Question about Sharp Aquos LC-46D62U 46 in. LCD HDTV
Screws for Table Stand
I just bought a 47 inch Sharp Aquos and the 4 screws that bolt the TV to the Table Stand are missing where can I get them and what are the specs (length, size etc)
2 Suggested Answers
  • 362 Answers
SOURCE: Sharp Aquos 47 inch tv.
these are pretty common screws if you still have the box and everything it came wtih new then it perhaps may have the screw sizes included with it in there if not then go to a local fastener store as home depot sells them in large packages for even more money by going to the fastener store you can get multiple sizes in one shot try till you succeed and get more of the ones that fit while you return the rest i hope this helps and they are usually about an inch in 3\4 of an inch in length
Posted on Nov 19, 2010
I lost the 4 short screws for my sharp aquos tv stand model lc 52d62u.i need to know the exact size to replace them.
Google is your friend
This is very late (4 years) but may help someone some day. For my Sharp LC52D64U stand:
Arm to base: 4 - M6 x 35mm
TV to arm: 4 - M5 x 16mm
BTW: base model CDAI-A418WJ36 fits just as well as the original CDAI-A376WJ32 and is usually cheaper on ebay.
http://www.avsforum.com/forum/28-tweaks-do-yourself/1004261-missing-sharp-aquos-screws-help.html
Jun 21, 2016 | Sharp Televison & Video
Cannot remove stand from sharp aquos 52 inch lcd tv
there are 4 screws on the back of the TV just above the stand that have to be removed before the stand can be separated from the TV
Jan 26, 2012 | Sharp Aquos Televison & Video
I would like to remove the stand on my 47 inch sharp aquos tv but can only remove the lower part and its left the piece connected to the tv
Normally there are 4 - 6 screws holding the base to the back of the tv which you access from the back of the set.
If you tried to remove the base by unscrewing the screws from the bottom then you may be left with the riser still attached to the back.
It's always best to look in your USER'S MANUAL for the proper method to remove the base from your particular tv.
Since you did not provide the model number I cannot give you a direct link to it, but if you go to the SHARP SUPPORT website and enter your model number you should be able to downoad a copy of your user's manual.
http://www.sharp.ca/manuals/default2.asp
Good luck and please comment back if this was helpful.
Feb 04, 2011 | Televison & Video
Sharp Aquos 47 inch tv. Just moved and can't find the 4 screws to the stand, where can I buy new screws or get the specs if I were to buy new ones at Home Depot? Thx
Nov 19, 2010 | Sharp LC52SB55U LCD TV
Missing LCD Stand Screws for Sharp Aquous 46" LC-46D62U
am not sure on size service manual doesnt say but there 2 1/2 long.
Jul 15, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
I can not remove the stand from my sony aquos tv.
With the 4 long screws removed, it should come out.
Here's where you can download the manual for the LC-46D62U.
http://www.sharpusa.com/files/tel_man_LC46_52D62U.pdf
It has the instructions you need for the stand.
Jun 02, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
I can not remove the stand from my aquos 46 inch tv.
you will find 4 screws at the back of the tv about 4" inches from the bottom. lay the tv set flat on your bed. you will need a metric allen wrench to remove the 4 screw. once the 4 screws are removed slide the base away from the tv.
Jan 18, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Can not remove the stand to mount it on the wall
If the Aquos 46 is anything like the Aquos 42, the monitor is attached to the base with machine screws (bolts). They are located in the lower back portion of the monitor, probably need an Allen wrench to loosen and remove. Once that is done, the base can be removed from the monitor. Best way is to lay the monitor face down on a tabletop padded with foam, a quilt or blanket, etc to protect the screen as you work. Remove the stand from the monitor, not the monitor from the stand; it is easier and safer that way.
Mounting to TV Stand
there are two types of stands, some are wall type which needs to be mounted using rawl bolts, nuts are suppose to hold a stand, some are ground stands which are suppose to be put on a flat surface in order to balance.
Jul 29, 2008 | Panasonic TH-50PZ77U 50" Class Plasma HDTV
Sharp Aquos LC-46D62U 46 in. LCD HDTV Logo
328 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
