Question about Dishwashers
I have a dishwasher that is model # DB1100XTPQA and for some reason there seems to be no electric current to it now. After concluding there is power to the unit what else could be the problem.
  • 3,361 Answers
If the power connection is good and tight at the wiring terminal box underneath the dishwasher the problem is the door switch.
The incoming power goes to the door switch first.
With the door latched and the switch working correctly,the power then travels to the timer.
Check the door switch.
Posted on Jul 06, 2010
How do I solve the problemp2118
P2118 Toyota Description
The Electronic Throttle Control System (ETCS) has a dedicated power supply circuit. The voltage (+BM) is monitored and when the voltage is low (less than 4 V), the Engine Control Module (ECM) concludes that the ETCS has a fault and current to the throttle actuator is cut. When the voltage becomes unstable, the ETCS itself becomes unstable. For this reason, when the voltage is low, the current to the actuator is cut. If repairs are made and the system has returned to normal, turn the ignition switch OFF. The ECM then allows current to flow to the actuator and actuator can be restarted.
Possible causes
- Faulty Throttle Actuator Control Actuator
- Electronic Throttle Control System (ETCS) harness is open or shorted
- Electronic Throttle Control System (ETCS) circuit poor electrical connection
Read more: http://engine-codes.com/p2118_toyota.html#ixzz3KLEhNm34
Read more: http://engine-codes.com/p2118_toyota.html#ixzz3KLELlJzl
Nov 28, 2014 | 2013 Toyota RAV4
Whirlpool Point Voyager Dishwasher blows thermal fuse - pump motor draws 10A
Yes 10amp seems a lot of current being drawn by the pump motor. Not sure if it is safe to run dishwasher in this condition. One reason could be a leaky capacitor on the motor. Try to replace it. See item 26 on http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Dishwasher-Parts/Model-GU1500XTLB0/1198/0130000/W0503069/00008
Apr 04, 2014 | Whirlpool Dishwashers
The dishwasher doesn't seem to have any electricity.
The fault could be from the wall socket. Troubleshoot with a tester to check if there is electric current running in the socket... If there is, then maybe the fault is from the fridge itself. you can take it to a profession to diagnose and pimpoint the where the fault is actually. Hope it helps...
Mar 28, 2013 | KitchenAid Dishwashers
Suddenly I have no power to my dishwasher. I checked my main house electrical fuses and they seem fine. Is their another fuse in the washer itself to check?
Do some more experiments...Check power is getting to the power point at the back of machine (maybe plug in a lamp or something if you don't have a multi-meter), check external cable for damage (while not plugged in). Is there any signs of power at all? Any lights that come on or beeps made? If your model doesn't have lights to begin with, it could be a problem in the trip switch in the door for example. There probably is an internal fuse... only problem is that if it did blow, it might have for a reason... keep investigating
Aug 12, 2011 | Maytag Dishwasher
When on dishwasher made a funny noise and smoke was coming from it. now dishwasher is dead
Secure power to dishwasher at the breaker box by shutting off breaker. Some models
of Hotpoint dishwashers were recalled for electrical problems. The number for the model
and serial are inside the door on the left. You can Google for recall information.
I have run across 2 of the new dishwashers with the "square" motor pumps with bad
castings in the fan section which broke off and lodged in the motor itself.
On some models the drain solenoid will burn out and produce a nasty smell.
You can check underneath with the power off to see if the triangle shaped control
arm moves freely. You can also inspect the motor to see if it has a broken vane.
If you have aluminum wiring and the dishwasher was connected to it, often the wires
will work loose from vibration and literally burn a hole through the wire nuts themselves.
It would be located inside the connection box (Power off first before checking).
I do not recommend attaching aluminum wiring to a dishwasher for this reason.
Hope this helps locating the problem.
Mar 12, 2011 | Dishwashers
I have a MDB5130AWW model dishwasher and it has worked extremely well up until a week ago. Now there is water sitting at the bottom of the dishwasher, and the "Clean" and "Rinse Only" buttons are blinking....
You may have a seized/stuck motor. Turn the electricity off and remove the lower panels. Take a flat head screw driver and carefully attempt to move the motor impellers. If the impellers feel hard to turn continue to try and free the impellers. If they loosen, reactivate the power and start the appliance. Good luck!
Feb 24, 2010 | Maytag Dishwashers
Is there a minimum amperage for a single family dwelling? The current residents would like a panel change, but only currently have a pull out and screw in fuse style panel. I would tell you more about the...
Per NEC code and local ordinances, no.
This type of work is only to be done by a licensed electrician, and requires that the electrical system be brought up to current code.
That being said, you can do it, but you better know what your doing as there is likely no way to kill incoming power from the meter without pulling the meter. And pulling the meter will violate power company agreements with the property owner.
You also risk liability in the event someone is electrocuted for whatever reason, even if not directly related to what you did.
Any plug in the bathrooms or kitchen within 6 feet of a sink are to be on GFI's, and you can't add a GFI as it's very likely the current wiring does not include a ground.
Dec 12, 2009 | Cutler Hammer Main Lug Load Center, 60 Amp
I have a brand new dishwasher. it doesn't seem to
The reason that the dishwasher is not drying completely is that newer model dishwashers do not have as powerful a heating element to dry the dishes. This is for several reasons mainly due to the manufacturer attempting to reduce power consumption by the machine. The condensation is caused by the same thing. Not much you can do to fix the problem other than towel them off by hand if you dont want to put them away wet.
Nov 25, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
The dishwasher acts like there is no electrical current to it.
Try a lamp in the socket to see if there is power. The dishwasher may have a circuit breaker.
Jul 11, 2009 | Dishwashers
Dishwashers Logo
Top Dishwashers Experts
