Question about Whirlpool Dryers
There is no heat going to the drum - Whirlpool Dryers
  • Whirlpool Master
  • 8,220 Answers
What I do is look for reasons their is no heat.
Posted on Jul 06, 2010
Replaced all parts for dryer because of no heat dryer runs drum turns had breaker and wiring going into dryer everything ok still no heat could wires be backwards going to replacement parts?
Electric dryers have as many as three thermal fuses. See if you might have missed one. One next to coils, one next to drum and one near the lint trap at air outlet. All three have different trip settings.
Jan 04, 2016 | Dryers
Keeps tripping out my down stairs sockets.checked the wires going to the machine and the plug.all seem fine.? Please help
IS BEARINGS OK IN DRUM IF NOT THE DRUM HAS GONE THROUGH HEATING ELEMENT ...TURN DRUM BY HAND IT SHOULD BE SMOOTH .. OTHERWISE CHANGE HEATING ELEMENT.
Feb 27, 2011 | Indesit W 123 Front Load Washer
The dryer is not producing heat.
If the Drum is rotating and the Blower Motor is operating (meaning you can feel air moving in the Drum), then the likely culprit that is causing your lack of heat is the Heater Box. By box, that means a metal box that usually sits behind the drum containing a heating element that heats the air going into the drum. If this heating element is not working then, you heater box is at fault. Don't assume that the element is bad, more often than not is is a thermostat, switch, or perhaps a wire that is connected to the box. While the other electric components on your dryer operate at 125VAC, the heater box uses 220V AC. You will need to get a multitester to check continuity. On some models, you can access the box from the box, but on others you will have to remove the front door and take the drum and belt off (a pain in the neck to remove). Hope that helps.
Jan 12, 2011 | Dryers
Dryer won't stay going after button is released and the door safety button is still functioning, also the heating element is still working.
This is what is probably going on. There are two parts in the motor that cause the drum to rotate.
One of them is "start" winding. It literally starts the drum's rotation. Once the drum motor has started the drum to move. The second portion of the motor, known as the "run" winding takes over and keeps the drum turning. When the Drum winding burns out. The same symptom is caused when the switch attached to the motor is also damaged. In your case, although this is rare. I think it may be the switch.
The reason being is that the motor has a combination switch that also connects one side to the heating element. In a nutshell, If you get the dryer not continuing to turn AND the heating element stays on. There is a problem with the switch.
If you get the heating element going on when you push the start button but turns off when you release the button. The problem is the motor having a burned out run winding. Either way, it is less labor intensive to replace the motor when you take it out. Doing it switch is not easy. Hope this helps. If not write back to me and we can continue.
Best, Mark
Dec 28, 2010 | GE Dryers
The dryer heats on and off. Sounds to be laboring to turn the drum. Service tech came out and did not know how to fix or approach the problem with why the dryer heats and dries a load and then may not on...
drum roller,drum glides, or idler assemblage which is located next to motor(might be motor going out). Here is a website that will help:
for glides/roller: http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
for idler/motor: http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Nov 29, 2010 | GE Profile Harmony DPGT750EC Electric...
Heating element is hot, but, no heat in drum.
disconnect the duck pip from the back of your unit and see if it is hot inside... if it is getting hot then your pip need to be clean.
if it is still the same your drum have felts in the front and the back that go bad, the heat is leak from the drum sides.
Jan 20, 2010 | Maytag Neptune MDE5500AY Electric Dryer
I can't remove the rear brake drums off my 2005 pontiac sunfire, I think because i let the bad brakes go too long and they grooved into the drums, so how do i get the drums off now/
I do brakes on these all the time.On all of the brake drums after some time they get hard to remove since the drum rusts to the axleor bearing hub. When I remove the wheel and the clips that usually come from the factory around a couple of the studs I apply heat to the drum and spin the hub.9A small propane torch will suffice since it doesn't require a lot of heat. As it warms up the drum expands and ships off the hub. Do not heat the hub or it will grow with the drum. When warm it will tap off or a light pry from the back of the drum. Without heat I cannot remove 90% of these drums.
Aug 16, 2009 | 2003 Pontiac Sunfire
Dryer will turn on and spin but is not heating up
This usually means the heating element (wire inside behind the turning drum) is broken. Unplug the dryer. Open up the back and front of the dryer, remove the drum's belt, then the drum. You should see the heating wire at the back. Check for the break. Then using pliers, join the two broken ends together by twisting the wires together. Put the parts back together, plug the dryer back in and away you go.
Aug 06, 2009 | Dryers
Motor not strong enough
The problem dosen't sound like the motor. Check to see if the drive belt is loose and slipping. This is the usual cause of the problem you describe. If not, the bearings for the drum may be going bad. The heating elements should turn off shortly if the drum stops so there is little danger of overheating.
Ray
Dec 15, 2008 | GE DBSR453EBWW Electric Dryer
Dryers Logo
27 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
