Question about LG LMV2083SW Microwave Oven
Unit Doesn't Heat
I have this model only an SB and it is just over a year old. The unit runs and pwers fine; however it doesn't heat at all.
4 Suggested Answers
ginko
  • 19396 Answers
SOURCE: Microwave Does Not Heat.
Test the high voltage capacitor,the rectifier diode.or the magnetron.
If it additionally does not spin and no light, then check also the door switch.
The diode and capacitors can br tested. The capacitor must be alloweddischarge before testing, or you risk to get electrocuted, even ifpower is off. Capacitors can get discharged by shorting their twocontacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Posted on Apr 27, 2009
SOURCE: Model #lmv1630bb. Does not
I will advice you verify if the hot surface igniter is coming on when the oven thermostat is in demand. When the thermostat is turned on for the oven you should see the igniter start to glow. You may need to remove the bottom oven panel to be able to see it in action. If it starts to glow then take a wrench and tap the gas control valve located at the back of the oven in the broiler/storage compartment on the bottom of the range. If you tap the valve and the burner comes on then shut off the oven completely and back on several times and make sure it is working. If it does you may have solved the problem. If the burner does not come back on and you have to tap it again then the gas valve is sticking either due to a bad valve or weak igniter. If the igniter does not glow then the igniter could be bad. You would need to verify the igniter is getting voltage. Then the igniter can be tested with a ohm meter. A good reading usually is between 500 to 700 ohms. The hot surface igniter cang get a crack in it causing it to stop working.
Take care.
Posted on Aug 22, 2010
  • 6771 Answers
SOURCE: Very loud motor sound -
The magnetron in the microwave has failed, "heats food" and some cases gives off an odor that stands out. To repair the oven will approach the price of a new one
Posted on May 15, 2011
Kenmore elite microwave model 721.79203010 problems
I'd check to make sure you don't have a door switch that isn't functioning properly. Also, might be a control panel or control panel interface issue.
Mar 18, 2013 | Microwave Ovens
Runs but doesn't heat
if it has a turntable does it move? Possible diode, inverter board (may have the diode on it or the Magnetron.
If an inexpensive unit it may be cheaper to replace than repair.
Nov 05, 2012 | Emerson Mw8999rd Microwave Oven
GE spacemaker XL1400
what problem do you have mention ? attached is there a list please indicate. God bless you
    No Lights or Power, Unit seems Dead The voltage to the unit is good.Lights come on, but can not program unit, Touchpad dead
    Microwave Runs, but no Heat Turntable rotates, acts like it is heating but doesn't. This is the big one, many possibilities.
    Microwave Runs, Heats, but turntable does not move
    Microwave is arcing
    Microwave Vent Hood is not working Over The Range(OTR) Models.
    Microwave Stove Light not Working OTR models, light bulbs good.
    Microwave overheats and keeps turning off
Oct 01, 2012 | Microwave Ovens
Electrolux microwave buzzes and food doesn't heat up
If the unit operates correctly except heating the food, then the unit needs a new magnetron.
Aug 29, 2012 | Electrolux EI30BM55H Microwave Oven
GE microwave over the range, model #jvm1740sm1ss has no power.it's only two year old.what could be the cause?
the problem of this unit is power related.
First, remove the unit's power cord from the wall, wait for about 30mins, then plug it back in. It may cool by then and might power on. If it doesn't power on, plug it into another outlet, to make sure there electricity entering into the unit.
If plugging into another power outlet doesn't power it on then the unit is most likely having a power problem.
When electric current comes from the power outlet into the cooker, it goes straight into the power supply board which then circulates the current into the unit. So if the cooker doesn't power on, the first thing is to make sure there is power entering into the machine.
So check the power cord, if it is a 3-pin plug, it must have a fuse in it. check the fuse if it is not blown. if fuse is intact, then power supply board should be checked.
If any machine or electronics device doesn't power on, it means its having a power problem. it might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
This unit must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the unit turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter and continuity tester in order to read the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Regards.
Nov 08, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave runs but doesn't heat
HI>An oven is equipped with a heating filament that is called.Magnetron.Now if the motor is working but the unit is not heating .Then MAGNETRON is defective and must be replace.
Jul 22, 2011 | Maytag Microwave Ovens
Just stop working less than A YEAR OLD.
Seems to be a common problem for the looks of it. Mine was only a month old. Defect maybe?
Jun 08, 2010 | Danby DMW799 Microwave Oven
Ge over the renge microwave runs but no heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
hjdhjd
Feb 13, 2010 | GE JVM2070 Microwave Oven
LG LMV2083SW Microwave Oven Logo
Top LG Microwave Ovens Experts
William Miller
William Miller
Greg Cann
Greg Cann
Devabhakthuni...
Devabhakthuni...
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
