Question about HP DesignJet 1050c plus InkJet Printer
System error on plotter screen
1st on plotter scrren came the msg system error 04c300 0021000, later wen i switched the power off, and then ON, came another error msg , system error 0000D8 005D0273, pls help, do i have to call a technician../ thanks & regards
pradeep
    Scholar:
  • HP Expert
  • 123 Answers
Follow-up to previous message... ended unexpectedly.
Enter the test mode and run the ELECTRONICS test. The plotter will tell you in plain English what the problem is. If it hangs up, power down.
Posted on Jul 08, 2010
I get an error msg that the transducer is not connected. How can I check idf the transducer is faulty
If you can find someone with a Humminbird that has the same pin configuration on the transducer cable, switch yours out and put the transducer in a bucket of water to see if it works. Otherwise, make sure the cable at the plotter end is firmly placed in the socket, and that no pins got bent in the past. Some of these models came with a metal clip that holds the end of the cable(s) tight to the plotter and is held tight by the mounting bracket screws.
Aug 28, 2011 | Humminbird Matrix 97 Combo Fish Finder And...
When I started my DELL Inspiron 1525 running Win 7 Ultimate, I got a white-on-black screen which questioned the voltage from power adapter. Diagnostic program run.. Stopped with the following msg: Error...
2000-0142 and 2000-0146 are hard drive SMART errors, indicating the HDD will fail.
To boot message about the AC adapter was a BIOS level message that normally appears when a Auto/air ac adapter or other 65 watt ac adapter is used to power the system.
Jul 16, 2011 | Dell Inspiron 1525 Laptop
Hp plotter designjet 1055 CM plus plotter produces system error
one of the printheads is bad.....check the error code again,because 060308 does not exist in hp designjet 1055cm plotter.
Jul 31, 2009 | HP Office Equipment & Supplies
Cant do EEROM setup coz severe error:0x4010008 occured
restart the plotter in service mode using following method
1 power off the plotter
2 press Up Arrow + Enter Button ( green buton) and while pressing both buttons switch on the plotter
3 when u see service test /Service utilities release keys & select service utilities & then perform eerom setup there , put the actual model number ( c7780b/c ) and it wil resole the issue
Mar 30, 2009 | HP DESIGNJET 800 42IN 1200DPI 96MB PAR USB...
HP vs17e My screen went black for a few moments and when it
Switch off and on your PC and hold down the F5 key and this should bring up your PC in Safe Mode. If this fails, then find a PC repair shop to replace the power supply.
Mar 22, 2009 | Computers & Internet
Error 47:01 for hp desighjet t1100 plotter
System Error: 47:YZ
Problem
Description:
Star wheels motor error..
Corrective Action: Try the following:
�� Switch the Power OFF from the back of the Printer and disconnect the
Power cord. Reconnect the power cord and power On the Printer.
�� Check that the Starwheel Assembly cable is not damaged and is correctly
connected to Main PCA.
�� Open the Window and check for any visible obstacles restricting the
movement of the Starwheel Assembly, then clear the obstruction.
�� Perform the Scan Axis Starwheel diagnostic test to troubleshoot the
problem further → Page 4-7.
�� Replace the Starwheel Motor → Page 8-167.
�� If the System Error continues, replace the Main PCA
Okay, this is direct from the repair manual. if this is a new printer you have one year warranty service on this printer. hope this helps!
Feb 03, 2009 | HP Designjet T1100ps Printer
White screen
appears that lcd screen is damaged and would need replacing
Aug 11, 2008 | Olympus FE-230 Digital Camera
Blank blue screen
Comment by suekanos, posted on Jun 03, 2008 this phone was just switched off in the night.the following day when i tried to switch
May 29, 2008 | Panasonic X300
HP DesignJet 1050c plus InkJet Printer Logo
508 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
