Coolmax CD-509-U2 returned an error on a request to write data to the media (used as a backup device). Error reported: Invalid Command There may be a hardware or media problem
    Novelist:
  • 150 Answers
Sounds like the devices is not mounted for some reason.
Hardware, Driver ....
Posted on Apr 18, 2008
  • Martin J Stadler
    Martin J Stadler Apr 18, 2008
    My solution was appropriate although perhaps too brief.
    Windows often returns a nondescript: "Invalid command" errors when it has a problem reading from or writing to a mass storage device, such as hard drive or a CD/DVD burner.
    This means that the logical data channel leading to this device is somehow disrupted or broken. Unfortunately there are many reasons for this to happen, for example:
    In the case of removable devices, such as your USB box, the device is logically "mounted" when the devices is plugged in and "dismounted" when it is unplugged. This means that windows accesses the corresponding device drivers, and creates a stack of software subroutines to handle the data transfers. This is a very complex, nested structure of layered program code, similar to that of a military command structure, with many opportunities for error. The problem is that Windows does not identify the exact error that caused the problem.
    Possible causes are:
    1) The USB link has failed, either through hardware or software (driver)
    2) The device driver uploaded from the USB device has failed
    or collides with another driver in resource allocations
    3) The windows device driver has failed for the same reason
    4) The physical drive has failed
    5) The media in the drive, hard or removable is corrupt.
    6) The media is read protected and you are trying to write to it.
    7) Another, unrelated windows error is causing a device conflict
    8) You have a virus or a root kit, such as the infamous SONY rootkit, which was designed to permanently alter your computer in order to prevent you from copying music CD's
    9) You may have a similar rootkit installed by a video game, such as the "STAR-FORCE" anti-piracy rootkit, which again will corrupt your device drivers.
    In order to fix this you need to isolate the failing device: The drive
    or Windows on your computer. Try the drive on another machine. If the problem moves with it, it's the drive. Otherwise save your data, reformat the machine and re-install windows.
    You may want to try a reputable anti-virus/ anti rootki program before you do that.
    Rootkits, by design, are extremely difficult to detect or remove, because they exploit operating system weaknesses and inconsistencies to make themselves invisible from the operating system as well as from anti-virus programs. Some-kits can even corrupt the firmware inside the physical drive. This is the latest state of the art in computer malware.
    I hope this is more helpful
    Martin
What is the u2-05 problem
U2-05 :HDD/MFP PWB SRAM contents
inconsistency
Trouble content
DetailMFP
Cause:
The HDD or the MFP PWB which differs from that
before turning OFF the power is installed.
HDD trouble.
MFP PWB trouble.
Check & Remedy:
Use SIM16 to cancel the error.
If there is backup data (export data by device cloning),
import it.
Mar 12, 2015 | Sharp MXM264 Copier
Tip
COMMON FTP ERROR CODES
~~~~~~~~~COMMON FTP ERROR CODES~~~~~~~~~~
# Description
110 Restart marker reply. In this case, the text is exact and not left to the particular implementation; it must read: MARK yyyy = mmmm where yyyy is User-process data stream marker, and mmmm server's equivalent marker (note the spaces between markers and "=").
120 Service ready in nnn minutes.
125 Data connection already open; transfer starting.
150 File status okay; about to open data connection.
200 Command okay.
202 Command not implemented, superfluous at this site.
211 System status, or system help reply.
212 Directory status.
213 File status.
214 Help message.On how to use the server or the meaning of a particular non-standard command. This reply is useful only to the human user.
215 NAME system type. Where NAME is an official system name from the list in the Assigned Numbers document.
220 Service ready for new user.
221 Service closing control connection.
225 Data connection open; no transfer in progress.
226 Closing data connection. Requested file action successful (for example, file transfer or file abort).
227 Entering Passive Mode (h1,h2,h3,h4,p1,p2).
230 User logged in, proceed. Logged out if appropriate.
250 Requested file action okay, completed.
257 "PATHNAME" created.
331 User name okay, need password.
332 Need account for login.
350 Requested file action pending further information
421 Service not available, closing control connection.This may be a reply to any command if the service knows it must shut down.
425 Can't open data connection.
426 Connection closed; transfer aborted.
450 Requested file action not taken.
451 Requested action aborted. Local error in processing.
452 Requested action not taken. Insufficient storage space in system.File unavailable (e.g., file busy).
500 Syntax error, command unrecognized. This may include errors such as command line too long.
501 Syntax error in parameters or arguments.
502 Command not implemented.
503 Bad sequence of commands.
504 Command not implemented for that parameter.
530 Not logged in.
532 Need account for storing files.
550 Requested action not taken. File unavailable (e.g., file not found, no access).
551 Requested action aborted. Page type unknown.
552 Requested file action aborted. Exceeded storage allocation (for current directory or dataset).
553 Requested action not taken. File name not allowed.
on Dec 03, 2009 | Computers & Internet
Coolmax HD-360B-U2 USB 2.0 External hard drive shows up on computer but I can't see anything that is saved on it. computer shows that there is data being used on device but when I open it, it says the...
Click start control panel scroll to folder options view place a tick in show hidden files folders and drives
this may vary depending on your operating system
Feb 16, 2014 | Coolmax HD-360B-U2 USB 2.0 External Drive...
Need command prompt for Acer Aspire
The Windows Backup and Restore feature allows you to save files and system images to external backup devices such as hard drives and flash drives. However, backing up files become problematic if the directory your backing up files from isn't configured properly, or if you're having issues with the devices you're backing files to. There are ways to solve or work around backup problems quickly and safely.
Hard Drive b> A backup will not complete if the files you're backing up exceed the amount of space left on the external hard drive. If you're backing up large system files, Microsoft recommends saving the backup to an external hard drive that can hold at least 200 GB. If you're running out of space, you must delete content to create space for others or use another hard drive. Error Codes In some cases, Windows displays the following error codes when it's unable to complete a backup: "0x80070001 (Invalid Function)" or "0x81000037: Windows Backup failed while trying to read from the shadow copy on one of the volumes being backed up." These error messages usually appear if Windows is unable to backup a specific library or if you opt out of adjusting your backup settings and settle for the default settings in the Windows Backup and Restore Feature. Reparse Point b> If you're unable to backup a specific library and run into error code messages, removing the reparse point allows you to complete the backup. A reparse point is a file that contains information about the user on a computer. If it doesn't point to a location that contains some of the data you want to backup, error messages appear when you try to back up your files. Type "CMD" in the Start Search box to open the Command Prompt. In the Command Prompt, typing "DIR /AL /S" and pressing Enter lists the reparse points. Each entry says "JUNCTION," which also means reparse point. The entries also tell you the location of the reparse points in Windows Explorer. If you locate a specific reparse point in Windows Explorer, delete its mounted volume from the device's Properties. Once deleted, you should be able to back up your files. Discs b> If you're backing up files to a disc, you'll run into problems if the discs are non-rewritable and already contain data, or if they are severely scratched or damaged. Non-rewritable discs can only be used once, while rewritable discs can be used to read and write data several times. If the CD or DVD you're using is severely scratched, the optical disc drive spins harder than usual in an attempt to read it. If it's incapable of reading the disc, the backup feature may freeze or display an error.
Windows backup or restore errors 0x80070001, 0x81000037, or 0x80070003
http://support.microsoft.com/kb/973455 - workaroundissue12
Apr 20, 2013 | Computers & Internet
My HD SAMSUNG HM500JI not work any more bad sector that cany be fix...!!!
Well.. I'm SAD to inform you..your drive has encountered a serious error.
There's a couple of options..none of which you will like.
Drives (SMART) report errors, but sadly don't fix anything. Once a bad-sector has been encountered, its usually an indication of major failure (google/39% of all drives w/bad sectors major failure..etc)
Your options.. Is your data super important--if so, STOP using the drive, send it to a DRC (Data recovery Center), expect to spend $600-1k for the data.
If you've backedup, good news-- drives are cheap.. buy another, plus your drive into tthe 2nd slot, copy off what you can..
the drive itself is having a major failure (meaning it cannot relocate the bad sectors any longer, hence the smart failure)-- meaning-- drives "TRY" to relocate (when they detect failures, they'll move the data else where, mark the bad area, and use a new spot)... Your drive has probably done that.. ALOT. And now... it's gone critical.
BEST solution for you, to save $$ and time.. but a drive ($80-150 bucks)... install your os... put the other drive on the other cable, copy off what you can..and call it a day.
A DRC won't do much more to be honest... if its SUPER critical, contact www.deepspar.com and see if they will recommend you to a DRC locally to you, or do it them selves...again $$$
Oct 16, 2012 | Samsung HM500JI 500 GB SATA Hard Drive
SAMSUNG HM500JI
Bro, when you see "SMART overall-health self-assessment test result: FAILED!" then this hard drive is either dead or dying. There isn't much you can do other than replace it now.
Hello i have a problem with my nokia 3110c whitch is : when i flash my phone with phoenix i got this result : Flashing started Creating product data items list Product data items list created Backup...
Now what is the condition of the phone ? If the phone has still problem, uninstall the previous file you have installed and re-install this one3110c file.Select the product code 0544311 or 0556977.This two files can use universal.Use fully charge battery or insert charger when message prompt.I hope there will be no error.Thanks good luck.
Aug 16, 2011 | Nokia N70 Cellular Phone
Master hard disk s,m,a.r.t.status bad,backup and replace
A failure message from the SMART system of this nature indicates that a catastrophic hard drive failure could be imminent. Without delay, back up ANY data you want to keep. This error isn't going to go away, and is being reported by the drive controller.
Whilever you can access the drive, move any data you want onto another media (such as DVD or external USB hard drive) because chances are it's not going to work much longer. You need to look at buying a new hard drive as soon as you possibly can, and migrating the data to it.
Files and Settings Transfer Wizard will be able to backup your data to another media.
Jun 02, 2008 | Computers & Internet
System State not successfully
This is common in the following OS.
• Microsoft Windows Server 2003, Web Edition • Microsoft Windows Server 2003, Standard Edition (32-bit x86) • Microsoft Windows Server 2003, Enterprise Edition (32-bit x86) • Microsoft Windows Server 2003, Enterprise x64 Edition • Microsoft Windows Small Business Server 2003 Premium Edition
This problem occurs when the following conditions are true: • You back up data from a volume that contains a Microsoft SQL Server database. • The recovery model of the SQL Server database is configured to use an option that is different from Simple.
Submit a request here to get a hotfix from Microsoft ( Its free and no product key will be asked )
http://go.microsoft.com/?linkid=6294451
Feb 18, 2008 | Microsoft Windows Server Standard 2003 for...
Computers & Internet Logo
90 people viewed this question
David Payne
David Payne
