Question about Apple iBook G4 Mac Notebook
G4 iBook screen fades to black on start-up
My G4 iBook screen goes dark shortly after I power-up. It's like an invisible finger hits the F1 key - I can actually see the "bars" reducing. If I hit the F2 key, the screen goes bright for a second or two and then fades again.
It's almost as if the F1 key is stuck. I have lifted the keyboard, cleaned the recess and checked for any obstructions.
Taking the battery out and rebooting a couple of times, as well leaving the two keyboard locks unclipped, solves the problem and thereafter the G4 is fine.
What could be causing this and how easy would it be to fix it?
The machine is a 2005 model but I'm not keen on replacing it just yet.
Thanks,
Paul
    Scholar:
  • 65 Answers
It sounds like that key is sticking.
You might want to look on eBay for a replacement keyboard. I'm not sure how difficult it would be to unplug the old keyboard and plug in the new. Opening the iBooks is a challenge, but maybe the keyboard can be plugged in through the hole in the top. Not sure.
Please rate me if this helps.
Bot
Posted on Jul 06, 2010
My ibook g4 won't power up but the power cord works,do i need a new battery?
I found this page at apple support about your problem, it seems to have helped a lot for many people. Apple Support
Mar 28, 2012 | Apple iBook 12 iBook G4 1.33GHz,...
My G4 iBook screen goes dark shortly after I power-up, even If I hit the F2 key, the screen remains dark.
Got the same problem with my ibook G4.
I have research on how to fix it, and found out that most model of G4 has the same problem.
I soon found out the main problem and the solution, it would require some skill in soldering and dis assembling the whole laptop.
Go to this site and hope it will help you just it like it helps me a lot!
http://macintoshhowto.com/hardware/how-do-i-get-my-broken-g4-ibook-fixed.html
Thanks for using Fixya!
Dec 14, 2010 | Apple iBook G4 Mac Notebook
My iBook G4 will not turn on though it has a full battery & is connected to a plug socket also..
There are several models of iBook G4. The following sequence applies to the "14-inch Early 2004."
Remove all peripheral cables. Remove the battery. Reset the power manager by pressing the key combination Control-Option-Shift-
power. Then plug the iBook into AC power and attempt to start it with the power key.
If this procedure does not being it back, invasive diagnostics are required, in which case you should being it to an Apple-Certified tech for repair.
Jan 21, 2010 | Apple iBook G4 Mac Notebook
Ibook display problem
You can reset the pmu this might help to stable the display,this is only used as a last resort and not a possible solution.
  1. If the computer is on, turn it off.
  2. Reset the power manager by simultaneously pressing and then releasing Shift-Control-Option-Power on the keyboard. Do not press the fn (Function) key while using this combination of keystrokes.
  3. Wait 5 seconds.
  4. Press the Power button to restart the iBook computer.
Oct 07, 2009 | Apple iBook G4 Mac Notebook
Apple ibook crashed when on MS Word. Black screen fan running???
Sounds like you have a problem with the logic board. This appears to be a common problem with iBook G4 related to the fit of the logic board (ie motherboard) within the case.If you were to take it to apple store the likely fix would be to replace the entire logic board which is very expensive and probably not fiscally sound on a 5 year old machine. Another option would be to try to fix it yourself. If you are feeling brave you can dissemble the laptop and attempt to shimmy the logic board back into position.
Here's a link that detail the approach. http://www.coreyarnold.org/ibook/. This guy had success on two ibooks that had the same problem and they have been working for 2 years since he did his repair
Also, here is a link to a forum that may offer you a few more approaches to solving your problem. iBook G4 won't boot up - fan running & black screen - AppleNova Forums
Hope this helps, good luck!
Mar 30, 2009 | Apple iBook G4 14-INCH Series M7701LL/A...
Ibook G 4/12.1/1.33/5aptx.....will not start
Some computer react this way when the logic board goes bad or have a defect in it.
First, Try this:
Remove the battery.  Plug back in the power cord, then press and hold down the power button til you hear a loud beep sound. then release it.  If the computer starts back up... Then you should be okay.
If not, it may has something to do with the logic board.
Let me know if the above works... We may can try some other things if not.
~ enov8
Jan 07, 2009 | Apple iBook G4 Mac Notebook
When i turn on my mac ibook g4 the screen gets light then suddenly goes dark and seems to boot up but the screen is black but i can faintly see the desktop icons. What should it do?? thanks
your backligny is probably off. try "increaseing the brightness" on your screen. on macs that should probably be one of the F-keys at the top of your keyboard. I think brighter is F2 or Fn + F2 or somethinglike that. just find the symbol. Do this while your laptop is plugged in to make sure it's not just dimming you screen to save battery.
Dec 29, 2008 | Apple iBook G3 Mac Notebook
Ibook screen issues
This is nearly impossible to diagnose via the Web. It sounds like the logic board is at fault, but not necessarily.
Nov 23, 2008 | Apple iBook G4 Mac Notebook
Ibook G4 14" 1.4mhz
On an Apple system, this is an indication that it thinks there is little or no battery left and goes to sleep to protect data loss. Your battery might be going bad (showing a full charge, but lasting for only a few minutes) or there may be a problem with your power supply.
Nov 13, 2007 | Apple PowerBook G4 Mac Notebook
Apple iBook G4 Mac Notebook Logo
171 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
