Question about KitchenAid KGST307 Gas Kitchen Range
Oven heating very slow smell gas - KitchenAid KGST307 Gas Kitchen Range
    President:
  • 1,430 Answers
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. There is a video at http://appliancehelponline.com/gasoventroubleshootvideo.html this will walk you thru the correct procedure for performing this test. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Posted on Jul 06, 2010
Whirlpool super capacity 465
Call a gas engineer at once. Gas is extremely dangerous.
Jul 19, 2013 | Ovens
Oven slow at starting, there is smell of gas before oven turns on
If there is a smell of gas PLEASE STOP USING IT you risk fire or explosion or both. Please get a registered Gas-fitter to look at this. If you can Turn OFF the Gas at the Wall/Outlet. Until it can be looked at. If you smell gas it is very dangerous.
Feb 11, 2010 | Ovens
Our oven doesn't heat and smells like gas
This sounds like a weak igniter, it would have to be a gas oven and the symptoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Feb 02, 2010 | Maytag Ovens
Oven is slow ot light and has a gas smell when
Hi, this sounds like a weak igniter, it would have to be a gas oven and the symptoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, if it does light the burner, there may be delayed ignition (pop), does not maintain set temperature or burner does not come on fully, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Jan 21, 2010 | Kenmore Ovens
Oven works sporadically
IF YOU CAN SMELL GAS, TURN THE STOVE TAP OFF. Get it checked out immediatly.
Aug 03, 2009 | Whirlpool GS460 Gas Kitchen Range
Maytag gas oven slow to ignite,makes poof sound
sounds like the safety valve gas regulator (its where the main gas line attaches in the bottom back)
Mar 25, 2009 | Maytag CWG3100A Gas Single Oven
Our oven smells of gas and takes forever to heat
It may be that the heating element is dirty and consequently, is not igniting the gas. Mine was doing the same thing and was also making a big BOOM sound which was the sound of the gas in the oven igniting after too much gas was released.
I called a friend who gave me these instructions and it worked...I was able to fix it in about 30 mins.
1. Remove the floor of the oven...there are two screws along the back wall of the oven holding the oven pan (the floor of the oven) in place. remove these two screws using a Phillips screw driver. The oven floor pan will then pull out.
2. Remove the thick steel plate next which is located in the center...just under where the oven floor pan sits. Remove the the right and left screws located along the outside edge of the oven floor rim and the center nut. I used a cresent wrench for the two screws and the center nut...didn't feel like finding the right socket size and don't have the special screw driver fitting.
3. You will see an aluminum pipe that runs down the center from the front to the back. Near the back and mounted to right side of the aluminum pipe there is the heating element. It is protected by a metal casing. There are two screws securing it to the housing. With your wrench, remove the two screws and gently pull it back. The heating element is made of a ceramic material and is delicate. Using a tooth brush, gently brush the heating element to clean it.
Jan 17, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Get too much of a gas smell when Magic Chef oven prheats up.
gas does NOT take that long to heat up!!
Shut that thing off before you kill your family !!!
Take it back or call someone to fix it !
This is a ticking bomb you have,...
If You smell gas then you should call the city or 911 .
Jan 15, 2009 | Magic Chef 31000 Gas Kitchen Range
Amana Big Oven Will Not Heat
slow to preheat??? long cooking times??? smell gas while in operation???. all signs of a bad oven ignitor retails for about 60-65. easy enough to replace reomve the lower panle of the oven itself and you'll see the ignitor right there 2 ***** mount that to the bake bar and pull it out, unplug the wire harness, plug in the new one and remount.Start baking
Mar 09, 2008 | Kitchen Ranges
KitchenAid KGST307 Gas Kitchen Range Logo
788 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
