Question about Yamaha Audio Players & Recorders
Have a HTR-5360. Needs a firmware update. Pushing
Have a HTR-5360. 7.1.Needs a firmware update. Pushing On and Straight sometimes shows code, sometimes does not. Even when it does, it won't show Upgrade CDDA when I push On and Info as told to
  • 4 Answers
SOURCE: Archos 604 Wifi Recovery Code 2
hello everybody, i had this same problem with my archos 604 wifi but thankx to someone on another forum i fixed it. it is really easy:
first you take the battery off, then you unscrew the 4 or 6 screw on the sides of the hard drive, then you lift the lid and then the hard drive, VERY CAREFULLY, Then you will see the problem : the little black plug conected through a ribbon to the hard drive is not plugged correctly or it is completely unpluged from the white socket. even if it is not un plugged just make sure it's tight, put everything back together and it should work just fine. ( IT IS A LITTLE DIFFICUL TO SCREW IT BACK TOGETHER BUT YOU"LL GET IT RIGHT) it is a weird problem. but it is easily fixed.
i hope that helps, bye
Posted on Apr 18, 2008
  • 686 Answers
SOURCE: sharp carousel convection microwave model #R-1874F
bad key pad new oven probably cheaper than fixing
Posted on Feb 20, 2009
SOURCE: Reverse Firmware Upgrade
http://www.fixyourownprinter.com/forums/printer/56368
There are two different print engines used in the CLP-300. One for 2006, and a different one starting in 2007. I have the older 2006 printer, and the current firmware is only for the new 2007+ print engine.
I talked to Samsung support here in Korea and fixed the problem. They sent me to their special tech support website at www.1479.co.kr (only in Korean) and I was able to download an older version of the firmware which restored my printing ability.
The latest version of firmware that worked with my printer was found in this post: http://www.bassmania.co.kr
Download the two files at the top, then extract the archive. Drag-n-drop the correct firmware file onto "usblist2.exe" and the printer will be flashed with the firmware (must be connected via USB if you're using the CLP-300N model).
Posted on Jun 14, 2009
SOURCE: LG Arena won't turn on after firmware update
I downloaded the LG Mobile Support Tool at http://www.51spsoft.com/Download.asp?ID=34522, which easily downloaded and installed the right firmware for me.
Posted on Aug 08, 2009
TheMobilian
  • 8220 Answers
SOURCE: Dacor oven beeps and shows F1 code
-F1- Alarm “System Watchdog Circuit”
The system will detect a failure in the internal watchdog element relay circuits and will activate a
cancel feature. F1 will be displayed in the time digits and will beep until the cancel button or another
function is selected. An F1 failure could be detected in cook or time of day mode. With an F1 failure
the ERC is picking up a command to supply heat without receiving an input from the membrane. The
watch dog circuit is designed to prevent this.
If the beep continues after pressing cancel check the main control (ERC)
Dacor
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Aug 20, 2009
My Yamaha HTR 6130 surround sound amp just froze up on me and won't turn off or on or control the volume ect. I'ts on but will not do anything, I can't control from remote or the unit itself at all.
HI
i think the unit needs to be set back to factory defaults
procedure is
Initializing the HTR 6130
1. Connect the power cable of this unit to the AC outlet.
2. Press the "STANDBY/ON" key while simultaneously pressing the "STRAIGHT" and "AUDIO SELECT" keys.
The self-diagnostic function is activated.
3. Select the main menu "13. FACTORY PRESET".
4. Select the "PRESET RSRV".
Hope this helps
Kind regards.
M.Mathis
Apr 14, 2016 | Yamaha Htr-6130bl 500 Watt 5.1-channel...
Where can i get firmware download for yamaha htr-3063
Hi al_sha,
Please be informed that Yamaha did not release firmware that can be downloaded by users, however they provided a step by step procedure on how to update the version of your unit. Please visit this link to have the Firmware update procedure for Yamaha HTR-3063.
Hope it helps.
Thank you for using FixYa.
Jun 16, 2011 | Yamaha HTR-3063
When listening to the fm tuner on my yamaha htr 6060, will all 7 speakers still make sound? i' having trouble getting sound from the other speaker connections other than the L and R front connection.
analog fm is broadcast in stereo you would need to use a simulated surround setting to have sound come out of your rear and mid surround speakers.
your manual says the default setting for fm broadcast is:
Radio Listening TUNER MUSIC ENHANCER
7ch Enhancer
Select this SCENE template when you enjoy FM or AM
radio programs.
make sure you unit is not in straight mode try pushing the straight button on the front of the receiver let us know if more troubleshooting is needed.
Cheers!
Feb 15, 2010 | Yamaha HTR-6060
Trying to upgrade H/D on IBM T43 laptop, get 2010 error on
Error code 2010 is definitely hard drive problem.
Did you get the firmware from the site below?
Link to hardware maintenance manual for reference:
http://download.lenovo.com/ibmdl/pub/pc/pccbbs/mobiles_pdf/39t2393.pdf
Here's the fix straight from the maintenance manual:
If in the primary bay the customer is using a non-IBM or non-Lenovo hard disk drive (HDD), or an old generation IBM HDD which is not supported by this system, with the risk in mind, the customer can still use it by pressing ESC. If in the primary drive bay the customer is using a supported IBM/Lenovo HDD with an old firmware, the customer needs to update its firmware to the latest. The latest version is available at http://www.lenovo.com/think/ support
Mar 13, 2009 | IBM ThinkPad T43 Notebook
I have a 2640b router failure
I think that u need to go on, open your internet explorer, and enter your ip address in the address bar. Enter your password. Check your settings. Sometimes, internet stops, because firmware needs to be updated, sometimes its your computers driver (this is not likely); but most likely, your best option is to update the firmware for it. Consult your manual or internet on how to do it.
Jan 06, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
No audio comes from the rear right speaker. what am i doing wrong with connecting the speaker on the htr-6130?
Swap the rear right speaker to rear left make sure the speakers and speakers wire are OK
Initializer the unit as follow set the unit in STBY mode if you are not sure which mode turn off the unit with the remote control now the unit is in STBY mode. Pressing STRAIGHT and AUDIO SELECT keys simultaneously then press power STBY button on front panel the display will show 1: Analog ByPass use the PROGRAM knob to move up to 13 PRESET INHI then press 1 or 2 keys to change to PRESET RSRV then turn off power now unit reset to factory just turn on and try it
Let me know how do you go
Cheers
PS: this model have an update firmware if your is still under warranty bring it back to Yamaha or 1 of the service center Yamaha they are able to update for you. Due to confidence I can not post that firmware sorry for that inconvenience
Nov 28, 2008 | Yamaha HTR-6130 Receiver
Shows files when i open in my computer but shows no file on playe
I had the exact same issue until I updated the Firmware from Samsung's website.
Updating the firmware was straight forward enough, however, in completing the firmware update-all current data on the player is lost due to the player being updated.
Nov 23, 2008 | Samsung YP-MT6Z MP3 Player
INSTALL A MODEM
The 5360 is techncially a bridge, not a modem, so it doesn't require software drivers for installation and operation.
There is a 5360 firmware upgrade, but it should only be used in certain situations -- see Related Articles at right for further information.
Note that DSL and cable bridges are often called "modems" because that is the familiar term for a device that connects the residential user to the ISP.
Please refer the link below:
http://kb.efficient.com/display/1/articleDirect/index.asp?aid=45459&r=0.9242823
Also refer the FAQ for 5360:
http://www.broadbandreports.com/faq/eff/6_5360
Thanks
Aug 16, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Toshiba estudio35 trouble code
I have a toshiba estudio35 copier I CANAT INSTALL IP\TCP IN MY MACHIN
Apr 20, 2008 | Toshiba e-Studio 350 Copier
Kyocera fs 3900dn printer
It needs a firmware update, very common, it would most likely be under warranty, if not post email so I can give you the firmware update required and I will instruct you on how to upload it to your quality printer.
Nov 27, 2007 | Kyocera FS-3900DN Laser Printer
Open Questions:
111 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
