Question about Norcent Technologies LM-965WA Monitor
Screen has gone black - is there a fuse anywhere I don't know about
    Genius:
  • 1,478 Answers
Monitor do not have fuse,
Have you check all connection to see if they are right, check if no cable was unplug, if you have and yet no picture display, It could be that the picture board on your monitor has started malfunctioning, since the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Posted on Jul 07, 2010
After updating graphics drivers, I don't know how to adjust scaling on my sell ST2321L monitor so the 1 inch black frame around the display is gone
Go to display setting on the monitor and adjust Horizontal and Vertical Positions
Use the icon-down.gifand icon-up-1.gif buttons to adjust image up / left and down / right. Minimum is '0' (-). Maximum is '100' (+).
Aug 30, 2012 | Dell ST2321L Black 23" 5ms LED Backlight...
My nokia e7 screen has gone to a black and green glitch back ground
Have you tried a reset by holding the power key down for 10 seconds?If that doesn't work you can try removing the battery for a few seconds.
I had a similar problem with my E7, it was dead and wouldn't respond even when I plugged it into my PC. But once I had removed and replaced the battery it was working fine and its not gone wrong since. Here's a good guide on removing and replacing the battery
Dec 28, 2011 | Nokia E7 (16 GB) Smartphone
I got 2wire G802.11g suddenly their no power on my modem, i use light tester to see if my breaker has gone off but it not i don't know what is wrong ,,
power adapter is the problem and it's a known issue for 2wire modems: if you are under an Internet Service Provided kindly contact them specially if the modem is still under warranty.
you can also try looking for a PSP power adapter... this works but not really a guarantee...
Qwest Technical Support at 1-800-247-7285
SASKTEL TECH SUPPORT Anywhere in Saskatchewan :1-800-773-2121
Outside Saskatchewan (anywhere in Canada and USA):1-888-773-2122
Anywhere else in the world:1-306-522-1820
AT&T ' Yahoo! High speed Internet
Call +1 877 722 3755 (877-SBC-DSL5)
Aug 30, 2011 | 2wire Wireless-G 802.11g ADSL Gateway
I don`t know were the black and white buttons are at on an Xbox elite
On the controllers for the xbox 360 elite, the black and white buttons that used to be on the old xbox controller S, are gone.
Oct 12, 2010 | Microsoft Xbox 360 Console
The monitor screen has gone black. By switching off and then swithing back on a faint image is seen which flikkers and then goes black again.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 20, 2010 | Computers & Internet
Saw quick working suddenly, maybe blown fuse
Your saw will have a reset button that may be black in color but should not have a fuse
With the power off push down in the reset button you may or may not hear a small "click" plug it back in a give it a try
Pushing them to hard will cause an overload and they will quit
give it 5 minutes to cool of and resetting should do it
Mar 08, 2010 | Hitachi 12" Compound Miter Saw with Laser...
Black screen
I have the same problem. Fine one day and a black screen the next. I called Vivtar and they were no help. They wanted me to send it in and let them repair it at my expense. don't think so. everything works perfect on the camera...but the screen is black and so are the pictures. Good Luck!
Apr 26, 2007 | Vivitar ViviCam 5385 Digital Camera
Viewsonic VA712b 17 " flat screen monitor
Realheadache, Unusual problem, it could be the resolution and refresh rate setting your PCs video card is currently set at. I don?t know if this will fix your problem but its worth a try: - Now go to your PC with the old monitor connected, right click anywhere on the desktop. - Left click Properties from the box that appears. - When the Display Properties box appears click on the Settings tab. - Make note of the screen resolution. - Change the screen resolution to 1024 x 768. - Click on the Advanced button in the lower right hand corner. - In the next box that appears click on the Monitor tab. - In the Monitor settings section of this page record the value of the Screen refresh rate. Then change it to 60 Hertz. - Close this and the Display Properties box by click on the OK button. - Now try connecting your new monitor. Let us know if this helps and as always please don?t forget to rate this posting.
Feb 04, 2007 | ViewSonic VA712B 17" Flat Panel LCD...
Norcent Technologies LM-965WA Monitor Logo
125 people viewed this question
Top Norcent Technologies Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Piyal Perera
Piyal Perera
Brandon Murphy
Are you a Norcent Technologies Computer and Internet Expert? Answer questions, earn points and help others
