Question about Sharp Office Equipment & Supplies
How do you get in SIM mode sharp mx
F4-30 code sharp mx7001n
  • mattwillis48 Jul 06, 2010
    i have manual its not there
  • 532 Answers
Hello, Clear key ® Interrupt key ® "0" key ® Interrupt key. Thanks for using Fixya.
Posted on Jul 06, 2010
    This did not work, any other suggestions.
  • 17,970 Answers
Several codes there, I suggest check your User Guide: MX-6201N | MX-7001N Operation Manual Suite (File Size: 20817k)
    its not in manual
How to clear H2-00 cord on Sharp Mx-M363N
Press on the keypad 'P/#' '*' 'C' '*' to get into sim mode then type '1' '4' then press the copy start key, then follow on screen instructions. If the code returns you have a bad fuser, I believe the lamp.
May 29, 2017 | Sharp Office Equipment & Supplies
Error code F2-40 in Sharp mx m314n photocopier
using third party toner or drum replace toner and drum with OEM
Jun 04, 2015 | Sharp MX-M314N Copier
Sharp mx 2300N error code U2-41
The U2 errors are usually related to memory or board level issues. You should try to disconnect the fax and network and then kill the main power inside the cover. Turn the main power on and then when you get a solid green light on the control panel press that power switch. If the machine boots with everything disconected then try conecting the options one at a time and try rebooting each time to see if you can narrow down the problem.
Oct 16, 2014 | Sharp MX-2300N Color Copier
Error code U6-02
You have a large capacity double tray, the code is for the lift up motor in the right hand tray (that lifts the paper stack to the rollers) pull out the tray and see if there is paper wadded between the tray and the back wall of the machine blocking the motor boss from meshing with the tray.
Clear the motor error code with SIM 15 in the service area of the machine (from copy mode, # * C * to access)
If the code comes back your lift motor is worn out and needs to be replaced
Apr 20, 2014 | Sharp Mx-m450n Mfp Multifunction Booklet...
Mx-2300n firmware
The firmware is only available from a dealer. You can make an arrangement to get it on a USB thumb drive and update the machine using SIM 49
Apr 19, 2014 | Sharp MX-2300N Color Copier
Maintenance require code vc
The VC code on a sharp mx-2700 is the cyan developer has reached its maintenance cycle of 60,000 copies. to clear this code enter sim mode #, *, C, * then 24-5 to clear dv count.
Jan 28, 2014 | Sharp MX-2700N Color Copier
Mine is displaying code error h5-01
this is 5 or more jam codes at once - likely hood is that the papers are jammed up on the fuser entrance on right hand side - if you remove the paper then go into service mode and use sim 13 to reset the code
Oct 15, 2013 | Sharp MX-2300N Color Copier
SHARP MX-3100N CODE E7-06
MFP -Image data decoder error
Try to clear code. enter sim with program key- asterisk*-clear key- asterisk*(P-*-C-*) enter sim 14 print key execute yes clear all machine will reset. if code comes back it is not just not a fluke and you may have another issue.
Aug 28, 2011 | SHARP MX-3100N
Code:fk1 sharp 2301 N
That is a maintanence code. Usually says that the fuser rolls are at a certain copy count.
Here is what to do.
Press in order on the consol. # * C * That will enter the machine into what is called SIM mode.
Then enter the number 24 then 4 for that code, then press execute. You may want to just do the clear all maintenance code too.
Apr 26, 2011 | Sharp MX-2300N Color Copier
Sharp service code H5-01
To enter simulation mode to reset errors enter this sequence on keypad.
P, * , CA , P then enter sim # 14 to reset code.
press " custom settings" button to return to previous menu and CA to exit sim mode.
Dec 10, 2008 | Office Equipment & Supplies
156 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
