Question about GE GTS22KBP Top Freezer Refrigerator
The top of the refrigerator around the light bulb area is hot which makes all the food near it warm. Is there any way to fix it?
  • GE Master
  • 3,361 Answers
Remove the light bulb for a day.
If the area gets cool with no light bulb you will have to repair/replace the light switch near the door.
If it is still warm you will have tp provide more information to find out what is causing the heat.
Posted on Jul 06, 2010
Change light bulb in Maytag MAN1956GE Refrigerator. Can't loosen bulb. Can't remove plastic "cage" around bulb.
Hello Jane;
My name is Peter. I am a retired field service refrigeration technician.
What you have provided is the standard manual number not the model number. The model number is on a label on the inside wall of your fresh food section near the top.
You may have a single screw holding the light cover on.
Note; the bulbs in a refrigerator like all of you appliances is specially designed for the service. They are a little expensive $8.00 - $10.00 each. Some food markets carry them. If not Lowe's or Home Depot.
Go into the following link put in your model number and a diagram will appear to help you.
Water Filters Lawn Garden Appliance Parts
Dec 12, 2014 | Maytag Refrigerators
Why does the front frame get real hot aroune top and bottom doors?
In some units the condenser coils run inside the outer walls of the fridge and this area can get warm. If its really hot check the visible coils at the rear and underneath the unit they may be badly clogged with dust, which cause the rest of the system to run much hotter since the airflow to the lower ones is blocked off. Make sure you clean all visible coils at least every 6 months. This will also cut down on the energy use.
Aug 08, 2014 | Frigidaire Refrigerators
GE side by side refrigerator main light bulb stays on even when door is shut firmly.
There is a switch just inside the door in most on the roof of the fridge, make sure it is not damaged.
Jul 02, 2017 | Refrigerators
LIGHTS STAY ON IN FRIDGE
LG had a problem with the control board going bad allowing the interior lights to stay on even when doors are closed. you need to get in touch with LG concerning repair MY UNDERSTANDING is there is a safety recall and it will be repaired for free. in the mean time unsrew the light bulbs so they dont melt down your liner...
Oct 03, 2012 | LG Refrigerators
My refrigerator is 15 years old. it has a top freezer. has been a good refrigerator until a few weeks ago. the motor is a lot noisier and the area around the freezer door ( top and sides) is really...
The compressor may be short cycling due to a condenser fan stopping while the compressor is running. The heat you feel is coming from the hot gas cycling through what is called a yoder loop. The yoder loop is there to prevent moisture buildup around the door seal. When this area becomes hot it means that something is wrong with the cooling fan below the refrigerator and cleaning the area may help. Please be aware that the fan may appear to be running normally but keep an eye out after cleaning because a bad fan does not always stop all the way and I have made up to three trips before catching one that has stopped. Always unplug the power before attempting to reach inside the compressor area. Feel compressor top to see if warm, hot or too hot to keep hand on top. Again this problem can be the condenser fan, dirty condenser restricting air flow or the start components of the compressor are worn out or all of the above. Fixing this now may extend your refrigerators life another 10 years. If you have any questions I will be here to assist you, Thanks, Sea Breeze
Jun 13, 2011 | Magic Chef Refrigerators
Kenmore refrigerator will not run when plug in
Look around door frame on fresh food side. I need a number like 321.258947 and may be near floor. Unplug and pull away from wall the remove the lower cover where the compressor is. Feel top of compressor to see if warm or just too hot to keep your hand there. I have never understood why Sears call 5561 as a model number. I will call this a request for clarification until you come back. Sea Breeze
Oct 13, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
The refrigerator and the frezzer stop working. I have power because the lights are working normally. Can i fix it.
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Jul 12, 2009 | Whirlpool ET1FHTXM Top Freezer...
Our whirlpool gold refrigerator is 50 degrees
Sounds like your refrigerator is not defrosting. Could you send me the model number so I can help you better? Look at following areas for the model number
  • Beneath Or Inside Food Compartment On Cabinet Frame
  • On Plate Lower Front Or Rear Of Cabinet
  • Beside Compressor Door On Right End
  • Near Rear Of Cabinet
  • Inside Liner At Top
Mar 29, 2009 | Refrigerators
Light
I have a Whirlpool side-by-side refrigerator. The freezer is too cold, ice cream get has ard as rock, but the fridge side is very warm, althought i turn it to to the coldest setting. Food is getting bad very fast. Does someone know how to fix it?
Thanks.
Jul 26, 2008 | Whirlpool GD2SHGX Refrigerator
GE GTS22KBP Top Freezer Refrigerator Logo
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
