Question about General Electric Dryers
My g.e electric dryer won't start and the light bulb is not coming on mod # dbxr 463
    Problem Solver:
  • 16 Answers
Since the light is not coming on either, check the curcuit breaker first. It can be half tripped and look like it is good. That should be the problem. If not, then check the power at the outlet and at the dryer. Turn power OFF when taking cover off dryer. 220v Hurts.
Posted on Jul 06, 2010
Dbxr 463 gas dryer no heat
Check the pilot light to see that it works when trying to use. Also gas valve could be stuck or bad.
Aug 24, 2014 | GE DBXR463GB Gas Dryer
Want to see a manuel on my new Maytag Dryer Mod: MEDC200XW3
The Maytag should have come with a manual. If not, you can go to the Maytag.com website or Google for it to find the manual for it.
Jul 20, 2014 | Maytag MEDC200XW Centennial Electric Dryer...
Kenmore mod 110 62932100 dryer won t start
First thing to check is the breakers on the building. Then unplug it and check the door switch. They go bad or get loose because of constant use
Jun 26, 2014 | Roper REX3614KW Electric Dryer
Dryer light bulb burned out
follow this steps and fix it. God bless you
Light Socket
The light socket can get corroded or a wire connection can come loose. You will need to remove the front panel to access the housing on most dryers.
Door Switch
If your dryer has an interior light, it probably uses a standard 40-watt appliance bulb, but check your owner's manual to be sure. If the bulb is good but the light won't come on, check the door switch, which serves two functions: When the door is closed, it turns off the light and allows the dryer to start. When the door is open, it turns on the light and prevents the dryer from starting. To check the door switch check for continuity. You should have some when the door is closed and none when the door is opened.If not replace the door switch by removing the front panel.
It blows fuses or trips the circuit breaker
Electric dryers use 220 volts or two power lines of 110 volts each. Some components in the dryer need only 110 volts; the heating element requires 220 volts. So it's possible for one part of the dryer to be fine and another part to have a short circuit. Short circuits can be caused by the heating element, the main power cord, or any other part of the internal wiring. Loose connections on the power cord cause failures and or fires. This can be checked with the dryer unplugged and removing the service cover and visually check for burning and mechanically check for tightness.
If the circuit breaker trips or the fuse blows when the dryer is unplugged, it's likely the problem is with the house wiring, fuse box, or circuit box. Contact a qualified electrician.
Jul 09, 2013 | GE Profile Harmony DPGT750EC Electric...
My 1993 compact bobcat skidsteer won't start, it just stopped running and won't start, I have tried starting fluid and still nothing?
Could be engine speed sensor. All fuses need to be checked. Any smoke when cranking? Any fault codes? A bad fuel solenoid could cause no start if fuel is good.
Sep 09, 2012 | RTO Construction Bobcat by Woody Click
Have a Kenmore Elite Dryer that won't start. Mod 110.65962401 Ser MS0303258 Type DDOT-ELE-2406028-CV54
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 22, 2011 | Kenmore Elite HE4 Electric Dryer
Dryer Wont Start - Smells Burnt
check for shorts and something holding the fan also look at breakers
Aug 11, 2009 | Whirlpool GEW9200L Electric Dryer
Maytag performa dryer assistance
Hello, My name is Juan. I will need help to find the problem with some suggestions. My dryer won't start at all, even when I open the door the light bulb inside the drum did not turn on. I check the power source it is ok. Please help with alternatives for a solution. Maytag electric dryer Mod # PYET344AYW
Thanks,
Juan J.
Jun 07, 2008 | Dryers
Dryers Logo
87 people viewed this question
Top General Electric Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Donni Steen
Are you a General Electric Dryer Expert? Answer questions, earn points and help others
