Wireless settings how do i download windows wireless settings to my xbox 360
  • wahed2001 Jul 26, 2008
    مشكورررررررررررررررررررررررررررررررررررررررررررر
  • Cheryl Whalen May 11, 2010
    Do you have a wireless controller and a wireless network at home with Internet access? What kind of Windows wireless settings are you referring to?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 359 Answers
Please rate FixYa if this solution resolved your issue!
Posted on Apr 21, 2008
  • Cheryl Whalen Apr 24, 2008
    If you are still having an issue with which I might assist, I would like to get to FixYa!
  • Cheryl Whalen Apr 26, 2008
    Hi there. If we solved your issue, could you please reflect that in rating FixYa, or if you still need assistance, please let me know. Thanks!
My madcatz xbox 360 controller will not connect to my compaq pc. The controller works and installs easily on my laptop. I have downloaded all necessary items from microsoft (xbox 360 controller for...
Vista has an issue with Xbox 360 controllers, let alone Madcatz copies. I would recommend buying an official wired controller for use with Vista. Alternatively you can you a Wireless Gaming Receiver specially designed for using Wireless Controllers on Windows based PC's.
Mar 21, 2011 | Microsoft Xbox 360 Controller
Tip
Setup your Xbox to a Wireless Network
Xbox game consoles can be connected <span style="text-decoration: underline;"></span> to a router<a href="http://compnetworking.about.com/cs/routers/g/bldef_router.htm"></a> for wireless access to the Internet and Xbox Live. Follow these instructions to set up the Xbox or Xbox 360 connections to a wireless home network.<br /><br /> <ol> <li>Connect the appropriate wireless network adapter<a href="http://compnetworking.about.com/od/hardwarenetworkgear/g/bldef_adapter.htm"></a> to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet sometimes also called a wireless network bridge must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi <i>game adapters</i> that connect to a USB port.<br /><br /></li> <li>Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -&gt; Network Settings -&gt; Advanced -&gt; Wireless -&gt; Settings" On the Xbox 360, the menu path is "System -&gt; Network Settings -&gt; Edit Settings."<br /><br /></li> <li>Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.<br /><br /></li> <li>Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)<br /><br /></li> <li>Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard MS Xbox Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP.<br /></li> <li>Save your settings and verify the network is functional.<br /><br /> On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live.<br /><br /> On the Xbox 360, use the "Test Xbox Live Connection" option instead.</li></ol> Tips: <ol> <li>Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.</li></ol><span style="font-weight: bold;">Troubleshooting</span><br /><br /> The built-in diagnostic of the Xbox can help with any falure.Navigate to the <i>System</i> area of the Xbox Dashboard, select the <i>Network Settings</i> menu option, then select <i>Test Xbox Live Connection</i> to run the test at any time. If the Xbox 360 built-in network diagnostic fails with the following message: <br /> <ul><i>Technical configuration error. Please contact Xbox Customer Support.</i></ul> This indicates a network issue requiring further investigation. The Xbox 360 network diagnostic contains the following tests run in the order listed below. Steps for troubleshooting Xbox 360 connectivity issues depend on which test reports the failure. <br />If you have an original Xbox 360 console, you need to attach an Xbox 360 Wireless Networking Adapter before you can connect your console to a wireless network.<br /> <b>Note</b> You can use an Xbox 360 Wireless Networking Adapter with the Xbox 360 S console. If your wireless router is not near your console, you may get a better wireless signal by using a wireless networking adapter. When you connect an Xbox 360 Wireless Networking Adapter to an Xbox 360 S console, the console will automatically use the wireless adapter instead of the built-in Wi-Fi.<br /> If you have an original Xbox 360 console, you need to attach an Xbox 360 Wireless Networking Adapter before you can connect your console to a wireless network.<br /><br /> Step 1: Attach an Xbox 360 Wireless Networking Adapter to the back of your Xbox 360 console.<br /> Step 2: If a network cable is plugged into the back of your console, unplug it. Step 3: Check the light on the Xbox 360 Wireless Networking Adapter.<br /> If you're using the black adapter with two antennas:<br /> <ul> <li><b>No light:</b> The adapter is not receiving power. Unplug the USB connector, and plug it in again. Still no light? Try plugging the adapter into a USB port on the front of the console.</li> <li><b>Green:</b> The adapter is connected to a wireless router, gateway, or access point.</li> <li><b>Flashing green:</b> The adapter is attempting to connect to a wireless network.</li> <li><b>Red:</b> The adapter is not recognized. Try plugging the adapter into a USB port on the front of your console. </li> <li><b>Flashing red:</b> There is a problem. The adapter might be experiencing a hardware failure.</li></ul><br /> Configure your wireless settings Go to <b>My Xbox,</b> and then select <b>System Settings</b>. <br />Select <b>Network Settings.<br /></b>Select <b>Configure Network</b>.<br /> <ol> <li>On the <b>Basic Settings</b> tab, select <b>Wireless Mode</b>. <br /> <b>Note</b> If Wireless Mode is still not available, there might be a problem with your hardware. <br /></li> <li>Select <b>Scan for Networks</b>. </li> <li>Select your wireless network name. <br /><br />If your wireless network is not listed, try either of the following:<br /> <ol> <li>Try improve the router signal by moving the router position.If you are not broadcasting your wireless network name, select <b>Specify Unlisted Network</b>, and enter your wireless network name and security type. </li></ol></li><br /> <li>Enter your wireless network password, and then select <b>Done</b>.</li> <li>Press the <b>B</b> button on your controller, and then select <b>Test Xbox LIVE Connection</b>. If you successfully connect to Xbox LIVE, you'll see this screen:Choose <b>Yes</b> when you are prompted to update the console software. <br /></li></ol>
on Jan 18, 2011 | Video Game Consoles & Games
I have wireless internet how do i get connect to the xbox 360
Depends if you have an Xbox Elite or an older Xbox 360?
If you have an Xbox Elite then there will be an in- built wireless, For older xbox 360's you will have to go and buy an Xbox wireless adapter.
If you go to settings, network settings, and select connect to xbox live via wireless then you will be prompted to input your security details for your Wireless and you should then be connected via wireless to xbox live.
Feb 06, 2011 | Video Game Consoles & Games
My wireless controller/controllers does not connect anymore...i must say though, that they are connecting when i plug them into a wireless convertor designed by microsft for windows OS...so the problem...
There is a XBOX 360 repair guide available that covers this problem and also all other common XBOX problems. You can get your copy XBOX 360 Repair Guide.....you can download it and get help to fix your console.......
Click here to download Microsoft xbox360 repair guide
Jan 03, 2011 | Microsoft Xbox 360 Console
Wireless adaptor was working fine until xbox live update, and since the update is unable to pick up our wireless netowork. Tried switching everything back on and on and re synching modem with xbox, to no...
To connect your Xbox 360 gaming console to a NETGEAR router's wireless network:
  1. Turn off your Xbox 360 and disconnect anything from the I/O port on the back of the console.
  2. Insert your Xbox 360 wireless adapter to the I/O port as instructed by the wireless adapter manual.
  3. Connect the wireless adapter cable to your Xbox 360 I/O port.
  4. Flip up the network adapter's antenna.
  5. Turn on your Xbox 360.
    • If you are using an unencrypted wireless network, your Xbox should connect to it automatically and you do not need to proceed to Step 6.
    • If you are using an encrypted wireless network click the System tab, and then click Network Settings and continue with Step 6.
  6. On the Network Settings page, select Edit Settings.
  7. On the Edit Settings page, select your wireless settings on the Basic Settings tab.
  8. On the Select Wireless Network page, select your wireless network.
  9. On the WEP Network page, type your wireless network key, and then click Done.
  10. On the Apply Settings page, click Test Xbox Live.
  11. If this is the first time you have connected your Xbox 360 to Xbox Live, you will probably be prompted to apply an update. If there are no updates, the Xbox Live Connection page shows that you're connected to Xbox Live. Press the Y button on your controller to continue.
If testing the Xbox it says DNS failed, then update your NETGEAR router firmware:
  1. From your computer, open an Internet Browser and navigate to http://kb.netgear.com to download the firmware for your router.
  2. Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed.
  3. Click Router Upgrade on the top left pane under Maintenance, browse for the firmware downloaded and click Upload.
  4. Wait for the router to reboot.
Dec 20, 2010 | NetGear MA101 802.11b Wireless Adapter
"HOW TO" use xbox 360 controller on pc games
Most games support the gamepad by default. You should not need any software or setup. But you might need the Drivers for it... Check this out, hope it helps:
http://www.microsoft.com/hardware/download/download.aspx?category=Gaming&type=Gaming&sku=JR9-00001
Mar 31, 2010 | Microsoft Xbox 360 Controller
Where can i download free driver for xbox 360 wireless receiver for windows
22 Feb 2007 ... Xbox 360 Wireless Controller cost 11 Dollars to make ... "Future drivers available for Windows Vista™ and Force Feedback for the Wireless Racing Wheel. ... and profiles are available for free download from their forums. ...
digg.com/.../Xbox_360_Wireless_Receiver_for_Windows
Nov 05, 2009 | Microsoft Xbox 360 Controller
I cannot connect to xbox live because my xbox360 cannot find my network
i had this exact problem. the reason mine wasn't working was because the security settings for my wireless router were set on wp2a and the xbox 360 can't pick this up. change your wireless router security to wpa and you should be fine...after i did this it saw my network and i was fine
Jun 02, 2009 | Microsoft Wireless Network Adapter Xbox...
Xbox Networking Problem
Is it possible for a wired connection? In my experience, wired connection is the only thing you can truly count on.
Jan 17, 2009 | Microsoft Wireless Network Adapter Xbox...
Microsoft Xbox 360 Wireless Controller for Windows
HI perform a system restore to before you installed the drivers
(start,Run System restore)
then reinstall them
should work :)
please rate .
Dec 17, 2008 | Microsoft Wireless Receiver For Xbox 360
Computers & Internet Logo
David Payne
David Payne
