Question about Rokinon 6501300mm f80160 for Sony Alpha
Adapter ring make camera read no lens deteched
I have a sony alpha af adapter ring with lens only makes camera read no lens detech
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Rokinon Master
  • 102,366 Answers
The 650-1300mm lens lacks the electronics to communicate with the camera. You'll have to focus manually, and set the camera's exposure mode to Manual.
Posted on Jul 06, 2010
How can I stop the metering on a Sony a77 Camera?
When you are using non brand lenses, with an adapter ring, most camera's can't communicate, so you have to use the lens as a non chip lens and it only will work in full manual mode. So switch the camera to M (manual) and then do manual focus and manual aperture on the lens. When you shoot a picture, look on the histogram if you need a faster or slower shutter speed and dial in the speed (manual) you think is correct.
Jan 12, 2015 | Sony a77II Alpha 77 Mark II Translucent...
I have a nikon mount AF 70-300 quantaray lens that I am trying to find a mount so that it can fit onto my sony alpha DSLR camera. Does this exist? Will a simple T mount fix my problem?
A simple T mount adapter will NOT work, since your lens doesn't have a T-mount.
If your lens has an aperture ring then something like this will work.
You'll see more information here.
May 23, 2012 | Sony Cameras
Is the Sigma Telephoto 400mm f/5.6 APO AF lens compatible with the Sony alpha camera?
Sigma makes their lenses with a variety of mounts. A lens with a Canon mount, for example, will not fit onto a Sony camera. Assuming you get the Sigma lens with a Sony mount then yes, it will be compatible with the Sony alpha.
Jan 14, 2011 | Sigma Telephoto 400mm f/5.6 APO HSM Macro...
Lens
The Sony ALpha camera actually use a Konica/ Minolta lens mount. a 500 or 1000mm lens won't have any really mechanical connection to make, so if you can find the lens with a Minolta mount , it should fit. BTW- most of those long lenses require a T mount adapter to fit on ANY camera-
May 15, 2010 | Quantaray 500-1000mm Lens
I am using a Tamron AF 18 - 250 mm lens on a nikon d90 and some times on auto focus F---- is displayed and i cannot take a photo. Is this something to do with the match of lens to camera ?
Make sure the lens is set for the largest f number on the aperture ring. there may be a lock to prevent the ring from turning in the future. Locking the lens of the largest f number allow the camera to set the lens through the camera. This is normal on most of the newer cameras.
If the lens does not have a move-able aperture ring, then dismount and remount the lens, making sure the lens is completely mounted and locks into place, completely lining up the contacts inside. If this does not work The camera or lens may need servicing.
Nov 22, 2009 | Tamron 18-250mm F/3.5-6.3 AF Di-II LD...
Lens ? Are the lens' from my old reliable sony f828 compatible with the sony alpha 300 I am thinking of ordering? Is there a fix if not?
You can try going to the camera store, and finding an adapter ring for it I've got an alpha 100 and can use konica/maxxuum lenses, and with an adapter I can also use Pentax screw mount.I wouldn't have bought the sony a100 unless it would take my other lenses too. Take the old lens and the a300 in to try out for a good fit.
Jul 27, 2008 | Sony Cameras
Sony Digital SLR
You should have no problem, if they are maxuum af. The others should work too- I have an Alpha 100. The alpha 100 works great. I used to run my own photography business, and searched around for quite a while before I found the alpha. There is an adapter ring that i bought, that makes it possible for me to use my favorite old pentax screw mount 135mm f1.6, or any other screw mount, on my alpha 100.
The only drawback I found was you cannot use any other flash(at this time) than the onboard one-or the sony only flashes-which are a little pricey. Different size hot shoe is the reason. I haven't found an adapter yet-but I'm sure someone will make one. The alpha doen't have a real time display- or asa of 3200. I'm hopeing for a firmware update/upgrade to correct this. BUT the newer models with a higher than a100 number do have realtime lcd, and do go to asa3200. And they use either sony mem.stick or CF cards happy shooting
Jun 23, 2008 | Cameras
Sony A100 compatibility
It would help if you actually gave details of the lens!
All the old Minolta AF and MF lenses will fit the Sony A100, but only the AF are auto-focus compatible.
Since the Maxxum 7000 was an AF camera, I would image that that is an AF lens pictured on the front.
Check out this site for more details:
http://www.mhohner.de/sony-minolta/lenses.php
Matt
Feb 29, 2008 | Sony Alpha DSLR-A100 Digital Camera
QUANTARAY FOR MINOLTA AF 70-300MM compatibility
Usually mounts are unique to a camera manufacturer. There are exceptions. Sony has the Alpha; lenses for the Konica-Minolta are the same mount. Your AF (autofocus) lens will work on it. You might also consider picking up a Konica Minolta 5D or 7D.....they're no longer made and hence are cheaply had.
The MD and Rokkor lenses won't work on the Sony Alpha.
THIS IS A CHEAP LENS (<$50 VALUE) SO I WOULDN'T LET IT DRIVE YOUR DECISIONS!!
Jan 19, 2008 | Quantaray 50mm f/2.8 AF Tech-10 for Canon...
Rokinon 6501300mm f80160 for Sony Alpha Logo
80 people viewed this question
Top Rokinon Cameras Experts
Terry Leonard
Terry Leonard
Thomas Stauber
Thomas Stauber
Tony Parsons
Tony Parsons
Are you a Rokinon Camera Expert? Answer questions, earn points and help others
