Question about Dishwashers
When you start the unit it engages and water flows within 4-5 minutes it shuts itself off with drainage intake light flashing. Cleaned filter and checked garbage disposal unit-same result. Changed cycles-same result.
  • rnuzzo20 Jul 06, 2010
    tHE MACHINE OPERATES AT DIFFERENT CYCLES AND SHUTS OFF AUTOMATICALLY AFTER 4-5 MINUTES. hOW DO i REBOOT THE COMPUTER SINCE THERE IS NO ON/OFF SWITCH WHICH IS THE FUNCTION OF THE DOOR OPEN/CLOSE. i HAVE NO WATER LEAK OR CRIMPED HOSES.
  • 6,784 Answers
HI. You can easily "reboot" your unit by unplugging the appliance for five minutes. This will force the main control sector to reset its programming. If you cannot reach the power plug, you can simply shutdown the appropriate circuit breaker for five minutes. This is necessary because your unit dose not have a reset button.
With that said, in order to remedy your error code if it comes back, you will need to purge all the drainage hoses and recirculating hoses as well. There are blockages present deep into the hoses. This is why you are receiving the flashing drainage intake light.
Posted on Jul 06, 2010
  • Michael Masters
    Michael Masters Jul 06, 2010
    • I would also advise to remove the inlet valve hose for inspecting purposes. Once the hose is removed, check the filter screen at the valve and hose. These screens must be clear of any debris. If the screens on the valve cannot be cleared, replace the entire valve. If the hose screen cant be cleared, replace the hose(inlet).
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. The first thing that should be checked is if its draining properly as it could be that the drain hose is clogged and needs to be cleaned. The drain pump also should not be clogged. Also the stopcock should be opened fully and the water inlet valve should be checked for any clogs. Also the metal filter, impeller cover and the air gap unit should be checked. After checking this you can reset the error as follows: turn the rotary selector switch to "Stop/End" or press the "Start/Stop" switch for approx. 5 secs. Then switch the appliance off and then back on again. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
  • 1 more comment
    Rylee
    I FOLLOWED YOUR ADVICE.
    The Miele Incognita Dishwasher does not have a start/stop switch. That is controlled by open and close door, any other suggestions? rnuz20
    When it shuts itself off (after4-5 minutes) The inside is wet and heated. Why is it shutting off?
  • Rylee Smith
    Rylee Smith Jul 06, 2010
    If you have already followed the instructions and checked the drain hose then check the water inlet valve which
    is located behind the lower access panel on the left or right side of the
    Dishwasher. If the water inlet valve is bad you have to replace it, also check
    the main water line for clogs/obstructions.
    Thanks
    Rylee
My Miele dishwasher has water in the bottom of it and won't run
Check the impeller on the pump to make SURE it's turning freely. There could be a piece of debris wedged in there - like glass or a screw from a pot handle. If this is redundant, I apologize.
May 24, 2012 | Miele 24 in. Novotronic G851SC Plus...
Whirlpool 7540 start light flashs 4 times
The #4 error code on your dishwasher says it's a drainage error and that the computer didn't detect that all the water drained out of the machine. Sometimes that can be caused by a blocked filter on the pump, a blockage in the drain hose or a water level switch failure...also it can be just a electronic anomalie and the board can be reset then the dishwasher will work as normal. Or of course it could be because the filter is clogged and needs to be cleaned so water will flow through it and drain out.
I have written tips both covering how to clean the pump filter and resetting the control board,refer to them and see if they will resolve your dishwasher troubles.
TIP FOR CLEARING THE ERROR CODES FROM THE BOARD
http://www1.fixya.com/support/r10357661-get_whirlpool_dishwasher_start_when
TIP TO CLEAN THE PUMP FILTER
http://www1.fixya.com/support/r10292354-whirlpool_kitchenaid_kenmore_diswasher
GENE
Sep 28, 2011 | Whirlpool Dishwashers
My Miele G2430 dishwasher stops right after draining in the first minute or so after starting, and the intake and drain light comes on. The solenoid at the end of the intake hose then clicks and the light...
Hi
Intake/Drain light flashing means an issue while draining. The dishwasher is not draining properly. Please check for air gap on the dishwasher is not clogged. It prevents dishwasher from draining properly and sometimes the drain flow is restricted due to gunk. Cleaning or bypassing the air gap will resolve the issue. If this doesn't resolve the issue then it is due to seized (or stuck) drain pump. Keep handy large bowls and towels to soak the water out. Disconnect the power to the dishwasher or turn off the breaker to the dishwasher. Tip machine on its back; remove screws that hold the bottom tray on. Remove the hoses to the main motor, remove electrical connections and switch it on. If the error still appears then turn the rotary selector switch to "Stop/End" or press the "Start/Stop" switch for approx. 5 secs to cancel the error message. Switch the appliance off and then back on again. Hope this helps...please post back for further assistance.
Daniel
Feb 23, 2011 | Miele Optima G2430SCi Stainless Steel...
Will not complete cycle
check if kitchen sink downpipe is clogged
Jul 06, 2010 | Miele 24 in. Incognito G843SCVi Built-In...
Intake/Drain lit flashing
I have exact same symptons, please someone help. I have had issue before where the plumbing backed up so it overflowed into the catch tray. Then that has to be vacummed out and then just start a new cycle. This time there is no water in the overflow tray....
May 28, 2010 | Miele 18 in. G601SC Plus Slim-Line...
Everstar portable ac unit displaying error message P1. The unit turned itself off and will not come back on. It had no symptoms of not working well before turning off.
According to my Everstar manual, P-1 is a drainage problem.
EverStar owners manual pg. 16 -
1. Release the drain hose from the ruber clip and pull out the rubber plug, let the drain hose slant down to a water container.
2. Press the TURBO button on the unit control panel for more than 3 seconds and the WATER INDICATOR light begins flashing. It indicates the forced water drainage feature is activated.
3. Waiting until the WATER INDICATOR light stops flashing and there is no water flow.
4. After the water has drained, remember to secure the drain hose and plug in the upright position and clip it to the unit.
The unit will return to normal operation.
....I had to do this and it worked - Good luck!
Mar 25, 2009 | Heating & Cooling
DH400P
I had a similar problem with the pump not working and the water flowing into the main drainage bucket instead. I had to disassemble the housing...not an easy project to reassemble...and found that the pump has its own smaller drainage tank with a float device, a pump pre-filter, the actual pump, then of course, more drainage tubes. The entire pump drainage system of components needed cleaned of accumulated, mucoid, slime! I cleaned the channel in which water flows into the pump's tank...located on the screen filter side of the dehumidifier. Then I moved to the other side of the dehumidifier and cleaned-out the entire pump drainage tank. Note that the pump's drainage tank only empties about 1/2 inch of water each time the pump activates. Thus, there is always alot of water in the pump's drainage tank. Thus, alot of time for slime to accumulate. Next, I cleaned off the float mechanism. I then cleaned-out the pump's pre-filter. Cleaning out the pump's pre-filter was paramount to the pump functioning properly and quietly! I checked that my pump was properly installed and NOT rubbing against its mounting so that it operated quietly. I added fresh water to the pump's tank several times to insure that the pump was working properly and that all slime was eliminated. Finally, I reassembled the housing...not an easy task! My pump now functions like new. All this work had to be done to insure proper function of the dehumidifier's pump system. My dehumidifier is only 11 months old. It is still covered by the one year warranty, but it is too expensive to ship the entire unit, as Delonghi requires you to do at your expense for them to fix it under warranty. You can be assured that I will check for future slime build-up to keep my dehumidifier functioning properly. The dehumidifier works great, it's just that it's high maintenance.
Jun 15, 2008 | DeLonghi DE400P Dehumidifier
Miele G841 Built in. Intake/Drain light on/flashing and the dishwasher just shuts down.
In the user manual there's a section on how to clean the non-return valve. It's the plastic piece under the wire below the triple filter. Why did you pull out the machine? Did you kink the drain hose? If you don't find a clogged valve, spin the impeller wheel several times. It's under the valve inside the bottom hole where the valve came out.
Now here's the important step- Reset the fault! Power off/on the unit. If the light blinks when you turn it on, Press and hold the start button 4 seconds with the door open. Find the combination of off/on buttons to press to reset the machine in the user manual.
(Note: If the machine runs continuously as soon as you pressed on the power button, then you have water under the unit in the safety pan. Call Miele for help.) Now select the normal wash cycle close the door and start it. The drain motor always runs first. This verifies to the brain how much water is inside the machine when it starts filling. The drain pump runs for half a minute. If you hear it running with no drain check the drain hose especially if it's connected to a disposal. Clean the disposal.. If it's not running at all the light will go on again before filling, call Miele. If the machine fill up with fresh water, the drain works. Watch and listen when the light comes on. Is it filling or did it start circulating? Open the door, are the baskets are dripping wet? Then it filled and circulated. If the light comes on several miutes later then call Miele.
Feb 04, 2008 | Miele 23 in. Novotronic G841 Built-In...
Another inlet / drain light cycle interruption problem!
When the water stops too soon, it could be the "over flow" is stuck in the downward position, therefore the dishwasher thinks it's going to over flow. Check that out. Otherwise I'm afraid this sounds like the circuit board is shot.
Miss Midget
Nov 02, 2007 | Miele 24 in. G646SC Plus Free-Standing...
Dishwashers Logo
62 people viewed this question
Top Dishwashers Experts
Owen Barnes
