Question about HP DesignJet 450c InkJet Printer
Upon turning on the plotter, with no paper installed, the Cartridge and Data lights are on solid. When I push cancel those 2 lights go out and the media light flashes. I again push cancel and the media light goes out and the load media light comes on solid. Typically the load media light flashes in order to draw paper into the plotter. With the load media light solid, the paper will not load. Any suggestions?
Remove the top cover and stick some paper into the switch on the left side of the menu to simulate the cover closed. Now power on the plotter and watch what happens. The carriage assembly should move all the way to the right and then back to the left. If will then move to the right again and then back to the left and start to find the mark encoder which is a white piece on the left end of the paper platen. You should see the red light come on underneath on the right side of the carriage assembly as it tries to read the mark encoder. Does the red light come on? If not I really do not see how the printer can come to load media unless you get all three lights on the right and then you hit cancel and then it say load media. That sensor does have a habit of picking up a lot of black ink. If the plotter is old and has been used a lot, it is possible the sensor is clogged with ink. The best way to clean it is to remove the left side cover and remove the service station. You will then have access to that sensor without having to remove the carriage assembly from the plotter. The other thing you will want to do is clean the encoder strip with a damp lint free cloth
Click on the link below to view the HP Design jet 450c user guide
http://h20000.www2.hp.com/bc/docs/support/SupportManual/bpp02529/bpp02529.pdf
Posted on Jul 06, 2010
  • 1 more comment
  • barry554 Jul 06, 2010
    Michael,
    I
    Micahel, I have cleaned the encoder strip and the sensor and the problem is unchanged. Prior to cleaning the sensor the red light was visible but I did remove a lot of black ink from the bottom of the sensor. The description of my problem shown above was accurate first thing this morning but for the last several trial start-ups the Cartridge and Data lights still come on solid and upon pushing cancel they go out and then media light flashes. The difference is that when I push cancel again now, the media light goes out but the ready light is flashing as though it were receiving a job. Pushing cancel does not stop this and of course the paper will not load. This change came even before I perfromed the cleaning that you recommended. Any other suggestions?
    Also,
    Several
    Mike, I started to mention that several times this morning when the load media light was on solid I depressed the blue load button and the paper drew in. The align media light flashed and I lowered the blue handle, aligned the media, raised the lever and the excess paper was cut off as usual but the plotter proceeded to spit out the roll and the media light came on solid. Thought this may also be helpful info.
I lost my installation cd for my x2470 printer. I do not have money,is there a way to install it witout a cd
    • Step 1 Open your web browser and go to Lexmark's "Drivers and Downloads" page (see Resources section below). Locate the search box labeled "Search by Model" and enter X2470. Press return. Select your operating system from the pop-up menu. Wait for the download page to load, then click the "Download Now" button. Save the installer file to an easily accessible location.
    • Step 2 Rotate the printer so that the rear section is in view. Connect the power cord to the power cord connector located on the right. Plug the remaining end of the power cord into an electrical wall socket. Connect one end of the USB cable into the USB port located on the left. Rotate the printer back into place.
  • Step 3 Turn on your printer. Extend the paper guides and insert paper into the tray. Readjust the paper guides so that they are flush with the paper.
  • Step 4 Lift the scanner unit and wait for the print cartridge holder to move into view. Push down on the light blue lever to raise the cartridge holder lid. Install the ink cartridge into the print cartridge holder. Close the cartridge holder lid and lower the scanner unit.
  • Step 5 Connect the remaining end of the USB cable into any available USB port on your computer. If any "Add New Hardware" screens appear on your computer, click "Cancel."
  • Step 6 Open the previously saved installer file and follow the onscreen instructions.
  • Step 7 Locate the button on your Lexmark X2470 that looks like an open scanner pointing to a computer monitor. Press and hold this button for three seconds. Follow the instructions that appear on your computer. Once this is complete, your printer is ready for use.
May 23, 2011 | Lexmark X2470 All-In-One InkJet Printer
I bought a used HP Design Jet 450 C...But its showing the cartridge and data solid orange light and ready light is constantly green. I brought a new black cartridge, the printer takes in the paper and...
I think the problem is not the computer. You shoud check the plotter by running the test print without the computer. When plotter's power is on, press Setup and Cancel keys simultaneously. If it does not print, then the plotter need repair.
According to your descriptions, there is System Error Code shown on your control panel. when the lights on for Ready+Cartridges+Data (DKL), it may have 9 possible causes referred by Service Manual page 2-7. You can check all these 9 items to see which one causes the problem.
Dec 17, 2010 | HP DesignJet 450c InkJet Printer
Designjet 450c plotter
From the service manual:
Ready + Cartridges + Data: Mark Encoder not detected. Possible causes:
1. The line on the mark encoder is dirty or missing.
2. Faulty or badly connected trailing cable.
3. Faulty or badly connected carriage sensor.
4. Faulty or badly connected X-axis Encoder Cable.
5. The drive roller has shifted slightly from the expected position (mechanics). Check that the carriage sensor lights just over the white mark on the drive roller when starting.
6. Faulty carriage PCA.
7. Faulty X-motor.
8. Faulty Y-motor.
9. Faulty electronics module.
Jun 10, 2009 | Xerox Phaser 7750DN Laser Printer
Problem with plotter
That sounds like a carrage movment problem. When you load paper the carrage moves from the RHS very quickly. If your carrage is not properly lubricated you will get that fault. Before going further you must switch off and open the cover. Look along the length of the belt (just below on the aluminum) if there ere lots of reddish pieces and a dust like substance it means that your carrage belt will need replacing. If the belt is ok, then move the head to the middle of the machine by hand and apply a drop of thin oil (sewing machine) to either side of the carrage on the bar. Move the head slowly left and right to lubricate the bar. It then should be ok.
Good luck
Dave
Jun 02, 2009 | HP DesignJet 450c InkJet Printer
Are the lights flashing? If they are flashing it is a system error, if they are on steady it is a recoverable error. When you push cancel is the media light the only one or is align media or ready on as well?
Aug 11, 2008 | HP DesignJet 450c InkJet Printer
ERROR LIGHTS
Is your ready light on as well? If so this may indicate that the "mark encoder" is not detected.The mark encoder is the white plastic piece on the left end of the large black roller that the paper feeds around.If the encoder is very dirty,then cleaning may help.If not, carriage usually has to be replacved, I have heard of some that paint over the mark encoder with white out before replacing the carriage. Don't think I would try it but....Hope this helps.
Jul 24, 2008 | HP DesignJet 450c InkJet Printer
Samsung ml 2010 r laser printer
Check your manual, there is a solution there or download the user guide from
this site below or read the information below.
http://downloadcenter.samsung.com/content/UM/200602/20060216163720484_ML-2010_English.pdf
LED pattern Possible Problems and Solutions
Your system has some problems. If this problem occurs,
contact your service representative.
On Line/Error LED
lights red
• Paper jam occurs. To solve the problem, see “Clearing
Paper Jams” on page 5.6.
• The front cover is open. Close the front cover.
• Paper tray is empty. Load the paper in the Tray.
• The toner cartridge is out of toner. Remove the old toner
cartridge and install a new one. See “Installing the Toner
Cartridge” on page 2.4.
• You pressed the Cancel button while the printer is
receiving data.
• In Manual Feed mode, there is no paper in the manual
tray. Load paper into the manual tray.
• If the printer is receiving data, the On Line/Error LED
slowly blinks green.
• If the printer is printing the received data, the On Line/
Error LED blinks green fast.
Jul 17, 2008 | Samsung ML 2010 Laser Printer
Printer ML2010 not responding
On Line/Error LED
lights red
receiving data.
Jul 15, 2008 | Samsung ML 2010 Laser Printer
Data light and Cartridge light stays on
Clean off cartridge contacts on printer carriage where carts sit and contacts on cartridges-if they sit for long periods of time they clog up.
you will probably need new cartridge{s}
start with black and go from there.
we use alcohol.
Apr 02, 2008 | HP DesignJet 450c InkJet Printer
Online/error light
Pull out the toner cartridge. Carefully put your fingers into the opening just beyond the chrome roller. A little to the left of center you will fell/see a small black plastic finger which sticks up. It should be loose - push it forward and it springs forward, release it and it returns to the original position. If your paper jam catches this finger it can become jammed and will feel rigid. Put light pressure on it either pushing to the back or pulling forward until it becomes free again. Replace the toner cartridge, close the cover and your red light should go out.
It worked for me - hope it helps someone else.
Mary Lou
Aug 31, 2007 | Samsung ML 1610 Laser Printer
HP DesignJet 450c InkJet Printer Logo
52 people viewed this question
Seeker5211
Seeker5211
