Question about Sharp AL-1655CS Copier
Sharps AL 1655cs have error L-3 and can not fix this? No manual Call 800 537 7464 or 321 951 0407 to help us. Carl Ring Melbourne FL. 329\04
    President:
  • 2,072 Answers
L# means there is a scanner error. Most likely the scanner is not returning to the home position in time.
First do the obvious and see if the lamp itself is coming on.
Then remove the glass, and it is very common for that silver shaft toward the back of the scanner that the carriage drives on to become dirty and sticky.
Clean that shaft with alcohol or windex a few times. Then lubricate it with a light oil and slide it back and forth.
I would also look on the underside of the scanner. There is a latch, a scanner lock under there. See if it is in the locked position. If so, take a screwdriver and just pop it out and throw it away. It is only used for initial shipping. It isnt needed once the machine is in place.
I am 90 percent sure that either cleaning that rail or removing the scan latch will resolve your problem.
Posted on Jul 09, 2010
My boss has a Sharp AL-1655CS Copy Machine and it makes this awful, screatching noise when I try to copy anything. Now the System Error Code L1-00 shows up. Not sure what to do.
Your problem on scanner unite.May be your copier is now lock position.
Solve:Unlock position.Left side under copy Board.Then solve your problem.Or study your copier user manual.
Jan 12, 2010 | Sharp AL-1655CS Copier
Error code E7-11
CCD drive circuit (CCD PWB, ASIC harness) trouble
Copy lamp lighting trouble (Copy lamp, inverter PWB)
OR the scanner shaft is dirty. Clean it and re-oil it with 3n1 oil.
Jul 17, 2009 | Sharp AL-1655CS Copier
My Sharp Al-1655CS Display is frozen say: system error (H4-00)
Just press the following keystrokes:
# * C * (That's pound, star, C, star) This will clear the display error, now press…14, then press the green button twice. This should let your printer start to warm up and you have fixed your problem.
Thank you!
Sabharish
Jun 19, 2009 | Sharp AL-1655CS Copier
System error L1-00 Sharp AL 1655cs
hi maryanne,delete all the sharp AL 1655cs programme and reinstall the printer software (INSTALL PRINTER) if need more help please log on to sharp copier web site for the manual instruction..before that make sure your printer is compatible for your PC.
Dec 08, 2008 | Sharp AL-1655CS Copier
MESSAGE: SYSTEM ERROR (H4-00) REFER TU USER GUIDE
We had this problem when the power was fluctuating in our building. I called Sharp and they told me to clear this condition with the following code: #*C* and when the screen shows 00-00 enter 14 and press the green copy buton. This worked on the AL-1655CS. On the AL-1631 we had to do a similar thing: C<auto>C<auto> 14 <copy>
Jun 06, 2008 | Sharp AL-1655CS Laser Printer
Sharp AL-1655CS ERROR MESSAGE
The [H4-00] system error popped up when the power went out of the house. I called Sharp Tech Support (1-630-378-3590) and was talking to their Tech Support in less than a minute.
The FIX? Just press the following keystrokes:
Mar 17, 2008 | Sharp AL-1655CS Copier
Sharp AL-1655CS Laser Printer stays in download Mode
you can´t. the only way to fix that is replace to main pwb. i have 3 whit the same problem.
Jan 08, 2008 | Sharp AL-1655CS Laser Printer
Sharp AL-1655CS Copier Logo
64 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
