Question about Panasonic Televison & Video
HOW TO REPAIR A PANASONIC FX74 TV SET
When this tv is switched on their is only sound ,but no picture.Also i
can here the static on the tv ,but no picture.The filliments on neck
of crt tube not on.
  • 556 Answers
SOURCE: Panasonic switching to standby mode on its own
Is this a recognised symptom? yes the problem in power supply. it is due to switching oscillator& switcing output circuit probabaly capacitor & transistor. as set is very old so after power supply is ok check for horizontal output also. can it be fixed? yes it is common & not major problem
Posted on Oct 08, 2007
ramon49
  • 111 Answers
SOURCE: CRT TV picture keeps getting horizontal line & loud cracking nois
the horizontal section is near collapse, the lines indicate a sort or leak. Soon, the set will go black. Shut off as repair will be cheaper now! Needs professional repair as High voltage section is dangerous.. Unplug to be safe!
Posted on Mar 14, 2009
mie999s
  • 105 Answers
SOURCE: turn on tv, sounds from circuit board but nothing at all on scree
Power supply,horizontal output,fbt transformer or lastly picture tube all this matter can make your ic board got sound
Posted on Mar 24, 2009
mie999s
  • 105 Answers
SOURCE: power supply in stsandby mode. onlky 35v panasonic
first try change your vertical output ic check the horizontal output ic but i suspect your system ic is fault it is very hard to find the part and exspensive too
Posted on Jul 01, 2009
  • 43 Answers
SOURCE: I have a Panasonic 32' crt tv
some of those chassis develope small cracks or cold solder joints
should be resoldered in several areas know to have that problem
transformer pin connectors-heatsink transistors/ic's have to be checked
Posted on Aug 31, 2009
Sanyo DP26649 screen blacks out and sound becomes loud static
Most likely you will need to get a diagnoses performed on the set. Your problem could be with either the main board or power supply board. The million dollar question is do you repair or replace? With parts and labor to repair this set, you could come out cheaper replacing it.
Jan 15, 2013 | Sanyo DP26649 26 in. TV
Panasonic 32" LCD TV showing almost Black pictures
If a 4 year old 32 inch set likely cheaper to replace than repair it assuming parts are even still available.
Aug 25, 2012 | Panasonic Viera TX-32LX77 LCD TV
Tv picking up channels except its all static, colorless, and loud static noise..
If the set was purchased in the USA it has the USA format which is NTSC--unless the signal is NTSC picture will be in black and white and no sound.
If the signal format there is PAL OR SECAM you will need a converter that takes that and outputs NTSC for the set to work properly there.
May 16, 2012 | Panasonic Viera TX-32LX70 32 in. LCD TV
My sega genesis has a clear picture but static sound can someone help?
Try an older TV set. I am not joking. It might very well be the case that newer TV sets/high-end TV systems can't handle the signals of the older video game consoles. Because the newr tv;s don't have the signal transfer inside of them to make the old consoles work so you could use the genesis av cables to hook up to a digital tv instead of the rf switch.
gen_av_cable_2_3_tmb.jpg&maxx=130&maxy=120gen_av_cable_v1_tmb.jpg&maxx=130&maxy=120
Mar 17, 2012 | Sega Genesis Console
Sound off
you are having problem on your tv with your tv sound ic this can be located ion the sound circuit just where the speaker is hooked up inside the set if you are not a tech have one repair your tv good luck
Jul 12, 2009 | Televison & Video
Problem with RCA TV Model 27F634T
You almost certainly have a bad picture tube. The green screen was from one of the elements inside shorting out. The static sound you're hearing is the high voltage arcing out through the end of the picture tube to other parts inside the set. It's more economical to buy a new TV than to repair this one.
Sorry to have such good news, but this is one of the ways a picture tube can go bad, and it happens quite often.
Mar 11, 2009 | RCA 27F634T TV
Samsung TXG2547 25"inches TV problem
you have damage your tv micro chip, regulator ,or horizontal output with static current when you plug out your tv from th plug,what is clicking is the relay trying to power up your tyv but due too the damage it cannot power have a tech repair your tv good luck
Oct 26, 2008 | Samsung TXG2547 25" TV
Suddenly no sound & no picture overnight: is my TV dead?
If you have static siugnal, sure TV is not dead.
Check the aerial cable, ensure it is well plugged in and getting signal.
If you are using a receiver box, check cables to TV and receiver (freeview, sat, cable etc.), try setting channels on receiver again, if it does not work but you get static, then either the cables or receiver are defective.
Test the TV on standalone , connecting it to an external antenna.
Tune again the channels, and save the preset.
If still no signal then the antenna socket on the TV may be defective.
Try using the TV with a DVD.
If you can watch DVDs, and TV is not keeping channels preset, and you tried all the above, at this point htere may be a fault in the tuner card inside tv.
Call the phone number listed on tv user manual to get support, and eventually repair it.
Oct 03, 2008 | Panasonic CT-36HL43 36" TV
Sanyo TV DS32224
Is the hissing or static sound comming from the speakers or from the back of the set itself?? Need more info please.
Mar 23, 2006 | Sanyo DS27910 27" TV
Televison & Video Logo
152 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
