Question about Toshiba (P000257700) Microphone
My laptop won't detect the built in mic anymore :( It worked before, but now when I try to use sound recorder or anything it says there's no device detected.
  • 96 Answers
Change your microphone
Posted on Jul 07, 2010
I have lg laptop.my laptop biltin mic is not working in my laptop plz give me solution
1. Mic might be disabled/muted in sound control panel - Click on the volume control/sound icon to get the properties
2. For recording you might using another device (e.g. modem)
3. Try recording a sound with built in sound recorder (in Windows it is in START-PROGRAMS-ACCESSORIES-ENTERTAINMENT)
4. Get a new external microphone or a headset wit mic
Jul 29, 2012 | Computers & Internet
In my hp compaq nx7400 laptop,mic was not detect voice how to identify that what's the problem
most of some notebook computer had only mic capturing, when you talk someone on voicechat, they heard you but you can't hear on your notebook built-i speaker. if you want to check., if your mic is ok...try to record voice....using sound recorder of Windows.
Feb 19, 2011 | HP Compaq nx7400 Notebook
How do i get my microphone to work?
Please open the Control Panel and click on Hardware and sound. Now, click on Sound and select Recording tab. In the Recording tab, right click on the empty space and select Show disabled devices. The Microphone should be listed and enabled in Recording tab.
Jul 01, 2010 | E-Machines M2350 Notebook
My mircophone is not working on my MSI laptop
Hello Freshnoble, hi! try first the sound recorder program, for testing purposes, if you are using XP, it goes, start, all programs, accessories, entertainment, sound recorder. Shout on the mic, you should see wave pattern on the sound recorder program. if not. the problem can be hardware and/or software. If its the hardware, check the microphone, is the mic built-in or are you using an external mic? if built in, try to enable first the microphone, right click the speaker on the lower right side of windows, select adjust audio properties, sound, at this point you should see the sound recorder device, select mic volume and adjust it all the way. test again the sound recorder. If you did not reach this point, there is some thing wrong with the device driver, load the sound driver first and test the mic again.
Mar 12, 2010 | Computers & Internet
Audio on Dell Webcam Central And voice record isn't working
I have a Dell 1545 with Dell web cam central & I've had this issue. The problem is that Dell web cam central installs it's own microphone settings onto your laptop called something like Dell web cam Live!. This isn't the built in microphone in my laptop & maybe not yours either. You have to change the settings for your computer system & Dell web cam central. Go to start> control panel> sound> recording .. on mine there is an option for Microphone "High Definition Audio Device" ... that is the built in mic. You want that for your default & apply it. Also .. as a side note .. I disabled the web cam central Live! microphone completely from this window. Then open Dell web cam central & go to the "Record Video's" option. In the middle of this is an orange button with a video camera icon. Next to this on the same button is a little arrow pointing down .. click that. Under microphone .. choose Microphone "High Definition Audio Device" just like the sound option in control panel. I've done this & it's completely fixed. I can record videos with sound & use my built in mic in voice/video chat.
Aug 15, 2009 | Dell Inspiron 1545 Notebook
My dell inspiron 1525 has a built in disarray mic but computer does not detect it??I've tried downloading the sigmatel driver but it says object not found. The webcam center does not give me any options...
Uninstall and reinstall the audio drivers. That should fix it. Also check in Audio/Sound properties in Control panel under Recording and check if the Array mic is detected and set as default. Try downloading "http://ftp.us.dell.com/audio/R171786.exe"
May 18, 2009 | Dell Inspiron 1525 Notebook
Acer Aspire 7720 built-in microphone not working
In the sounds control panel, right click in the area which should show recording devices. Select 'show disabled devices' and bingo!
Feb 25, 2009 | Acer Aspire 7720 Notebook PC
Hp Dv6000, problems recording with built in microphones
go into your device manager and disable the onboard microphone
Feb 13, 2009 | HP Pavilion dv6000z Notebook
Cannot record sound
Normally every Lap is coming wit internal mic; so
1- Simply check your mic is mute or not
2 - Check your mic volume
3 - Use sound recorder that comings with windows (just record & play)
4 - Use an external MIC (known as working) with sound recorder
5 - Check in control panel->sound and audio device --> default recording device and Voice recoding device as your system’s built-in audio device (some times it’s changing when we installing b-tooth deice)
6 - Check device manager --> under sound audio controller for any issues
7 – Uninstall & install completely your Audio Device driver with default settings.
** If you didn’t solve your prob; my advice is take your lap to a good technician with component level Repair skills.
Thank you & Best Regards
Dinu..
Dec 20, 2008 | Toshiba Satellite A215-S4697 Notebook PC
For Vista:
1) go to Start > Control Panel > Sound
2) click the recording tab
3) Right click the device that is not the new one you bought.
4) choose Disable
For XP:
1) Right click My Computer or go to Start > Control Panel > System
2) On the system window click the hardware tab
3) Click the Device Manager button
4) Scroll down to the Sound, video and game controllers.
5) Look for any device that is not your new mic as well as your sound card.
6) Right click and disable anything that are not the mentioned above.
7) Exit and test.
If you have XP and the XP Method above doesnt work then please make a comment stating so so I can give you another solution.
Dec 17, 2008 | HP Pavilion dv9000z Notebook
986 people viewed this question
Top Toshiba Audio Players & Recorders Experts
Electro Med Services...
 Grubhead
Grubhead
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
