Question about Sony CDX-CA810X CD Player
Sony CDX-CA810X CD Player says cd reset. CD player repeats cd reset... took off face and hit reset button... still problem occurs.... removed fuse from cd player...no resolution. Can someone help? Is a CD stuck inside?
SOURCE: CDX-S2000 Volume, Source, and Mode buttons not working????
Hey jshaff, try taking off the detachable front, and you will see a reset button, press and hold in for 10 secs, this should solve your problem. if it doesn't work first time keep trying. you must have power to the head unit for this to work. you will hear the cd make a noise and that should be that, try and let me know.
Posted on Oct 04, 2008
  • 87 Answers
SOURCE: Sony CDX-CA810X / CD-playback drops aux amplifier
Do you have the remote turn on lead hooked up to solid blue wire from the back of the deck? Your amp shoild be hooked up to Bluw w/ white strip as the solid blue wire shuts off when the tuner is off, its used only for the power antenna.
Use Blu w/ Wht strip for amps
Posted on Jun 03, 2009
SOURCE: CD RESET
to fix this problem you have to take the face plate off. There should be a small button on the middle-left side that sais "reset" on it. Get a ballpoint pen and press this button. Pop the face plate back on and play your CD and it should work no problem.
Posted on Jul 11, 2009
  • 27 Answers
SOURCE: Sony CDX-S2210 CD Player stuck on demo mode
make sure the unit is switched off and the clock is displayed then
1 Press and hold (SEL).
The setup display appears.
2 Press (SEL) repeatedly until the
desired item appears.
3 Press the volume +/– button to select
the setting (example “ON” or “OFF”).
4 Press and hold
(SEL).
The setup is complete and the display returns
to normal play/reception mode.
Note
Displayed items will differ, depending on the source
and setting.
With the card remote commander
In step 3, to select the setting, press
< or ,.
The following items can be set (follow the page
reference for details):
“z” indicates the default settings.
*1 When the unit is turned off.
*2 When the audio output is set to “SUB.”
CLOCK-ADJ
(Clock Adjust)
(page 4)
BEEP To set “BEEP-ON” (z) or
“BEEP-OFF.”
SUB/REAR*1 To switch the audio output.
– “SUB” (z): to output to a
subwoofer.
– “REAR”: to output to a
power amplifier.
DIM (Dimmer) To change the brightness of the
display.
– “DIM-ON”: to dim the
display.
– “DIM-OFF” (z): to
deactivate the dimmer.
DEMO*1
(Demonstration)
To set “DEMO-ON” (z) or
“DEMO-OFF” (page 4).
A.SCRL
(Auto Scroll)
To scroll long displayed items
automatically when the group/
track is changed.
– “A.SCRL-ON”: to scroll.
– “A.SCRL-OFF” (z): to not
scroll.
LPF*2 (Low
Pass Filter)
To select the cut-off frequency
“78HZ,” “125HZ” or “OFF
Posted on Jan 29, 2010
Nomodo4u
  • 863 Answers
SOURCE: need a wiring diagram to install cd player
If you buy a wiring harness from this guy he will send you a wiring diagram. Copy and paste the web address2_bing.gif.
Here you go bud:
http://cgi.ebay.com/SONY-wire-WIRING-Harness-XPLOD-XR-CA430-CDX-MP30-sn6_W0QQitemZ200417888633QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item2ea9d64979
Posted on Feb 23, 2010
I got a sony cdx ca810x stereo and none of the face buttons work is there a way to reset it or is there something wrong with the unit please help as I have no money to buy another
Hello... I am sorry to hear you are having problems. You can manually reset the cd player. You can use a pencil or ink pen to press the small button to reset the unit. If you flip the face down it should be there on the actual unit. I should say "reset". This probably will not fix your problem. The other thing you should do is to remove the face and clean the contacts with a q-tip and some rubbing alcohol and see if that will remove any debris that may be hindering a good connection. Make sure the face is attached back onto the unit securely. If after doing this, it is still inoperable, then you will need to replace the unit. Unfortunately, at this point there would be no way to tell if it is the face or the unit itself that is bad, so complete replacement would be the best option. Sony has been good about keeping the same harnesses through many years, so it is possible that if you replace it, get another Sony and it will plug directly in and save you any install and parts costs. Hope this helped!! Good luck with your venture!!
20 year car audio/video installer
Bay manager
Mar 17, 2011 | Sony CDX-CA810X CD Player
I've had my Sony Xplod CDX S2010 Radio/CD player in my Jeep for years and it has all of a sudden locked up on me. The CD player will play and eject CDs, however it doesn't allow me to adjust volume or skip...
i'm not sure if there is a flexible cable that goes from the face to the motherboard. if there is, that could be the problem. it could also be a bad switch.
Aug 25, 2010 | Sony CDX-S2010 CD Player
Jun 03, 2009 | Sony CDX-CA810X CD Player
CD RESET
Jan 16, 2009 | Sony XPLOD CDX-GT200 CD Player
Xplode cdx-gt460u CD Reset Error
REMOVE THE FACE PLATE THERE SHOULD BE A RESET BUTTON ON THE FRONT OF THE RADIO PUSH THAT AND TRY AGAIN IF THAT DOESNT WORK THEN PULL THE RADIO AND DISCONNECT FROM POWER 4 A LIL BIT AND THAT MAY WORK
Dec 29, 2008 | Sony XPLOD CDX-GT200 CD Player
Sony cdx r3300 Won't play...simply scrolls a message
_half fixed, use the remote -@least can get more life outa the unit!
Nov 11, 2008 | Sony CDX-R3300 CD Player
Jun 05, 2008 | Sony CDX-S2000 CD Player
Sony CDX-MP40 only works after hitting reset button
If you dosn't find a solution, then I'am very interested in buying the faceplate for this unit. batman@galnet.dk
Mar 09, 2008 | Sony CDX-MP40 CD Player
Sony CDX-CA810X CD Player Logo
115 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
