Question about Solis Master 5000 Espresso Machine
After using oily coffee beans the machine drops one drop at a time how do I clean the coffee grinder and drip system alos it says after the rinsing cycle 'ventilate' how do I ventilate.
  • 1,089 Answers
Hi
The ventilate is just opening the steam valve for just water. Don't push the button for steam. Your grinder needs to be a little coarser. Turn the big know in the bean hopper to a larger #, about 2 to 4
# higher.
You need to clean the brew head in the brew unit.
Holding the handle, the top left side is the brew head. There is an outlet pipe that exits the front, towards the door (looks like an "L" pipe). 2screws hold it to the top. Remove the 2 screws while holding the manifold ("L" pipe assembly). Once they are removed, lift the l assembly off (be careful, there is an O-ring, spring with a black seal (don’t loose it or your out of luck).
Now remove the brew screen, by holding the screen with your finger and twisting the thumbscrew (remember thumbscrew, DON’T use the key to install the screen, use your fingers...
Once the screen is out, look at where the screen was. There are 2 holes. 1 big one in the center and a small one to the side.
With the brew unit upside down over the towel insert a paperclip into the small hole and force anything out the other side. I have gotten worms almost a 1" long from this passage. The paper clip has to go from this side to prevent damage to the seat on the other side.
Clean then reassemble. Brew unit on towel right side up. Then the spring with black seal down.
Now the O-ring over the spring, then place the manifold on top of that with the pipe towards the handle side. Insert your screws (I turn them backwards a little with a little downward pressure until they feel like they drop into the threads. They should turn down easily, if not back them up a little more ( we are trying to find the old threads) and tighten. Install screen, and tighten with your fingers. The screen just needs to be flush with the bottom of the brew head.
Install in machine and test
Posted on Jul 06, 2010
Our Saeco Vienna Superautomatica sounds like it's grinding beans but keeps running until the red 'bean' light comes on and we have to shut the machine off. Any suggestions?
The grinder is timing out and stops if the beans do not enter the grinder. This happens because:
1- The grinder outlet is clogged and fresh beans cannot pass through the burrs.
2- The grind setting is too fine and helping clogging in the grinding chamber or the ground coffee outlet.
3- Operator may have been using dark roast oily beans. Like it or not, the dark roast oily beans do not make stronger espresso. Please stop using such beans in fully automatic espresso machines.
4- The grinder has already made over 2000 grinds and the burrs are blunted and not grinding beans as needed.
To solve this malfunction, clean the grinder. Make sure the grinder outlet to the doser is cleaned. This outlet passage is about 2 inches or more. To clean it, lay the machine on its back (water tank side) to allow better view of cleaning the doser and the passage of coffee from the grinder to the doser. Use the link below to find instructions for cleaning the grinder and replace the burrs.
Gaggia Titanium and Plus Espresso machines parts and repairs Saeco...
Oct 18, 2014 | Coffee Makers & Espresso Machines
Talea ring the grinder will not stop gringing
The Talea model is with a Ceramic grinder system. This can happen when the grinder outlet is clogged with coffee grounds. Fresh beans cannot enter the grinder as the outlet is clogged. Remember, the grinder in any machine is a grinder. It does not shovel the coffee grounds out and clean the outlet when it is clogged.
1- Check if the grind setting is too fine (powder like). If so change the setting to coarse. Fully automatic machines do not need fine grind. Keep the grind fineness like the table slat grain.
2- Check if the beans are dark roast and oily. Oily beans are a slow poison for any fully automatic machine. Change the beans to Non oily medium roast type.
Oct 16, 2014 | Saeco Talea Ring Plus Espresso Machine
My grinder is not grinding is it blocked?
if you hear it trying to grind, but is not, or hear it spinning and is not grinding, more than likely it is blocked, or so oily that bean will not drop. Coffee beans, have so much oils in them, that after a while it gets caked up, and beans either get jammed, or stuck. If you hear grinder low humming, then it is probably stuck or clogged, if it is on but hear like a spinning sound, beans are not dropping, because they are stuck because of oil build up. If you can get to the grinder, turn machine off, unplug, get all beans out, if turning up side down to do so, get clean dry terry cloth,and start wiping and cleaning, when you feel your done, spray a LITTLE, no much pam in there, refill and try again. As said early if it is a low humming, like motor turning but jammed, do not use until jam is fixed, you will burn up motor, then have more expensive fix. Let me know if this helped and solved problem. Mr Bean Man from Fixya
Jun 12, 2011 | Saeco INCANTO DELUXE Espresso Machine
Grinder blocked
Jun 11, 2011 | Coffee Makers & Espresso Machines
Grinder blocked
Jun 11, 2011 | Saeco INCANTO DELUXE Espresso Machine
How do i reset my gaggia titanium, the gears are in the wrong position
Are you talking about the coffee brewing system? Or the coffee grinding system? You said "gears" so it sounds like you took the coffee bean hopper out and the adjustment knobs come out with it. So if you are trying to line those gear teeth back up correctly, Here is the complete instructions for cleaning the grinder (from wholelattelove.com). You only need the last few steps for lining up the gears.
You do not need to clean the grinder as often as you may think. Usually we do not recommend cleaning the grinder unless there is a problem with calibration or a clog. Avoiding oily beans, flavored beans, and beans stored in the fridge or freezer will typically prevent issues.
If you do experience issues with your grinder, cleaning it is the most common solution. To clean your grinder, follow these directions:
1. Remove the water reservoir, turn off and unplug the machine.
2. Take the cover off of the bean hopper and vacuum out the beans.
3. Remove the 3 Phillips head screws that are in the bean hopper.
4. Lift up the bean hopper and set it aside.
5. Open the machine's service door and remove the drip tray and the brew group.
6. Remove the rubber gasket from the top of the grinder area.
7. The grinder is made up of 2 pieces. The inner piece has 4 tabs that the rubber gasket sits on. The outer piece has teeth in a ring on the exterior covering ½ the circumference.
8. Rotate the outer ring 180 degrees counterclockwise. You should be able to lift off the inner ring. There is a red spot on the outer collar which should now be facing the 9 0'clock position when you are at the front of the machine.
9. Vacuum out all of the beans and ground coffee.
10. If possible, use a small pipe cleaner to get grounds out of the "pathway" going to the front of the machine. It is located on the floor of the grinder at about the 5 0'clock position.
11. Above where the brew group would be located, there is a gray triangular tab attached to a door on a hinge. Pull down on the triangle - coffee grounds may come out.
12. Look above the trap door and you will see the other end of the chute. Vacuum out the chute and clean with a pipe cleaner.
Reinstalling
1. Drop the inner burr onto the grinder with the tab that has the red and blue marks facing the right hand side of the machine at approximately the three-o'clock position.
2. Rotate the outer collar so that the red mark lines up the red/blue marks on the inner burr.
3. Reinstall the rubber gasket that goes over the grinder. The slots in the gasket line up with the four tabs of the outer burr.
4. There is a straight piece located directly to the right of the grinder. This is your dosage control. There is a piece that can slide backwards and forwards on this dosage arm. Push this arm all the way to the back of the machine.
5. Set the knobs in the bean hopper to #0 on the grind setting knob. Set the doser knob all the way to the plus setting. Now place the hopper back into the machine.
Note: You may have to rotate one or both of the knobs, a small amount, to get the bean hopper to set down on its supports.
6. Install the 3 screws.
7. Replace the water reservoir.
8. Fill the bean hopper with a cup of beans.
9. Plug in and turn on the machine.
10. Reinstall the brew group and the drip tray.
11. Once the machine warms up, press the small coffee button. When the grinder comes on set the grind setting to 6.
Note: You may have to press the small coffee button twice or 3 times before the machine will make a cup of espresso.
Sep 24, 2010 | Gaggia Titanium Espresso Machine
Ground coffee piles up before getting to steam unit
HI
There are 2 knobs in the bean hopper. Turn the large knob to the largest number. You can turn the knob to a larger number any time but it has to be grinding to turn to a smaller number. Now replace everything and make your coffee. Once you have made your coffee you can turn the knob back to a number that was higher than the one you had it on, but only when the grinder is running.
If that didn't do it. Sounds like you have a blockage in you grind passage. Try removing the brew group. Then inside on the roof of the machine where the brew unit was setting there is a drop chute where the coffee is dropped into the brew unit. From the left side of the drop chute pull down and back, and it will drop coffee. This will clear an opening that relieves pressure on the passage. There is a passage inside the drop chute area that goes to the grinder. Vacuum it out. It will be on the right side of the drop chute.
Once that is cleared go to the bean hopper and follow the first part again.
Dec 01, 2009 | Saeco Vienna De Luxe Espresso Machine
The grinder runs but does not grind the coffee beans
This fixes almost all the "beans will not feed or beans will not grind" problems caused by coffee bean dust packed in the burrs. Oily beans cause this problem more fequently.
a. Pour all the beans out the top.
b. Open the settings up all the way and see what else can be poured out. Use your shop vacuum to **** grounds out the spout and backward out the bean bin.
c. Pour in some instant rice and start grinding. Reduce the grind to a small setting like six and then open the settings all the way again. (The grinder will not start at a low setting with the rice in it. If you let it stop, open the settings to about 16 before trying to restart.)
d. Pour out the rice and vacuum out the ground rice.
e. Adjust the grinder to your favorite setting and try a coffee grind. Grind until most of the rice dust is expelled (any remaining trace of rice dust will not affect the flavor of the coffee).
Nov 12, 2009 | Saeco Royal Professional Espresso Machine
The machine says FILL BEANS but beans are in it...yes, we did run out of beans but now it won't recognize beans. we cleaned it out, grinded , etc...but it still says fill beans. We also rinsed many times,...
Hi
Oily beans (shiny) can some times stick together after grinding with a fine setting. Try opening the grinder setting to the very coarsest setting and see if it will clear the passage. If you have pushed the brew button an lot of times you may have packed the grounds in the passage which will have to cleaned manually.
Once you have the grinder working again, open it to the coarsest setting to clean the burrs. 1 time is enough. To turn the grind setting back down to your setting make sure that the grinder is running at that time. You can open to a coarse setting any time but it has to be running to finer.
Oct 25, 2009 | Jura Capresso Impressa S9 Coffee...
Solis master 5000 beans get hung up in hopper. machine says no beans, lift lid to find hopper is still full, poke finger into pile to release hang-up, is this normal, should I try to remove small cover...
The coffee that you are using might be very oily and not able to slide over the cover. DO NOT REMOVE THE COVER. Try finding another blend that is not as oily or clean the bean hopper more often.
Oct 06, 2009 | Coffee Makers & Espresso Machines
Solis Master 5000 Espresso Machine Logo
123 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
AZBen
AZBen
gbob59
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
