makes ice its ok just set to cold which starves reefer box of air. add 2-3 gallons of water to the freezer and or reefer box, if empty it wont cool much.
Nov 01, 2010 | GE Refrigerators
Freezer gets cold but rerfrigerator does not on my side by side model TFX20JEX
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Oct 25, 2010 | GE Refrigerators
Temp in refridgerator is 40 degrees on bottom shelf with temp gage turned to coldest setting. Is this right?
the normal temperature for a refrigerator is 35-40 degrees F, so 40 at full cold setting is not correct.
If this is a side-by-side or top-freezer, make sure that the air vents between freezer and fridge are not blocked by food items or ice.
Make sure defroster operation is working normally as ice will block airflow.
Also, there is a circulating fan in most models that moves cold air from freezer to fridge. make sure that's working.
Oct 21, 2009 | Refrigerators
Refrigerator is not getting COLD
clean the coils on the back of the fridge and make sure the condenser fan is free and running normally. that is the fan at the back of the unit on the bottom where the compressor is. if it cant ge rid of the heat, it wont cool. also make sure the the fan that supplys the cold from the freezer to the fridge is working.
Jul 21, 2009 | GE Monogram ZISS480NRSS 48" Built-In...
Frezzer and refrigerator work sometimes
  1. check rear wall of freezer for ice build up, if so unit is not defrosting
  2. check to see if fan is running in freezer
  3. check to see if compressor is running
Nov 23, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
431 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
