Question about AudioCodes MediaPack MP-118-FXS Router (MP118FXSC3S)
Whats the maximum distance for a full load FXS endpoint the MP118 can support? [maximum cable distance from the FXS port to the analog telset.]
How to configure it
You need to connect it with your router using ethernet cable then check which IP is assigned with router and then type that IP in your browser address bar to enter into your device setup. Once entered into setup then follow the on screen instructions.
Mar 05, 2012 | Linksys SPA-2102 NA Analog VoIP Adapter...
How does and Atlas 550 split to analog
The Atlas 550 is modular, and can break out the 23 channels as BRI or FXS. Since you want 23 analog lines, I presume you want regular 2-wire phone lines (aka, FXS lines). The you that by using 3 "Octal FXS" modules (8 port modules) in addition to the T1 module.
Read more here: http://www.adtran.com/web/appmanager/portal/Adtran?_nfpb=true&partNumber=1200305E2
Nov 21, 2011 | Adtran Atlas 550 (4200305L3) Multiplexer
Password recovery on PAP2
There is a hard reset that can be done via the phone IVR. Connect an analog phone to the RJ-11 port on the PAP2 and pick up the handset, where you will hear dialtone. Press * (4) times and you will be told you are entering the configuration menu. Press 7 3 7 3 8 + # and you will be asked to enter 1 to confirm. Congratulations, you factory-defaulted your PAP2, the adapter will restart and you can log in with the default user name 'admin' with no password.
Mar 06, 2011 | Linksys SPA-2102 NA Analog VoIP Adapter...
I need to hard rest my Linksys Spa 2102 and it is asking me for a password. How can I get arrond this. The password was set by my previous Viop provider.
dial **** and 73738# and press 1 to confirm the resetting. wait for 1 minute
Whats the provider, sometimes they are provide locked :(
Feb 19, 2011 | Linksys SPA-2102 NA Analog VoIP Adapter...
How do i add udp ports 5198- 5199
From Control Panel click on the firewall Icon, Advanced settings, Connection and security rules, New rule, Custom, Protocol and Ports. In Port Type choice UDP, in Endpoint 1 port choose specific Port, in the text box bellow enter your start Port. do the same for Endpoint 2 Port. Complete the setup by clicking next
May 28, 2010 | Siemens SpeedStream Modem (4100) (SS4100)
No connectivity via Ethernet cable
The cable may be bad. I ran into that same problem just last week
Mar 05, 2010 | AudioCodes MP118 Analog Modem
Samsung hlp 4663w does not receive off air signal from roof antenna through antenna ports 1 or 2. Get cable signal just fine through same ports. Same antenna works fine on other tvs. Whats the problem and...
If you're in the US, you will no longer get antenna signals because the US has recently switched to digital. The TV you have does not have a digital tuner and you'll need to purchase a digital converter box that converts a band of analog signal to digital.
Feb 03, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
How unlock linksys modem spa2102
If it's locked to sunrocket, google for SPA2102 sunrocket unlock. Loads of how-tos out there.
If it's not sunrocket, go to broadbandreports.com and send a PM to DogFace05. He has a small business based around unlocking SPA2102 routers (so it's not free - but will turn your SPA into something usable)
Dec 05, 2009 | Linksys SPA-2102 NA Analog VoIP Adapter...
What is the maximum distance for the AT-MC1005/1
MC 1005/1 is singlemode MEDIA CONVERTER for 10 km distance and FS 232/4 is singlemode 2 PORT SWITCH for 100 km distance
Aug 24, 2009 | Allied Telesyn AT MC1005/1 (AT-MC1005/1)...
Audiocodes MP118 8 FXO early media to Freeswitch SIP extension
Hi, man.
There are many things to consider in this type of application.
when calling from PSTN to IP using analog lines from time to time you will have this type of event, I suggest working with H323 protocol, this will tone down a bit your problem.
If you want optimum performance, you should use a DID with the channels you need and address to your PBX SIP FreeSwitch. The DIDs are cheaper and are digital which eliminates random connectivity problems in the incoming call.
Once you have directed the DID you tell your server to transfer the call to the IVR using your internal dialing plan.
Lucky
Oct 06, 2008 | AudioCodes MP118 Analog Modem
AudioCodes MediaPack MP-118-FXS Router (MP118FXSC3S) Logo
77 people viewed this question
Top AudioCodes Computers & Internet Experts
Are you an AudioCodes Computer and Internet Expert? Answer questions, earn points and help others
