Question about Husqvarna Craftsman 36cc, 16 In. Gas Chain Saw
Bar bolt on Husqvarna 142e spins.
I finally cut off the nut as one of the bar bolts spins when I try to tighten or loosen the nut. I am not sure if the head of the bolt is damaged or if the flange on the plate-bar stud / bracket is damaged. How do I get into this area and check and replace the broken or damaged part (either bar bolt or plate-bar stud)? It looks like the assembly is under the clutch cover. If I need to remove this - will I run into troubles putting the cover and band brake back on?
    Brigadier General:
  • 4,088 Answers
Go to Searspartsdirect.com and enter the complete Sears model number minus the decimal point. That should bring you to a series of replaceable parts diagrams plus part numbers. If the bolt is not listed as a separate part, then likely it is part of the fuel tank assembly. Hope this helps!
Posted on Jul 14, 2010
Tightening chain
Tightening chain is performed by adjusting the bar. Two bolts generally hold the bar in place. Loosen these. Make sure that chain has enough play to easily move by hand. If it sticks, it's too tight. Then tighten the bar, check the chain oil, and cut wood.
Mar 25, 2015 | Garden
Cant loosen the bolt that holds my alternator on, for my 2006 2.4 camry, ive been using a 14 mil ring spanner and trying to turn it anti clock wise? also how do you loosen the belt?
Try using a 14mm socket and extension bar.
If you do not have that then simply get a 19mm ring spanner and use it as an extension bar onto the open end of the 14mm spanner.
Once loosened you will also need a12mm ring spanner to loosen the pinch bolt that holds the alternator belt adjustment bracket.
Dec 12, 2010 | Toyota Camry Cars & Trucks
Replace broken sway bar for a 1996 ford windstar
Section 04-01: Suspension and Wheel Hubs, Front 1996 Windstar Workshop Manual REMOVAL AND INSTALLATION Stabilizer Bar Removal
  1. Raise and support the vehicle. Refer to Section 00-02 .
  1. Support vehicle with hoist or safety stands behind front sub-frame (5C145).
  1. stw~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: To avoid damage to the 6 mm drive hole in the front stabilizer bar link ball stud, do not use an Allen wrench to break loose or tighten or final tighten the front stabilizer bar link-to-shock absorber nut.
    Using care not to damage the front stabilizer bar link ball stud seal, remove the RH and LH front stabilizer bar link-to-front shock absorber nut.
  1. Using care not to damage the front stabilizer ball link stud seal, remove the RH and LH front stabilizer bar link-to-front stabilizer bar nut.
  1. stw~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Use extreme care not to damage the ball joint boot.
    With another set of support safety stands under front sub-frame, remove two rear sub-frame retaining bolts. Lower rear of the front sub-frame to obtain access to stabilizer bar brackets (5486).
  1. Remove front stabilizer bar bracket bolts, stabilizer bar brackets, stabilizer bar bracket insulators and front stabilizer bar (5482) as required.
Installation
  1. Clean front stabilizer bar to remove dirt and contamination in area of stabilizer bar bracket insulator installation position.
  1. Lubricate inside diameter of new stabilizer bar bracket insulator with Rubber Suspension Insulator Lube E25Y-19553-A meeting Ford specification ESF-M99B112-A or equivalent. Do not use any mineral or petroleum based lubricants as they will deteriorate the rubber stabilizer bar bracket insulators.
  1. Install new stabilizer bar bracket insulators onto front stabilizer bar and position them in approximate location.
  1. Install stabilizer bar bracket on stabilizer bar bracket insulators and install new bolts. Tighten to 55-63 Nm (40-46 lb-ft).
  1. Raise front sub-frame and install new front sub-frame-to-body retaining bolts. Tighten to 115-132 Nm (85-97 lb-ft).
  1. Install front stabilizer bar link (5K483) to front shock absorber. Use care not to damage link ball joint boot seal.
    Install a new front stabilizer bar link-to-shock absorber nut. Tighten to 90-100 Nm (66-74 lb-ft).
Apr 28, 2010 | 1996 Ford Windstar
What is the torque settings on the head bolts for 2002 nissan x-terra 2.4litre?
① Step 1: 22 ft. lbs. Step 2: 59 ft. lbs. Step 3: Loosen completely then retorque to 22 ft. lbs. Step 4: 18-25 ft. lbs. Step 5: Plus 86-91 degrees ② 10-12 ft. lbs. plus 60-65 degrees or 28-33 ft. lbs. ③ The cylinder heads and the lower intake manifold are installed together Step 1: Tighten the cylinder head bolts to 22 ft. lbs. Step 2: Tighten the cylinder head bolts to 43 ft. lbs. Step 3: Loosen the cylinder head bolts completely Step 4: Tighten the cylinder head bolts to 84 inch lbs. Step 5: Tighten the intake manifold fasteners to 35 inch lbs. Step 6: Tighten the intake manifold fasteners to 13 ft. lbs. Step 7: Tighten the intake manifold fasteners to 12-14 ft. lbs. Step 8: Loosen all intake manifold fasteners completely Step 9: Tighten the cylinder head bolts to 22 ft. lbs. Step 10: Tighten the cylinder head bolts 60-65 degrees Step 11: Tighten the cylinder head sub-bolts to 80-105 inch lbs. Step 12: Tighten the intake manifold fasteners to 35 inch lbs. Step 13: Tighten the intake manifold fasteners to 78 inch lbs. Step 14: Tighten the intake manifold fasteners to 70-84 inch lbs. ④ 10-12 ft. lbs. +60-65 degrees ⑤ Step 1: 72 ft. lbs. Step 2: loosen completely to 0 ft. lbs. Step 3: 29 ft. lbs. Step 4: Plus 75 degrees clockwise Step 5: Plus 75 degrees clockwise ⑥ Step 1: bolts 11-22 19 ft. lbs. Step 2: bolts 1-10 29 ft. lbs. Step 3: bolts 1-10 Plus 60-65 degrees ⑦ Step 1: 20 ft. lbs. Step 2: loosen to 0 ft. lbs. Step 3: 14 ft. lbs. Step 4: Plus 85-95 degrees ⑧ Step 1: 31 ft. lbs. Step 2: Plus 60 degrees ⑨ 83 inch lbs. ⑩ Stud bolt: 11 ft. lbs. Nuts: 31 ft. lbs. ⑪ Step 1: 72 ft. lbs. Step 2: loosen completely to 0 ft. lbs. Step 3: 29 ft. lbs. Step 4: Plus 90 degrees clockwise Step 5: Plus 90 degrees clockwise ⑫ Bolts: 17-24 (M8) 16 ft. lbs. Install rear main seal Bolts: 1-16 (M10) 26 ft. lbs. Bolts: 1-16 (M10) Plus 90 degrees clockwise ⑬ Step 1: 33 ft. lbs. Step 2: Plus 84-90 degrees clockwise ⑭ Intake manifold collector: Bolts and nuts: 8 ft. lbs. Stud bolts: 61 inch lbs. ⑮ Intake manifold: Bolts and nuts: 5 ft. lbs. and than to 21 ft. lbs. Studs: 8 ft. lbs.
Jan 10, 2010 | 2002 Nissan Xterra
CHAIN AND BAR KEEPS LOOSENING UP AFTER 3 TO 4 CUTS. RESET TENSION AND BAR AND LOOSENS AGAIN AFTER 3 TO 4 CUTS.
Are you holding the nose of the bar up as you tighten the bar nuts?
You loosen the bar nuts and gravity pulls the bar down. You check the chain and the tension is correct, tighten bar nuts. Begin a cut and the bar slowly moves upward (no matter how tight the bar nuts) and the chain becomes slack.
19d6408.gif Chain adjustment
  1. Make sure the chain brake is off (gloves will protest your fingers).
  2. If necessary, loosen the bar nuts that are clamping the clutch cover in place (or whatever holds the clutch cover and bar on). They don't need these really loose - finger tight will do.
  3. Ease the tension adjustment until the chain is obviously loose.
  4. Using one hand, hold the nose of the bar up.
  5. While holding the nose up, adjust the tensioner so that the center of the chain just touches the underside of the bar, add a touch more.
  6. Continue holding the nose of the bar up & tighten up the bar nuts / bolts / quick-release system.
One more likely possibility, is the chain isn't being oiled.
Checking chain lubrication
Aim the tip of the bar at a light colored surface about 20
cm (8 inches) away. After 1 minute running at 3/4 throttle
you should see a distinct line of oil on the light surface. HTH
Lou
Oct 20, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
How to replace a front wheel bearing for a 1999
Removal: Raise and support vehicle. Remove wheel. Remove caliper assembly. DO NOT allow caliper to hang from brake hose. Always support caliper by wiring it to frame. Remove rotor.
Loosen and remove ABS speed sensor mounting screw. Carefully remove sensor head from steering knuckle. If sensor head is seized due to corrosion, use hammer and brass punch to tap sensor. Tap edge of sensor ear, rocking sensor from side to side until it is free. DO NOT use pliers on sensor head.
Remove axle shaft nut. Remove 3 bolts securing hub assembly to steering knuckle. Pull hub straight back from knuckle. If hub is corroded, pry between hub flange and knuckle
Fully remove knuckle pinch bolt. Insert pry bar between lower control arm and steering knuckle. Push down on pry bar to separate ball joint stud from steering knuckle. Ensure ball joint dust boot is not damaged during removal. Loosen and remove strut-to-knuckle nuts. Bolts are serrated where installed into knuckle. DO NOT turn bolts in steering knuckle. Use soft-face hammer to drive bolts out of knuckle. Remove knuckle from vehicle.
Installation: To install, reverse removal procedure. Tighten all nuts and bolts to specification. DO NOT fully tighten axle nut until vehicle is on ground. Ensure hub mounting surfaces are clean and free of foreign material. Coat speed sensor with high temperature grease before installing onto knuckle.
Oct 19, 2009 | 2002 Ford Taurus
A/c belt relacement
DO this with a COLD engine, so you do not burned by a hot engine...Loosen the 14 millimeter nut on the idler/tensioner pulleythat the AC belt rides on. Do NOT remove the nut, or the pulley will fall off. Then loosen the long 12 millimeter bolt, which will remove tension, and will let the pulley extend. Remove the old belt. Spin the tensioner pulley with your hand, make sure that it spins free & is not noisy, Fit the new belt, and tighten the 12 millimeter bolt until the pulley retracts,and tightens the belt. Finally, retighten the 14 millimeter nut.
Dec 31, 2008 | 1995 Toyota 4Runner
Problem installing new toilet bolt covers.
unthread the nut as far as possible, then tighten it one full turn. Cut off the top with a hacksaw or dremel grinder and re-try. The bolts are cheap. A small jewelers file may help. Look for the damaged thread and remove the burr.
Dec 22, 2008 | Home
Changeing chain
Sure, all are very similar and I can tell you without a manual. Loosen the nuts that holds the chain bar to the body. Loosen the slot headed screw that tensions the chain on the bar,( you may have to dig into some stuck on sawdust that may cover the screw) then pull the chain and bar off together. I would flip the bar over to get the advantage of a good square surface for the new chain to wear against on the bottom. Now make sure the cutting bits on the new chain face away from you on the top as it moves on the bar and you are set to replace it on the mounting studs. When you replace the sprocket cover, make sure the tensioner peg goes into the bar slot then snug up the bolts a bit and tighten the chain til you can pull it away about 1/2 inch from the bar when properly tensioned. now further tighten the bolts and enjoy.
Dec 03, 2008 | Poulan Pro Chain Saw 46cc 20"
Serpentine belt
Hey there hardrock,
  • Get a 14mm or 9/16" socket and a long handled ratchet or breaker bar.
  • Get the belt around all the pulleys except the A/C compressor or Alternator.
  • The tensioner pulley is near the Alternator toward the center of the engine. It's on a spring loaded arm. Get your socket on the center nut of this pulley.
  • Slowly pull the ratchet toward the center of the engine. The pulley will pivot on the arm allowing you to get the belt on the final pulley.
  • Slowly release the tension.
  • You're done
Mike
Jul 15, 2008 | 1993 Honda Accord
Husqvarna Craftsman 36cc, 16 In. Gas Chain Saw Logo
246 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
