Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
My access Master 350 will not open or close when using remotes
My access Master 350 will not open or close with either remote (I have two). I have two doors, one works fine but the other one will not open or close with the remotes. It opens and closes with the button on the house.
    President:
  • 3,197 Answers
If the light in the wall control is flashing your opener is in the lock/vacation mode. Press and hold the button with the lock icon for 3 seconds. If this is not the case your logic board is bad.
Posted on Jul 06, 2010
Lift master remote model 893lm won't open or close door
There should be a button on the back of the opener itself. If you push it the opener should flash on and off or make a click sound a few times. After that click which ever button you want the door to be opened with on the remote
Jan 21, 2018 | Cars & Trucks
How to access video input w/o remote for rca colortrak plus tv
usually it is not possible in as much the manufacturer did not provide buttons that can be use on the device, you can try using a master remote which is to be programed to work for your device, ask for a master remote and make sure your device is listed among the devices that the master remote can operate.
Apr 04, 2013 | Televison & Video
I have to "Access master" remote controls to open
Depends on the model. Some have a small screw on the back, some have a small 'door' that slides open and some have a small slot on the bottom that you use a screwdriver or the sun visor clip to insert and twist. Yes they do have a battery.
Nov 09, 2011 | Sears Craftsman LiftMaster Chamberlain...
It appears it just went dead. Replaced batterys. Lite does not even work
The remote you have is an expensive item to replace so lets try checking a few things first. Open the battery compartment and closely look at the contacts, there should be one at the top and bottom of each battery. If the remote was not used for a long period of time with the batteries still in the remote, then some corrosion may have built up preventing good battery connections... clean the contacts if you suspect this. Hope this works for you.
Feb 28, 2011 | Universal Remote Control MX-350 LCD Remote...
My lift-master garage opener works just fine from wall button, but will only open but not close from any remotes (from car or original remotes) If I open it with remote and immediately close with wall...
We have the same model and similar difficulties. We were told it's a bad antena. Not sure if there is anything we can do about this. Sometimes it works with the remotes, sometimes not. Always works with the wall switch, because that's wired.
Nov 12, 2010 | liftmaster Chamberlain Garage Door Opener...
I have a Lift-Master Security remote garage door opener. It has a new battery. Can it be reprogrammed or do I have to replace the remote?\r\nThank you for your assistance. Model number971LM. It will...
ANY TIME YOU CHANGE THE BATTERY IN A REMOTE IT NEEDS TO BE REPROGRAMED.
ON THE CIRCUIT BOARD YOU WILL FINS A SQUARE BUTTON.
PRESS AND RELEASE NOW HOLD DOWN THE BUTTON ON THE REMOTE FOR ABOUT 20 SECONDS. WHEN YOU PRESS THE REMOTE THE NEXT TIME THE DOOR SHOULD OPEN.
Oct 21, 2010 | Sears Craftsman LiftMaster Chamberlain...
Door lock problem ..can open but can't lock
If it's only the drive's side door that's doing it, it's for safety purposes so you don't lock your keys in the car. close the door and use your remote to lock or your keys if you don't have your remote. If you already knew this then the lock switch may be faulty.
May 10, 2010 | 2004 Honda Accord
Lift-master 2000SDR remotes will open but not close garage door. Same problem with all clickers and even those programmed into the cars. What could this be and better yet, how do I fix it?
Lift-Master 2000SDR opener. Opener generally works fine from the remotes. However, first time in the morning in cooler weather, it will start to close and the reverse and the lights blink. I have checked the senors - appear to be aligned properly. I have lubed the gear and used garage door spray on the rollers and hinges at the proper places. To close the door when this happens, I have to hold the wall button.
Nov 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage Master 1/3 HP 1997 Door Working, not responding to Remote
I have the exact same situation, except my model (139.53607) is older than yours and does not even have an LED. Remotes only works after after shop light goes off (5 minutes or so), but wall button works fine. Did call Sears Service and the tech told me the logic board is probably shot. Don't want to waste money on service call so I'll probably have to buy a completely new unit in the Spring and go through the winter without the use of a remote.
Jan 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
367 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
