Question about Neff 24 in. S5555X0GB Built-in Dishwasher
Water not draining away. tap icon displayed - Neff 24 in. S5555X0GB Built-in Dishwasher
  • Neff Expert
  • 414 Answers
Http://www.neff-eshop.com/eshop(bD1lbiZjPTAwOQ==)/neff/gb/prodp.htm?prod=S5555X0GB%2f94&ESHOPTYPE=S
go to link, look at page 4, using a tx20 driver remove the pump cover indicated by number 0462 on diagram, check for obstruction, may be a piece of glass etc so go careful, remove any debris and check the impellor turns ok. The unit will not drain without this cover refitted but you can check impellor is rotating whilst it is off. Check all outlet hoses, particularly the spigot connection under the sink if this is how it is fitted, Good luck
Posted on Jul 08, 2010
2 Suggested Answers
evanusa
  • 197 Answers
SOURCE: bosch dishwasher wont drain
You can check the drain or the filter. You will have to pull it out of the space it is now to access it. Items will get stuck in the drain clogging it.
Posted on May 31, 2009
My LG dishwashing machine model LD 2131 SH displays a F error. What does it indicate?
LG DISHWASHER ERROR CODES AND DESCRIPTION MODELS LD 1420W2 D1420WF LD...
ERROR CODES; FAULTS & REMEDY ERROR DISPLAY [IE]
Inlet error.
Condition: Not reached to the normal water level in spite of 10 min. water supply.
Possible causes:
  1. The Water Tap is not opened.
  2. The Inlet Hose is twisted.
  3. The Filter of inlet valve clogged by impure water.
  4. The Inlet Water Valve is normal ?
  5. The water pressure is very low. ( below 0.5 kgf/ )
  6. Inlet valve is blocked by safety device for leakage sensing.(In case of Inlet Valve).
Remedy
    • Open the Water Tap.
    • Repair the Inlet Hose.
1.Close the Water Tap.
2.Unscrew the Inlet Hose (Inlet Valve side)
3.Clean the Filter of Inlet Valve.
> Replace or repair the Inlet Valve.
> Check the water remain on the base.
1.Check the point of damages and repair or replace the related parts.
2.Disconnect the inlet hose to dishwasher to unlock the safety valve.
ERROR DISPLAY [OE]
Drain error.
Condition: Not fully drained out in spite of 5 min. drain operation.
Possible causes:
  1. The Filter clogged.
  2. The Drain Hose twistec or blocked.
  3. The Drain Pump/Motor or circuit is troubled.
Remedy
    • Clean the Filter.
    • Remove the cause of twist or block.
    • Replace the Drain Pump/Motor or repair the Circuit.
ERROR DISPLAY [E I ]
Leakage error.
Condition: The water level in Tub goes down during operation.
Possible causes:
  1. Water leakage in Hose connections.
  2. Water is leaked by damages.
  3. Impeller of the washing Pump is worn away.
  4. The Thermal Protector of the washing motor is functioned
Remedy
    • Replace the connections of Hose.
    • Check the point of damages and repair or replace the related parts.
    • Replace the washing pump.
    • Check the applied voltage.
ERROR DISPLAY [ F E ]
Excess error.
Condition: Excessive water is supplied than normal water level.(Automatically drain Pump operated.).
Possible causes:
  1. The Inlet Valve is troubled.
  2. The Air Break is troubled.
  3. The Sensor Assembly is troubled.
  4. The Controller is troubled.
Remedy
    • Replace the Inlet Valve.
    • Replace the air breaker.
    • Replace the sensor assembly.
    • Repair or replace the controller.
Jul 09, 2017 | Washing Machines
Flashing display 7 mins into cycle. Water drains away and eventually display goes blank. Help?
Do you get an F21 code or some other code.
An F21 code means the water is not draining away properly. There may be plugged pipe.
Here are some tips to help you:
1. Check to make sure the washer's drain pipe is draining properly.
2. Check the drain hose to see if there are any kicks or clogs in it.
3. Check the washer for excessive subs. Sometimes excessive subs can also keep the water from draining.
Of course, the above tips are useful only if you have a F21 code. If you have other error codes, you'll have to look at the manual that came with the machine.
Feb 22, 2013 | Washing Machines
Machine not emptying subsequently will not spin what can we do
If you still need to remove the water, setup seperate syphon hose. (Garden hose will do, place the hose in the top of the tub submersed under water, turn garden tap on & when the air is out of the garden hose turn tap off & disconnect the hose, providing tap is lower than the machine the water will drain away through the garden hose.)
Remove the power cord from wall socket, lean machine against the wall at 45Deg angle. If yours is an older machine with the access panel in the front panel access the pump through it...
Disconnect pump.
Put a towel over connectors to stop them getting wet in next step.
The pump is removeable by twisting 1/4 turn anti-clockwise, you need to lightly release the barb clip to allow the pump housing to turn. Hopefully you can now see the debris causing the problem.
Make sure all lugs are engaged when reassembling, if one is not the pump will be hard to turn.
EVEN WITH PRODUCT OFF AT THE DISPLAY PANEL THE DRAIN PUMP IS STILL LIVE, MAKE SURE THE POWER PLUG IS PULLED OUT OF THE WALL SOCKET
Aug 07, 2010 | Fisher and Paykel Washing Machines
The red light comes on as if the tank is full of water but its not draining to the exterior tank which is properly attached... I have even manually drained the interior tank from the back at the bottom......
Does the LCD display show a "tank" icon? If not, the pump will not be allowed to empty the water into the tank. This is because the sensor is not detecting the external tank. If the tank is not properly secured to the unit, the magnet is too far away from the sensor. If the tank is secured, try putting a strong neodymium magnet there to temporarily trick it.
Aug 04, 2010 | Danby DPAC120068 Air Conditioner
How to type or save adsresses for destinations
After typing in the address and displaying the map, tap the tools icon then tap save this location. If the tools icon is not displayed tap the center of the screen and display the menu.
Aug 01, 2010 | Garmin GPS
Water does not drain away, remains in bottom of dishwasher at end of cycle
It is very important to have the d/w drain hose attached higher on the drain connection you must have tapped into when you installed it. If it a built in the drain hose would/should lead to just right after the u-trap under the kitchen sink. Hope thatt helps!
Dec 08, 2009 | Cars & Trucks
Slow drain of water from toilet tank!
Turn off the water when it is full and put a drop or two of food coloring in the tank. Sit back and watch and you'll find where the water is going and hopefully that will help you solve the problem. Could be any number of things
Jul 25, 2009 | Siemens SpeedStream 4200 (13A4200001)...
Bosch dishwasher wont drain
Feb 22, 2009 | Bosch 24 in. SGI43E05GB Built-in...
How to change time in Tomtom GPS device
Here's the solution to your problem:
> Tap the "Change preferences" icon
> Tap the Arrow Icon until you reach the screen with the "Set Clock" Icon
> Tap how you would like the time displayed
> Tap done
> Set the correct time to display
> Tap Done
This will set the new time on your unit.
Mar 13, 2008 | Tomtom ONE GPS Receiver
Neff 24 in. S5555X0GB Built-in Dishwasher Logo
827 people viewed this question
Top Neff Dishwashers Experts
Samohthda
Level 1 Expert
shaun taylor
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
