Question about Maytag Atlantis MAV6000 Top Load Washer
My washer has completely stopped running...it still hums and water goes in but will not drain or agitate. the last few loads made the machine smell like burning rubber. its at least 10 years old and has been repaired a couple of times. should i bite the bullet and replace it or get it repaired?
  • Maytag Master
  • 8,220 Answers
It is not uncommon for the water pump to lock up causing the belt to burn and even melt the drive motor pulley. Tip the machine back and check the pump. It should be easy to turn. The bearing will lock slap up on these type pumps with nary a water leak. To replace the pump you need a 3/8th nutdriver and a pair of channel lock pliers. You remove 2 hoses and 3 bolts.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jul 06, 2010
Admiral machine will agitate, but will not drain or spin
Agitating and Spinning are from one motor. Pumping is not controlled by the same motor. If the pump is bad, it won't pump. Pump can be checked by measure the resistance of its terminal, and its measurement should not be open. If pump is good then the problem is from the pump controller. If pump is bad, then you know what to do.
Sep 01, 2009 | Admiral AW22 Top Load Washer
Wash will not drain
Hi, When the cycle goes into drain, do you hear the motor humming at all? If the motor does not hum, check the lid switch.
If the washer agitates, there must be a problem with lid switch ot timer. The lid switch is most common.
Please let me know if this helps or if I can assist you further.
Vic
Jun 20, 2009 | Kenmore 22422 Top Load Washer
Washing machine was making noise when agitating & spinning
This sure sounds like a bad transmission. Turn the transmission by hand to feel and listen to it. It should be smooth and quiet.
May 04, 2009 | Maytag PAV2300 Top Load Washer
How do you diagnose a bad washer pump vs a cloged line?
Amana ALW480DAW seems to be not completely draining. When I start a new load water in basket becomes dingy and smells. Washer smells when it has not been used for a couple of days. We have checked the outflow and inflow drain tubes found no problems. It seems to spin and agitate normally, it drains to a point and leaves water in it, not visible in the basket. When we blow on the outflow tube when it is done draining there is still water present, we can hear it bubble.
Feb 23, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Kenmore Washer will not drain completely
Some machines don`t drain all the water out.
Is it your pipe which goes from the washer to the drain.
These pipes can get very smelly.
I suggest that you just run some soda crystals through the machine on a hot wash cycle.
please try this and let me know what happens
best of luck
Jan 25, 2009 | GE WBSR3140DW Top Load Washer
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Tub will not drain or spin
Dear customer,
i recommend you to kindly check the following parts of the washer..
  • Inspect the drain hose for kinks
  • Test the timer control
  • Test the lid switch (some models)
  • Inspect the water pump
  • Inspect the drive belt (belt drive only)
  • Inspect the motor coupler
    • Inspect the agitator
    • Inspect under the washer for soot (clutch)
    • Test the motor
    • Inspect the pulley
    • Test the transmission
    • Inspect the pump coupling
    hope u find it useful. thank you.
    Jul 06, 2008 | Admiral AW22 Top Load Washer
    Washer repair
    The transmission might have locked up causing the motor to overheat.
    Nov 10, 2007 | Frigidaire FWS833A Top Load Washer
    Maytag Atlantis MAV6000 Top Load Washer Logo
    680 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    John Tripp
    John Tripp
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
