Question about Fisher and Paykel 24 in. DS603H I Built-In Dishwasher
First drawer is dead not working at all
The upper drawer is not working at all. when i pressed the start button there is not light its totally dead.
  • emtoravi Jul 06, 2010
    i will try to open this and check..can you tell me hoe to open the front thanks.
  • Fisher and P... Master
  • 3,247 Answers
If the bottom drawer is working fine and the problem is only with the top drawer then the most obvious problem seems to be with the top drawer controller module. This sits on the right side in the front of the drawer. You have to take the front cover off to get to it. The cable connectors could be loose. If pulling these out and putting back in does not help then the controller needs replacement. You could try using the one from the upper drawer. But if this makes no difference then the thermal fuse under the heater assembly could have blown. Unforturnately this requires replacing the whole heater assembly as the thermal fuse is not separate.
Make sure you turn the power off at mains when working on the unit.
Can you confirm the model is DD603 and not DS603 which is the category showing on fixya.com for your query.
Let me know how far you want to go with this before calling the technician.
Posted on Jul 06, 2010
    its a black double drawer.
  • Sam Jul 07, 2010
    There are two plastic bolts on each side of the dishwasher holder the front cover. Get a plier to pull these out but make sure the cover is supported so that it does not fall down.
    see installation manual page 7. The location of the plastic screws is shown in insert diagram of notation 6.
    Hope this helps.
I cant set the time on my adidas duramo watch. It says 'offset' and below it says '1H'
This has already been posted on Fixya, so I take no credit for it. I've put the original reply below :-
Directions for setting the time on the adidas duramo / furano / uraha / paruko watch 1. press and hold the SET/LIGHT button (upper left) until "light on" or "light off" is displayed 2. press the MODE button (lower left) until "hour" is displayed and the hour digits are flashing 3. use the START/STOP (upper right) button to increase the hour, and use the LAP/RESET (lower right) button to decrease the hour 4. press the MODE (lower left) button again and "minute" is displayed and the minute digits are flashing 5. use the START/STOP (upper right) button to increase the minute, and use the LAP/RESET (lower right) button to decrease the minute 6. press the MODE (lower left) button again and "second" is displayed and the second digits are flashing 7. use the START/STOP (upper right) button or the LAP/RESET (lower right) button to set the seconds to "00" 8. press the SET/LIGHT (upper left) button to accept the changes
Aug 31, 2017 | Adidas Watches
Sudden death
Mostly looks like hardware problem with your laptop as no lights are turning on.Check if power button is turned on.if its still unresponsive then conatct dell support.Below is the link for dell support:
http://support.euro.dell.com/support/index.aspx
Regards,
Rahul
Jul 14, 2013 | Dell Vostro 1700 Notebook
Dishwasher bottom part works top part all lights are on and wont work
I'm assuming its a fisher and paykel, you will certainly need more info. Do you have an led display or 3 buttons and lights. Any fault codes, flashing beeping when buttons are pressed etc. If everything is normal no unusual beeps lights etc but nothing AT ALL happens when you press start it is the door 'switch' which is actually a light that is reflected through a plastic prism and back to itself ( originates from the board) check the prism top right drawer frame. Just compare to working drawer. If not more info required.
Jul 07, 2013 | KitchenAid Dishwashers
DD603 model & top drawer totally dead, no lights but bottom drawer 100% Your thoughts plse.
possible causes
  • top drawer controller has lost power - replace power filter plate located at the base of dishwasher under bottom drawer controller
  • itself is faulty if you are getting some lights on the panel
  • thermal relay has tripped. It is located inside the heater element at the base of the drawer. The whole heater needs to be replaced.
Make sure the dishwasher is disconnected from the mains power supply when working on it
Jul 26, 2012 | Fisher and Paykel Dishwashers
Set time on adidas Adults' Performance Duramo Watch
Mar 15, 2012 | Adidas Watches
Jake is getting 5 cash drawers ready for the day. He takes 650 $20 bills and 725 $10 bills out of the vault. He wants to divide the money evenly between the cash drawers. How much money should he put into...
Since he has $20,250, he should put $4050 into each drawer.
To get the total amount, multiply 650 by 20 and 725 by 10, then add the two numbers together. To get the final result, divide the total by 5. Since you didn't specify the make and model of your calculator, I'm afraid I can't give you the sequence of button presses to calculate this.
Jun 23, 2011 | Office Equipment & Supplies
Honda civic 2008 - panic button on the key
Placed jumper cables on the car to try & jump alarm sounded pressed the unlock button & was then able to start car without any problems.
Mar 12, 2009 | 2008 Honda Civic
Kawasaki zzr400 (1994 model),streetfighter wont start
check starter solenoid.see if getting power to starter side when pressing button .if yes check if power to starter w/ test light when pressing button.if power there check starter,also motor, will it turn manually or is it seized.if no power to starter side of solenoid, jump across solenoid posts w/ a large screwdriver -motor will probaly turn over,w/ key on.if small wire to solenoid has power when pressing start,solenoid bad,if no power, wiring or start button bad.
Jan 22, 2009 | 1997 kawasaki ZZR 400
Top drawer has no electrical power
I f lock is activated during wash the draw will appear dead when wash cycle finishes ,check for lock symbol in lcd display if it is visible press lock button for about 5 seconds until you hear beep release button and try POWER button
Aug 23, 2007 | Fisher and Paykel 24 in. DD-602 Built-in...
Fisher and Paykel 24 in. DS603H I Built-In Dishwasher Logo
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
