Question about ASUS (r) Vintage-AE1 Desktop Barebones PC (2741028)
I have no image anymore on the screen. There is `No Video Output`on the screen. I changed the battery for the Bios, but still no go.
  • 107 Answers
Try replacing your graphics card with a known good one to see if that is the problem, also check your screen is ok by running it on a known good PC.
Posted on Jul 06, 2010
Blank screen
  • With the computer on, use a flash light to inspect the screen. If you can see a very faint image then either the inverter board is bad or back light. Usually its the inverter.
  • If you get nothing, plug an external monitor and toggle the display to it. If you get output then your screen is bad or possibly a loose video cable.
  • If you get nothing, power off, pull battery pull all memory out. Power on computer. If you get BIOS and a no memory error, one of your memory modules is bad.
  • Still nothing, then the motherboard is bad.
Jan 29, 2013 | Acer Veriton Z290G 185 320GB
My screen dont light on my aspire 7250
I have just fixed an Aspire 7250 with following symptoms: Only blue Power LED or battery charge LED come on, fan spins, no backlight, no video either on internal screen or VGA output.
Problem solved desolderig BIOS flash chip (W25Q16) and flashing BIOS 1.10 with an universal programmer.
Aug 06, 2012 | Acer Computers & Internet
EeeBox PC EB1007 doesnt boot
Don't assume that a lack of video is a bios issue. I'd first look at the monitor and then the video card.
Use another monitor to check the output. Unfortunately, your video circuit is integrated with the motherboard. Unless you have a PCI card to put into the computer, you won't be able to easily identify a video problem.
I have seen, though, a bad power supply affect the video output so that is an area to check.
Apr 20, 2012 | ASUS EeeBox EB1007 (EB1007B003F) PC...
Ok i change the bios settings i do stupid stuff with by bios settings i also change some values after changing settings i restart my computer desktop. after i restart just black screen came my keyboard...
Probably what you have done is disabled the default video or changed the default video output. If you have both on-board video and an add-on video card, try moving the monitor cable to the other video connector (assuming the hardware for both is functional and you did not install a video card because the on-board video failed).
If you go to the support page on the motherboard manufacturer's website, you should be able to find the manual for your motherboard. In that manual the procedure to reset the BIOS will tell you how to find the jumpers on the motherboard used for that task. Most of the time you pull a jumper off a certain pair of pins and place it on a different pair of pins for ten seconds, then put the jumper back where it was. This is done with the computer turned off.
Another way to do to reset the BIOS to factory defaults is to remove the clock battery, wait about a minute, then put the clock battery back in. You will have to reset the time and date, but that is not usually difficult.
Jan 23, 2011 | Computers & Internet
Netvista 6350 lost screen connection after BIOS password reset
If there a separate AGP Video Card in the system? If so, is there also a VGA connector on the motherboard? If you have both, try swapping the screen over to the other one. You may have reset the default video card back to the motherboard.
However, it looks as though you are using onboard video as you appear to be using 256Mb shared RAM for the video memory as your total should be 1536Mb.
In that case, you may need to do a rurther BIOS reset. You can find the complete instructions here
Nov 28, 2009 | IBM NetVista PC Desktop
Video loss
Have you checked your BIOS settings in regards to Graphic/AGP controls? If it is NOT set on auto (which will read a AGP or PCI graphics card automatically over the on board) it will always look to the onboard card or known PCI Graphics card for the video output. Check those settings and reboot. Remember to save the bios config prior to changing anything.
You haven't brought up a blue screen error so we must assume you installed the drivers properly. The BIOS control of the AGP and graphics is most likely the problem.
Jun 03, 2009 | MSI K8N Neo2-F Motherboard
No video output
get a screw driver un do ur hard drive and slice the **** out of it
Sep 01, 2008 | Microsoft Xbox 360 Console
Auto image adjust
This problem has existed for 4 or 5 years, and I've seen various solutions posted with inconsistent results. Did the problem begin
after a power failure or surge, by any chance? In my experience, this can be related to a setting in the BIOS (Basic Input/Output System) of your motherboard, which can sometimes be affected by power glitches. Try this:
Access the Setup menu of your BIOS. This can only be done during the first few seconds after starting or re-starting your PC. Usually there will be an instruction on the logo screen telling you what key(s) to press to get into Setup (usually F2, F12, or a key-combination, depending on the manufacturer). This screen goes by pretty quickly, so you have to be fast. Once you're in the BIOS setup menu, use the arrow keys to navigate to a category called "Video" or "Display" or "Graphics", etc. (again, depending on the brand). Press "Enter" to view the screen adjustsments for that category. If the graphics controller is set to "Auto", change it to "Onboard/PEG" or some similar term. (If you don't have an alternate graphics controller, you're out of luck.) Follow on-screen instructions for changing and saving settings. When you exit the BIOS, be sure to select "Exit and Save", not simply "Exit." See if that works.
Jun 26, 2008 | Computers & Internet
ACER ASPIRE 3000
What new softwares or updates have you just done on the Aspire 3000,You need SP 2 Updates to function properly...
Change cmos back to default and then reboot
don't touch cmos anymore
FOLLOW THESE STEPS
after start up.
go to desk top
right click on the desk top
properties
display properties opens on themes
select settings
Now with Both screens attached and powered up
box 1 displayed will allow you to adjust the properties here.
Adjust to the smallest settings first should be 800x600
and this will allow you to independantly set sizes of image for each screen.At 800x600 both screens will be identical in size in the menu box.
Screen Number # 1
click Idendify,& number 1 should appear on your screen
click advanced
select compatibilty click apply without restart and OK
Screen Number # 2
DO the same process as Screen Number # 1
image size here needs to be 800x600 too
If your video does not run it will be the screen settings I have just talked about unless you have other softwares as a default.
Remove the other softwares and try again.
You should be able to save the settings for a dual output or set output to individually operate either or.....
I hope this helps your situation,
Please rate me or if you need more help just ask thanks
Jun 21, 2008 | Acer Aspire 3000 Notebook
P4M-915G/PD1 no screen, no BIOS, only power.
Do you hear any beeps at all? Do you have a system speaker on the motherboard? If not, plug a 2-pin system speakers onto the motherboard where it says "speaker" and listen for some beeps. You may have a fried CPU or dodgy RAM on your hands. Possibly even a faulty AGP/PCI-E slot, to name a few.
Sep 07, 2007 | FIC P4M-915PD1 Motherboard
ASUS (r) Vintage-AE1 Desktop Barebones PC (2741028) Logo
67 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
