Question about Nikon Coolpix S210 Digital Camera
Lens error the lens won't go back, and I cannot do anything with the camera shows lens error or black screen
  • 4,102 Answers
Hi, the chances are the motor that operates the lense has quit working or it could just be stuck with some grit, what you can try is this.
if you get hold of the biggest part of the lense and try turning it slightly now not the furthest part out as this just moves in and out but if you try turning the piece that is closest to the camera it may just free it up, try turning it whilst turning the camera on and off you only need to get it to turn slightly and this should free it up. or you could try pushing the furthest part of the lense in or pull it out slightly doing this may free it up also.
you may need to use slight force when trying to turn the part nearest the camera, but if after trying both of these methods it still dont work then this would point towards the motor failing and the only option would be to have the motor replaced, how ever the cost of repair would more than likely cost as much as the camera so you would need to shop around and check if the part was worth getting repaired or not.
Posted on Jul 06, 2010
jackboy
  • 2985 Answers
SOURCE: Lens error
If it is a new[ish] purchase send it back via the seller. It may be an issue with the particular model. Get onto Pentax Tech support Team- See what happens- if it is an issue then a replacement free or at moderate cost may be available. If the camera is older -there will be no economic repair option.
Posted on Jun 21, 2007
SOURCE: Black Screen
I have the exact problem. I came on slowly, some days it would work, some days it wouldnt. Finally i couldnt get it working at all. Sent it back to Kodak as it was still under warranty, the repair center claims it was "physical damage". They admit that the camera shows no evidence of falling or banging but it doesnt matter. The camera was lightly used only by my wife, she took good care of it. I'm currently fighting with Kodak, they are requesting photos from the repair center, so they claim. I think its lost cause, but we'll see.
Posted on Oct 03, 2008
  • 102366 Answers
SOURCE: (lens error) my camera lens wont go back in
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Feb 23, 2010
  • 420 Answers
SOURCE: Lens error
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
  • hit the part near lens softly with palm (trust me this made mine work)
Posted on Sep 11, 2010
SOURCE: Canon SC100 Lens Error
There is a major technical fault in the design of Canon cameras. Canon refuse to fix the problem under warranty and are forcing consumers to pay for expensive lens repairs.
If you have experienced a similar problem with your Canon camera, please add your story to the petition
http://e18.bitnet.cx/comments.php
Peter
Posted on Jan 16, 2011
Sony cyber shot dsc h200 lens is stuck, will not take pictures. says to turn off and turn on again, but does not work.
Hi Susan,
If you cannot find the power button, just simply remove the battery wait for few seconds and put the battery back. What I assume of this behavior is 'If the coming out lens is obstructed by anything' the camera will show such error. If it does again, I would suggest calling Sony and getting their advice. Regards
Feb 27, 2014 | Sony Cyber-shot DSC-H200/B 20 Megapixel...
I damaged the lens of my dad's nikon coolpix S220, should i get it repaired or try something on my own
This is a specialist repair, I suggest you take it to a Nikon camers repairer.
May 10, 2013 | Cameras
Camera lens won't shut
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error" (older Canons), "ACCESS" error (Sony), "Zoom Error" (Fuji), "Lens Obstructed" (Kodak), "lens error, restart camera" or just "lens error" (nearly all camera makers lately use this variation). Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Jul 28, 2012 | Samsung Digimax S500 Digital Camera
I have the same problem this guy had: I have a Sony Cybershot 8.1 megapixels. Every once in a while the screen will turn black when I turn the camera on. The display will come up (shaky hand, flash, etc.)...
The camera either has a stuck aperture inside the lens or a bad CCD sensor.
The aperture is the opening that allows light to enter the lens. If it's stuck closed no light goes in, so no display on the LCD and solid black pictures. The way to fix it is to replace the lens. You can try tapping or banging the camera on it's side on your hand or even gently on a table. This might unstick the aperture for a short time, but it will just stick again later.
If the CCD is bad the sensor won't show anything other than solid black, or sometimes purple/pink smeared lines. Again the solution is to replace the lens assembly, or look for a used CCD online and just switch that out instead.
Hope this helps!
Thomas Drayton
Owner, Darntoothysam.com Digital Camera Repair
Jul 12, 2011 | Sony Cyber-shot DSC-W100 Digital Camera
Lens is stuck (halfway out) and screen shows "lens error" and won't do anything
Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 30, 2011 | Nikon S8100 Digital Camera
My camera was dropped and now when i turn it on it beeps and then the screen goes black and says e18. i would like to take it apart since i have nothing to lose. do you have anything that shows how to do...
E18 error refers to a lens error .Try checking if any dust got on the lens barrel if not check with the Canon dealer for a replacement as this is might be a factory fault
Mar 31, 2011 | Canon PowerShot A400 Digital Camera
My screen keeps turning black
It's the lens that cause the problems.If parts are available, try replacing it.
Oct 18, 2009 | Nikon COOLPIX L18 Digital Camera
The screen reads "lens error, restart camera. I can not get the lens to retract. I can not get the power to stay on. The cannon screen shows up momentairly - but fades to black and the message appears.
remove the battery, let it sit for at least 2 hours, then put it back. put the batteries back, then gentle push the lens sideways to free its stuck part. if the error still occurs and the lens is not retracting, consult the warranty for the device as the lens assembly gears may be at fault.
regards,
voodoo
Aug 12, 2009 | Canon PowerShot SD1000 Digital Camera
My Canon Power Shot A80 Digital camera goes ON but only shows the screen name Canon then the lens goes back into off - some sounds come on and then E18 shows in the lower left of a black screen. Help.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Jul 09, 2009 | Canon PowerShot A80 Digital Camera
E18
The following blog outlines some repair options for an E18 lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
It's important that you fix the E18 error first, as the blur of colors may be symproms of a failing CCD. If so, Canon would fix this for you for free IF the camera has no other problems (ie no E18 lens error). Please see the following info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
May 27, 2008 | Canon PowerShot A70 Digital Camera
Nikon Coolpix S210 Digital Camera Logo
420 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
