HP Photosmart C6180 All-in-One: "Ink System Failure" Error 0xc18a0206
    President:
  • 1,561 Answers
Try the following to resolve the problem.
Solution 1:
1. Press and hold "left arrow" key
2. Press the "setup" key and release both keys
3. Press and release the "OK" button
4. Press and release the right arrow button until the display says “System Configuration Menu”. 2. Press and release the “OK” button.
5. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
6. Press and release the “OK” button.
7. Display should say “Hardware failure status: Clear. Press OK to clear”.
8. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
9. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
10. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
11. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
12. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
13. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
14. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
15. If the error is still there, or reoccurs the printer is already defective.
Solution 2:
1. Press the On button to turn the printer off.
2. Unplug the power cord from the back of the printer.
3. Remove all the ink cartridges.
4. Wait two minutes.
5. Plug the power cord into the back of the printer.
6. Press the On button to turn the printer on.
7. Install the ink cartridges when prompted.
Take care.
Posted on Jul 06, 2010
  • kevin285 Jul 06, 2010
    Solution 1 WORKED !!!
    Thank you very much, Jumuah!
Ink system failure
A Google search found this possible solution for you at HP:
Ink System Failure C6180 error 0xc18a0306
Jul 25, 2014 | HP Photosmart C6180 All-in-One Printer,...
0xc18a0206 error
ink system prime failure- the printer is no klonger able to hold pressure in the ink tubes- suggest you replace ALL PRINTHEADS in one go ( the problem may lie in just one printhead or the tubes themselves
If the prinhead replacemnet doesnt wotk then a new set of ink tubes and heads will be needed- this costs about the same as three new c6180 printers and is not worth the money- sorry for thew bad news
Jan 20, 2014 | HP Photosmart C6180 All-In-One InkJet...
I have an HP Photosmart C6180 i get error 0xc18a0206
Welcome to Fixya.
Here's how to resolve this issue :
HP Photosmart Reset
Basically, this error denotes "Ink System failure" and can be resolved by Printer reset. Follow the easy steps and you should be good to go.
Thanks for using Fixya.
Aug 20, 2011 | HP Photosmart C6180 All-In-One InkJet...
Ink System has failied. Error 0xc18a0206 on HP Photosmart 6180
Press *(star) and # (hash) together on the printer and let go.
Key 1 then2 then3
Press the right arrow key until the onscreen menu shows System Configuration
Press OK
Press right arrow key until failure status is displayed
OK again
I think there was another OK after this but not sure????
Keep pressing cancel til you get back to the main menu then
Unplug from power for 1 minute then plug back in
Power back on.
Mar 07, 2011 | HP Photosmart C6180 All-In-One InkJet...
I recieve Ink System failure error message with error code 0xc18a0206 on my HP PHOTOSMART C7180 ALL-IN-ONE PRINTER.
The error that you are having is a hardware issue, it means your printer has an Ink System Failure. Believe me, there's no use going through troubleshooting for this one. Call HP and just Upgrade your printer. HP Printer Tech Support would be more than happy in giving you discounts and an extra year of warranty for $1.00.
Feb 03, 2011 | HP Photosmart C7180 All-In-One InkJet...
Hp c6180 ink system failure error:0xc18a0206
Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This also fixed the ink system failures (0xc1....) the printer was having. A similar fix may apply to other printers. acca299.jpg
Oct 10, 2010 | HP Photosmart C6180 All-In-One InkJet...
Ink System Failure
below is to document that i want you to follow exactly inorder to resolve your issue..
CLICK HERE ==>> DOCUMENT
Please let me know the result after following the document.
thank you so much.
adonscott
Aug 07, 2008 | HP Photosmart C6180 All-In-One InkJet...
22 people viewed this question
k24674
