Question about Ovens
We had a power cut which has affected the power of the oven. Power is now on, lights are flashing but, as i have lost my manual i don't know how to get things started.
  • jackiekaye Jul 06, 2010
    had a power cut today, the oven lights are flashing but there is no power. how do i reprogram the panel to get the oven to work?
    i have a simpson evolution 844 multifunction oven. The power in the house went off today and has caused the oven panel to have flashing lights along with the oven not to work. Could you help?
  • Ovens Master
  • 17,970 Answers
Tell us the brand and model to check info, PLS.
Posted on Jul 06, 2010
    its a Simpson, Evolution 844, multifunction oven
    have you found a solution to my problem yet?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To start with unplug the oven and plug it back after 10-15 minutes, if still the issue is not resolved then the control panel has gone bad and needs to be replaced. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
    the board is not the problem... this has happened before and started working as we worked off the manual, but as i do not have the manual i need assistance is reprogramming. If you can't help, please put me onto someone who can.
  • Rylee Smith
    Rylee Smith Jul 06, 2010
    Have you unplugged it? If you have the please post a comment with the manufacturers name and model no# of your Oven
  • 1,711 Answers
Can you give some more details of the oven, brand, model, year e.t.a.
Also have you try to do anything and what happent.
  • Michael Willaman
    Michael Willaman Mar 27, 2014
    Model number RF361PXKQ. I have notused since 2 days ago and tried to turn on and lights show on but no heat from burners or oven. It never showed any sounds or falshing. it was on PF and when I set clock was ok.
Main oven not working following a power cut. Timer flashing AUTO and clock control buttons not working
The auto function will cut off the power to your oven try switching the oven to manual control to reset the control.
Apr 26, 2015 | Ovens
I have a stove built in oven and had a power cut and it keep flashing 8888 and wont work
Hi.
After power cuts most ovens need resetting, for this reason 00:00 is flashing. The operation is described in the specific model's user manual. Most ovens reset either pressing or holding down for few seconds a Clear or On button, or holding down the main control knob.
Aug 06, 2011 | Ovens
We had a power cut, now I can't get the oven to work the auto light is flashing but when I turn the knob for the oven it won't come on.
You need to reset the oven from auto to manual setting.
This is done by pressing 2 or more buttons on the timer at the same time to reset it, until you do this, the oven will not work
Feb 17, 2011 | Tecnik TKC8085 Electric Double Oven
I replaced the flash timer on my oven and the power still does not come on what else could it be???
Is the electronic timer in the manual mode?
Is the element faulty?
Poor connection at the oven element terminals?
No voltage output from the oven thermostat control?
The oven thermal cut-out switch has operated and cut all power to oven?
Feb 08, 2011 | Frigidaire Ovens
Hi. I think I've had a power cut and my Stoves oven (about 10 years old) Is not working. The clock is flashing and the main oven won't switch on. I'm sure this has happened before but can't...
The clock is on auto because of power cut, you need to reset it to manual to enable the oven to work as normal. Refer to your user instructions.
Oct 15, 2010 | Stoves 720EF Electric Double Oven
Reset clock and oven light came on flashing
THERE IS A PROBLE WITH THE ERC (CLOCK) NOT TO SURE IF I WOULD USE IT EITHER. THE PART IS EASY TO CHANGE JUST TURN POWER OFF AT THE BREAKER FIRST. YOU CAN FIND THIS PART HERE.
http://www.searspartsdirect.com/partsdirec
Apr 22, 2010 | GE Profile JTP18 Electric Single Oven
Oven pilot went out due to power outage. I don't know where the pilot oven light is. where is the pilot light to light the oven?Ge XL44
pilot over lights do not require power to stay light or should it go out in a power outage! do you have to normally light pilot with a match? if not you have a glow coil and its a electronic ignition range and power will affect it. once power is restored you should just be able to turn on over and everything would be ok.if it is a pilot light you need to remove the bottom door stick arm in to back and you'll see the pilot assembly at back if you look up! hopethis helps...
Feb 06, 2010 | GE Ovens
My question concerns a Kenmore glasstop electric oven (model #790.95200100). While operating the oven at 450 degrees and the back right burner at level 5, I heard an audible "pop" and saw a flash of light...
After letting the stove cool, I pulled the entire unit out from the wall and discovered scorch marks on the wall. Opening the back panel revealed a simple fix: the "element on" light module had shorted and was visibly scorched and melted. Looks like a simple replacement (and some wire stripping where the leads fused). Stove currently works with the affected wires capped off (while I await a replacement module).
Sep 14, 2009 | Kenmore Ovens
Creda europa solar plus double oven
Hi, hold down the minute and cook button and at the same time hit either the plus or 1 button to set a time and then oven will work. each time the power is off this needs to be done. hope this helps
Dec 02, 2008 | Ovens
Is 10mm cable ok from 4kw oven to connector unit
A bigger cable size (larger diameter conductors) will not affect power requirements of the stove. (A smaller one definitely will)
Regards
Nov 16, 2008 | Neff U1721 Double circotherm Electric Oven
Ovens Logo
163 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
