Question about HP ZD7168CL Notebook
TURNED COMPUTER ON, IT WOULD NOT BOOT UP, I GET THIS ERROR MESSAGE: "PXE-E61 MEDIA TEST FAILURE, PXE-MOF: EXITING PXE ROM" CONNECT CABLE....WHAT CABLE? THIS IS IN REFERENCE TO FAST ETHERNET CONTROLLER REALTEK RTL 8139, 8130/810 X PCI. CAN THIS BE FIXED AND IS IT WORTH IT. I HAVE ALREADY INVESTED MONEY, REPLACING BATTERY, MEMORY, LARGER HARD DRIVE.
4 Suggested Answers
leecom72
  • 4806 Answers
SOURCE: After the initial BIOS checkup, this error came
Hi there.
the laptop is trying to boot from the LAN (ethernet port)
Go into the bios and set the first boot device to the HDD, save the changes and exit, the PC will restart and boot from the hard drive.
Good luck and thanks for using Fixya!!!
Posted on Feb 24, 2009
  • 108 Answers
SOURCE: my notebook stop booting up it is saying.
Reset bios to default settings and if you want to reinstall your operating system set first boot menu option to cd rom or drive whatever you want to boot from.check if your hard disk ide or sata if not sata then disable sata at bios then save and exit bios.and start your installation
Posted on Aug 20, 2009
parrotheadpc
  • 2600 Answers
SOURCE: Computer does not boot up
Sounds like the computer cannot find your hard drive and is looking for other means to boot the machine. It first is looking for a network hard drive, then it is looking at the DVD. When that fails it is asking you to check the computer for hardware errors. Check to make sure the hard drive is seated in it's compartment. The DV6000 has an adapter that fits on the end of its SATA drive and sometimes that adapter can wiggle loose from the contacts. Just take the hard drive out and then re-seat it to the connector. In most cases it is either a loose connection or the hard drive has suffered a failure.
Posted on May 19, 2010
Disk boot problems
Insert your OS disc to repair the damaged boot sector and then replace the hdd as that could be the cause.
Sep 11, 2014 | Computers & Internet
Hello, My laptop shows the following message when I turn it on- Realtek PCIe FE Family controller Series v1.19(08/10/09) PXE-EGI-Media test failure,check cable PXE-MOF-Exiting PXE ROM Reboot an
It can't locate a working boot disc. Most likely lost communications with hard drive. Look in BIOS again to see it recognizes the drive. If not try re-seating / reconnecting drive.
Feb 16, 2013 | Dell Inspiron N5010 Black
R780 pxe-e61 media test failure
It is not recognizing the hard drive, Open it up reseat it. Then check BIOS by pressing F key noted on startup. It must be noted there in order for it to boot correctly.
Jan 19, 2013 | Samsung R780 Red Intel I5-460m...
Laptop won't start up
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Aug 12, 2012 | Toshiba Computers & Internet
PXE-E61 Media test fail, PXE-MOF Exiting Broadcom PXE ROM
Disable PXE in the Boot Sequence in the BIOS setup [F2]
Aug 10, 2012 | Dell Computers & Internet
Toshiba satellite L455D-S5976 PXE-E61 media test failure...brand new hard drive What do I do???
You need to boot from an installation CD for the operating system, or the Toshiba restore set. New hard drives are completely blank when you purchase them. The computer is looking for something to boot from and cant find it, so it trys to boot from ethernet. Check your bios set up for boot order and boot devices. You might try disabling boot from network.
Hope this helps
May 04, 2012 | Toshiba Satellite L455D-S5976 Notebook
PXE-E61 : media test failure, check For Realtek RTL8101E/8102E PCI-E Ethernet Controller v1.06 (080222) PXE-E61: Media test failure, check cable PXE-M0F: Exiting PXE ROM.
The system is not finding any bootable media (Hard Drive) and is attempting to boot via the network card (PXE Boot) the error message is saying that there is not PXE network to boot from and it is exiting the process.
Generally, this is caused by a hard Drive failure. Reseat the drive and or drive connections and see if the system will find the hard drive.
Generally, a Hard drive failure
Jun 17, 2011 | Computers & Internet
When i start my lapt top i get black screen that reads intel undi,pxe-2.1 (build 082) for real tek rtl8101e/8102e pci-e enthernet controller v1.07 (080320)pxe-e61 media test failure,check cable pxe-mof...
If the sound you are referring to is a clicking sound, then it is a hard drive failure.
Your computer is trying to boot up the operating system from the hard drive, but when it fails to access the hard drive, it tries to boot up from other devices configured on the BIOS. Apparently, your next choice for booting the operating system is set to the LAN card. Hence, you get the message "PXE-E61 Media test failure", which means that the computer tried to boot up the operating system over the network but it found out that your network cable is not connected to your computer's network interface card.
Dec 07, 2010 | Toshiba Satellite Laptop
Sony vaio pcg-fxa36 will not boot get error realtek RTL8139(A/B/C
ok, what is happening is the laptop is trying to boot from the ethernet port, what you have to do is go into the bios (this is usually F2 on boot) and change the boot order to hard drive, save settings and exit the bois screen, the pc should now boot to windows
kind regards and please don't forget to rate us
Dec 03, 2008 | Sony VAIO FXA36 Notebook
Error Message: PXE-E61 Media Test Failure Check Cable
Not always the Hard drive, boot into the bios setup utility and de-select network bootfrom the boot options. If it tries to network boot first you will always get that failure.
Apr 12, 2008 | Compaq Armada E500 Notebook
HP ZD7168CL Notebook Logo
146 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
